download từ ieee
  • falleaf
    Administrator
    • Jul 2005
    • 3429
    #91
    Nguyên văn bởi haphung Xem bài viết
    ieeexplore.ieee.org/iel5/31/23596/01086263.pdf?arnumber=1086263
    em rất cần tham khảo tài liệu này. bác làm down júp em với
    em rất cảm ơn!
    Của em đây.
    Chúc vui
    Falleaf
    • haphung
      • Sep 2007
      • 3
      #92
      em cảm ơn anh nhiều!
      • vatech
        • Jun 2008
        • 3
        #93
        chào các bác, mình đang cần 1 số tài liệu tham khảo trên IEEE để làm đề tài nhưng không có account
        bác nào có thể down giúp mình 1 số tài liệu sau đây được không?
        Xin trân thành cảm ơn.
        1. N.Nabona, J.Castro, J.A.Gonzalez. Optimum Long-term Hydrothermal Coordination with Fuel Limit, IEEE Transaction on Power System, Vol.10, No.2. May 1995.
        2.A.A.F.Mcarneiro, S.Soares, P.S.Bond, Alarge scale application of an optimal deterministic hydrothermal scheduling algorithm, IEEE Transactions on Power System, Vol. 5,No.1, February 1990.
        3.M.K.C.Marwali, S.M.Shahidehpour, Coordination between long-term and short-term generation scheduling with network constraints, IEEE Transactions on Power System, Vol.5.No.3, August 2000.
        4.Pang, C.K, Chen,H.C. Optimal Short-Term Thermal Unit Commitment, IEEE Trans. Power system, Vol. PAS-95, No.4, pp.1336-1346, Jul./Aug. 1976.
        5.Development of a profit maximisation Unit commitment program. The University of Manchester institute of Science and Technology, September 2000.
        6.Generator bidding in oligopolistic electricity markets using optimal control: fundamentals and application
        7.Optimal dispatch under transmission contracts Fang, R.S. David, A.K.
        Dept. of Electr. Eng., Hong Kong Polytech., Kowloon;
        8.Optimal response of a thermal unit to an electricity spot market
        Arroyo, J.M. Conejo, A.J.
        Dept. de Ingenieria Electr. y Electron., Univ. de Castilla-La Mancha;
        9.Power generation planning and risk management in a liberalisedmarket
        Bjorkvoll, T. Fleten, S.-E. Nowak, M.P. Tomasgard, A. Wallace, S.W.
        SINTEF Ind. Manage., Trondhei
        • 207.207
          • Oct 2007
          • 11
          #94
          Cam on TAOLAO nhe. May hom nay di CT, phai nho dua em vao lay ho tai lieu nen khong cam on ban dc. Nhan tien lay ho cai nay voi :
          Measuring bottleneck bandwidth of targeted path segments
          Harfoush, K.; Bestavros, A.; Byers, J.
          INFOCOM 2003. Twenty-Second Annual Joint Conference of the IEEE Computer and Communications Societies. IEEE
          Volume 3, Issue , 30 March-3 April 2003 Page(s): 2079 - 2089 vol.3
          Digital Object Identifier
          Summary: Accurate measurement of network bandwidth is crucial for network management applications as well as flexible Internet applications and protocols which actively manage and dynamically adapt to changing utilization of network resources. Extensive work has focused on two approaches to measuring bandwidth: measuring it hop-by-hop, and measuring it end-to-end along a path. Unfortunately, best-practice techniques for the former are inefficient, and techniques for the latter are only able to observe bottlenecks visible at end-to-end scope. In this paper, we develop end-to-end probing methods which can measure bottleneck bandwidth along arbitrary, targeted subpaths of a path in the network, including subpaths shared by a set of flows. We evaluate our technique through extensive ns simulations, then provide a comparative Internet performance evaluation against hop-by-hop techniques. We also describe a number of applications which we foresee as standing to benefit from solutions to this problem, ranging from network troubleshooting and capacity provisioning to optimizing the layout of application-level overlay networks to optimized replica placement.
          • 207.207
            • Oct 2007
            • 11
            #95
            cam on nhieu nhieu. may qua la may
            • Kekhukho
              • Sep 2006
              • 213
              #96
              Bác down giùm em bài báo này với:
              Wind Generator Stabilization With Doubly-Fed Asynchronous Machine
              Li Wu; Zhixin Wang
              Power Electronics and Motion Control Conference, 2006. IPEMC apos;06. CES/IEEE 5th International
              Volume 1, Issue , 14-16 Aug. 2006 Page(s):1 - 6
              Thanks
              Biển học vô bờ
              • vatech
                • Jun 2008
                • 3
                #97
                Nguyên văn bởi vatech Xem bài viết
                http://ieeexplore.ieee.org/xpl/freea...rnumber=964636
                Hello, Bác Taolao ơi giúp cho mình cái vụ này với, mình đang cần gấp để làm đề tài, mong bác giúp đỡ
                Xin cám ơn và hậu tạ
                • taolao
                  • Jul 2006
                  • 148
                  #98
                  Download here
                  Phen này ông quyết buôn băng dính,
                  Vừa bán vừa hm... hm... cũng đắt hàng.
