mạch hiển thị dung lượng pin
  • danhpro1
    • Apr 2009
    • 40
    các bác cho em sơ đò nguyên lý mạch điện hiển thị dung lượng pin đi, nếu có mạch bảo vệ thì càng tốt.
  • rstAkaiIto
    • Sep 2009
    • 77
    Description.
    This circuit uses a LM339 pdf, a quad comparator. LM339 pdf can work on single or dual supplies, it has a open collector output that can drive 15mA, low power consumption. The circuit is an untested design but it should work. I did it as many searches were made in my webpages with these keywords.
    There are many better circuits in the various circuit archives i have linked on the front page, you just have to look around. When you measure the open circuit voltage of a battery with a high impedance DMM (10M), the value may be a bit misleading. Apply a dummy load to bleed the battery a bit so that proper readings can be taken on Load. The load below is a 100 ohms wire-wound fusible ceramic resistor which will heat a bit when you test 12V batteries.Theory of Operation.
    R16 a 5W ceramic wire wound bleeder or dummy load. R15 is a part of an attenuator for obtaining ranges. D2 is a protection clamp diode. R10-D1 forms the 5V reference for comparators. Then an attenuator obtains 1.2, 1.4, 1.6, 1.8 V steps for each comparator. This circuit is similar to Audio Level meter or VU meter circuit.
    The comparator compares the battery sample voltage to the fixed reference step. If '+' pin is more positive than '-', or is '+' is more dominant, then output goes floating 'open collector', so No LED light . But if '-' is more dominant the output transistor of comparator goes low impedance or saturates or turns 'ON'. But only spec current can be switched, do not compare with electrical switch 'ON'. Also on a dual supply 0V is more dominant or positive compared with -12V, even though it appears -12V is a big number. The direction of current is what decides, all measurements are relative.
    Data sheets and Information.
    Ai bit tiếng anh dịch
    • gth_pcb
      • Sep 2009
      • 166
      Cái mạch của bạn AkaiIto mình thấy rất hay. Trước kia mình cũng làm rồi. Nếu bạn không mua được con LM1339 thì thay bằng con uA741 cũng được. Nếu muốn tăng độ chính xác của mạch đo thì tăng số IC so sánh lên nữa.
      GTH sản xuất mạch in PCB 1 mặt:
      -phủ xanh: 40.000 đ/dm2
      -không phủ xanh: 30.000 đ/dm2
      -Cung cấp mực cảm quang để làm mạch in
      email:
      • huuphuong
        • Dec 2007
        • 243
        Nguyên văn bởi gth_pcb Xem bài viết
        tôi thấy 339 còn dễ tìm hơn 741 chứ
        danhpro1 Tìm hiểu thêm về danhpro1
