download từ ieee
  • ITpro
    • Jan 2006
    • 35
    #16
    Nguyên văn bởi jefflieu Xem bài viết
    Nhieu lam, chiu kho' search di roi chi ra chinh xac tai lieu na`o roi Jeff down cho ....
    Bác kiếm hộ em cuốn này với xin cảm ơn trước hòm mail của em là : manhtranlinh@gmail.com
    The history of noise [on the 100th anniversary of its birth]
    Cohen, L.
    Signal Processing Magazine, IEEE
    Volume 22, Issue 6, Nov. 2005 Page(s): 20 - 45
    Digital Object Identifier 10.1109/MSP.2005.1550188
    Summary: In this paper, the author conveys some of the vibrant history of noise that has been involved in the solution of some of the greatest scientific, mathematical, and technological problems. This paper aims to show that the history of noise is an exciting story filled with drama and worth telling.
    Dấu hỏi vòng vòng
    Dấu ngã cong cong
    Khi ngã ta lại hỏi
    Ngã lần này có đứng dậy nữa không
    • chinh4030029
      • Mar 2008
      • 5
      #17
      Bác cho em xin mấy file này với, thanks bác trước hén ^.^
      Taku Noda, “Development of the transmission line
      model considering the skin and corona effects for
      power system transient analysis“ – PhD dissertation,
      Doshiha University, Kyo*** Japan, 1996.
      Vu Phan Tu, Josef Tlusty, "The Calculated Methods of
      a frequency-dependent Series Impedance Matrix of
      Overhead Transmission Lines with a lossy ground for
      Transient Analysis Problem," Proc. of IEEE- PES
      Conf., LESCOPE’03, pp. 159-163, Montreal Canada,
      May 2003.
      Vu Phan Tu, Josef Tlusty, “The Induced Magnetic
      Field Calculation of Three Phase Overhead
      Transmission Lines above a Lossy Ground as a
      Frequency Dependent Complex Function,” Proc. of the
      IEEE-PES, LESCOPE’03 Conf. – Montreal Quebec,
      Canada – pp. 154 -158, May 2003.
      • chinh4030029
        • Mar 2008
        • 5
        #18
        Vội quá nên quên ^^ mail của em là jchinh03@yahoo.com
        • taolao
          • Jul 2006
          • 148
          #19
          Nguyên văn bởi chinh4030029 Xem bài viết
          May 2003.
          Vu Phan Tu, Josef Tlusty, "The Calculated Methods of...
          Vu Phan Tu, Josef Tlusty, “The Induced Magnetic...
          Phen này ông quyết buôn băng dính,
          Vừa bán vừa hm... hm... cũng đắt hàng.
          • taolao
            • Jul 2006
            • 148
            #20
            Nguyên văn bởi ITpro Xem bài viết
            Cohen, L.
            • chinh4030029
              • Mar 2008
              • 5
              #21
              Thanks bác TaoLao nhé, em đã nhận được file bác gửi rùi
              • chinh4030029
                • Mar 2008
                • 5
                #22
                Bác cho em xin thêm cái này nghen ^.^ jchinh03@yahoo.com
                A. Deri, G. Tevan, A. Semlyen, and A. Castanheira,
                “The Complex Ground Return Plane, A Simplified
                Model for Homogeneous and Multi-layer Earth
                Return,” IEEE Trans. Power Apparatus and Systems,
                Vol. PAS-100, pp. 3686-3693, 1981.
                The influence of sag in the Electric Field calculation around High Voltage Overhead transmission lines
                Amiri, R. Hadi, H. Marich, M.
                Dept. of Electr. Eng., Oran Univ. of Sci. & Technol., Mohamed Boudiaf;
                • testervn
                  • Mar 2008
                  • 7
                  #23
                  Cho em xin tài liệu này
                  Article Information
                  Intra-block algorithm for digital watermarking
                  Duan, F.Y.; King, I.; Chan, L.W.; Xu, L.
                  Pattern Recognition, 1998. Proceedings. Fourteenth International Conference on
                  Volume 2, Issue , 16-20 Aug 1998 Page(s):1589 - 1591 vol.2
                  Digital Object Identifier 10.1109/ICPR.1998.712016
                  Summary:We present a variant to the DCT-based block algorithm proposed in Hsu and Wu (1996) for signal embedding in digital images. Instead of inter-block relations, our algorithm uses intra-block relations to generate the watermarked image. We describe the algorithm and its performance against translation and cropping. The features of our method are: (1) the watermark is perceptually invisible; (2) little loss of relevant information of original image; (3) the watermark can be retrieved by using a secret key; and (4) the watermark is robust against translation and area cropping
                  Cảm ơn nhiều
                  • taolao
                    • Jul 2006
                    • 148
                    #24
                    “, A Simplified
                    The Complex Ground Return Plane...
                    The influence of sag...
                    • taolao
                      • Jul 2006
                      • 148
                      #25
                      Nguyên văn bởi testervn Xem bài viết
                      Article Information
                      Cảm ơn nhiều
                      • chinh4030029
                        • Mar 2008
                        • 5
                        #26
                        Thanks bác nhìu nhé em đã nhận được tài liệu bác gửi ^_^
                        • blackbirdnt
                          • Aug 2007
                          • 7
                          #27
                          thanks a lot
                          Nguyen Quoc Huy - 0986088777
                          • testervn
                            • Mar 2008
                            • 7
                            #28
                            Thanks bác nhiều, đã down được tài liệu.
                            Cho em xin thêm tài liệu này nha
                            Novel DCT and DWT based Watermarking Techniques for Digital Images
                            Article Information
                            Tripathi, S.; Jain, R.C.; Gayatri, V.
                            Pattern Recognition, 2006. ICPR 2006. 18th International Conference on
                            Volume 4, Issue , 0-0 0 Page(s):358 - 361
                            Digital Object Identifier 10.1109/ICPR.2006.872
                            Summary:Two digital image watermarking techniques that have higher level of security compared to most of the existing algorithms have been proposed. The proposed digital watermarking scheme uses the properties of discrete cosine transform (DCT) and discrete wavelet transforms (DWT) to achieve almost zero visible distortion in the watermarked images. These techniques use a unique method for spreading, embedding and extracting the watermark. Embedding using a linear relation between the transform coefficients of the watermark and a security matrix has been proposed with satisfactory results. It has been shown that instead of adding the watermark to the source image, as is normally done, multiplying the watermark with the transformed source could be a preferred technique, as it would retain the original bit rate to a large extent. The watermarked images were tested subject to image cropping
                            • taolao
                              • Jul 2006
                              • 148
                              #29
                              Novel DCT and DWT based Watermarking Techniques for Digital Images[/URL]
                              • testervn
                                • Mar 2008
                                • 7
                                #30
                                Cảm ơn taolao nhiều
                                levan8421 Tìm hiểu thêm về levan8421