                  • taolao
                    • Jul 2006
                    • 148
                    #99
                    Nguyên văn bởi Kekhukho Xem bài viết
                    Li Wu; Zhixin Wang
                    Thanks
                    Download here
                    • taolao
                      • Jul 2006
                      • 148
                      #100
                      Nguyên văn bởi 207.207 Xem bài viết
                      Download here
                      • 207.207
                        • Oct 2007
                        • 11
                        #101
                        Cảm ơn pác nhé
                        Hihihihi
                        • 207.207
                          • Oct 2007
                          • 11
                          #102
                          Available Bandwidth Measurement on any Target Link Using Prioritized Packet-Pair Probes
                          Wei-Xuan, Gu; Shun-Zheng, Yu
                          TENCON 2006. 2006 IEEE Region 10 Conference
                          Volume , Issue , 14-17 Nov. 2006 Page(s):1 - 4
                          Digital Object Identifier 10.1109/TENCON.2006.343827
                          Summary:Available bandwidth plays a very important role in Web and Internet applications such as route selection, load balancing and network security. This paper presents a novel technique of prioritized packet-pair probes for available bandwidth measurement. The new measurement overcomes traditional methods in that it needs no path assumptions and it works very well on any target link even under high traffic load conditions. The experiment results validate the new method and show good performances in tracking traffic variances
                          One way delay trend detection for available bandwidth measurement
                          Chobanyan, A. Mutka, M. Zhiwei Cen Ning Xi
                          Dept. of Comput. Sci. & Eng., Michigan State Univ., USA;
                          This paper appears in: Global Telecommunications Conference, 2005. GLOBECOM '05. IEEE
                          Publication Date: 28 Nov.-2 Dec. 2005
                          Volume: 2, On page(s): 5 pp.-
                          ISBN: 0-7803-9414-3
                          INSPEC Accession Number: 8946277
                          Digital Object Identifier: 10.1109/GLOCOM.2005.1577809
                          Date Published in Issue: 2006-01-23 09:15:22.0
                          Abstract
                          Available bandwidth (AB) defined as a minimum spare capacity of links constituting a network path is an important QoS characteristic of the path. We propose to improve a whole range of "probe-rate" AB measurement tools that send sequences of measurement packets (called "trains") across the network path. If transmission times of packets in the train, called one way delays (OWD), show an increasing trend as packet sequence number in the train increases, then AB is believed to be lower than the rate at which the train was sent. In contrast, an absence of a trend indicates that AB is higher than the rate of the train. We propose an algorithm for efficient OWD trend detection and compare it to widely used OWD trend detection tests.
                          Bác TAOLAO lấy hộ cái này nữa với.
                          Cảm ơn nhiều nhiều.
                          • vatech
                            • Jun 2008
                            • 3
                            #103
                            Thành thật cảm ơn bác Taolao, tài liệu này rất cần thiết cho mình. Khi nào có điều kiên mình xin hậu tạ bạc.
                            • taolao
                              • Jul 2006
                              • 148
                              #104
                              ISBN: 0-7803-9414-3
                              Abstract
                              Cảm ơn nhiều nhiều.
                              Download here
                              @vatech: Bạn chỉ cần click nút "cảm ơn", ko cần hậu tạ gì đâu. Chỉ click chuột thôi mà, chẳng tốn công sức gì cả. Trước đây lúc làm LATN mình cũng nhờ 1 người bạn download dùm mấy bài ở IEEE. Bây giờ mình có điều kiện thì download dùm bạn thôi. Nếu mai này bạn có điều kiện thì bạn cũng làm như vậy là được rồi.
                              • vaiduakhu
                                • Apr 2007
                                • 41
                                #105
                                Có bài này chắc sẽ giúp các bạn từ download được bài báo IEEE cho mình.
                                How to get access for literature by CODEEN
                                If you want to know about codeen, you can search in google:
                                The proxy of codeen is too many, you can get easily.
                                What I tell you is how to use the codeen proxy to get some literature,maybe some people have know about it.
                                1. First I you can a proxy of codeen at: http://fall.cs.princeton.edu/codeen
                                2. You will find a “good” proxy as pic shown. Don’t choose the proxy which port of 3124/3128/3127 is blocking, it is very important to choose proxy.
                                Here, I choose 198.163.152.229.
                                3. open http://all-nettools.com/toolbox( thanks peter02402), locat this proxy.
                                Result as following:
                                scientific institution is very good.
                                4. Change the proxy of our browser to 198.163.152.229, notice:the port must be fill in 3128or 3124,3127.
                                My browser is firefox:
                                5. Now, I take the sciendirect as example:
                                open science.adsense-seo.net, it redirect www. Sciendirect.com(198.81.200.2). don’t open www.sciendirect.com at your brower,because all proxy of codeen has hold back most all domain of literature site. You must know a domain which can redirect datebase of literature directely.I will provide some for you.
                                6. You can search some article:
                                7. I go to University of Florida Libraries and find http://www.uflib.ufl.edu/afa/
                                Click it and I see:
                                domain MY domain IP
                                http://www.sciencedirect.com/ science.adsense-seo.net 198.81.200.2
                                http://ieeexplore.ieee.org ieee.adsense-seo.net 140.98.193.112
                                http://www.proquest.com/ proquest.adsense-seo.net 192.195.245.135
                                http://gateway.ovid.com/ ovid.adsense-seo.net 192.84.75.109
                                http://www.springerlink.com/ spring.adsense-seo.net 203.98.210.65
                                NetLibrary.adsense-seo.net 216.52.36.1
                                Acs.adsense-seo.net 216.143.112.80
                                indian.adsense-seo.net 203.110.246.22
                                spring.adsense-seo.net springer.lib.tsinghua.edu.cn 203.98.210.65
                                wiley.adsense-seo.net 208.215.179.155
                                CRCnetbase: http://crcnetbas.ddns.us
                                levan8421 Tìm hiểu thêm về levan8421
