download từ ieee
bác ơi
down hộ em cái này với WiMAX Module for the ns-2 Simulator
Bạn taolao ơi, down cái này giúp với, mình đang cần các tài liệu bên dưới để làm luận văn. Cám ơn rất rất nhiều.
1. C.S. Chang, A.C. Liew , J.X. Xu , X.W. Wang , and B. Fan
Dynamic security constrained multiobjective generation dispatch of longitudinally interconnected power systems using bicriterion global optimization
2. D. Streiffert
“Multiarea economic dispatch with tie line constraints ”
IEEE/PES Winter Meeting, 1995, WM 179 - 2.
3. C. Wang and S.M. Shahidehpour
“Power generation scheduling for multi area hydro - thermal systems with tie line constraints, cascaded reservoirs and uncertain data”
IEEE Trans., PAS , Vol. 08 , No. 3 , 1993 , pp. 1333 – 1340 .
4. O. Alsac and B. Stott
“Optimal power flow with steady - state security”
IEEE Trans., PAS , Vol. 93 , 1974 , pp. 745 – 751 .
Của bác nào thì vô lấy nha
Performance of multicarrier DS CDMA systems
http://www.mediafire.com/?gdgydi9fmxf1stp
Performance of orthogonal multicarrier CDMA in a multipath fading channel
http://www.mediafire.com/?ho1ahtowlxbahvh
Wide Area Protection—Technology and Infrastructures
http://www.mediafire.com/?bf3a24inrowag9a
A selective attention model for predicting visual attractors
http://www.mediafire.com/?ngnn9jq7m4j5dd0
Optimal Power Flow By Newton Approach
http://www.mediafire.com/?dtcaugflrf8tw38
Allocation of VAr support using LP and NLP based optimal power flows
http://www.mediafire.com/?wc43l7a2afva327
Optimal VAr planning by approximation method for recursive mixed-integer linear programming
http://www.mediafire.com/?lq7787ienk4f40b
http://www.mediafire.com/?xkh4e2m3kp6snh7
http://www.mediafire.com/?ww6zaw17xs8skhu
http://www.mediafire.com/?m80wczexqfo8zks
Optimal load flow with steady - state security
http://www.mediafire.com/?p9o2zx94lt75bfd
Một số ko lấy được thì mọi người chịu khó vô http://www.nghiencuusinh.org , đăng ký thành viên rồi gửi yêu cầu bài báo thì sẽ có các supplier cung cấp cho các bạn nếu họ có thể.==>
Làm ơn tải giúp mình một số tài liệu sau trên springerlink:
1. http://www.springerlink.com/content/p3297327j84l6714
2. http://www.springerlink.com/content/n83q4v412517p43x/
3. http://www.springerlink.com/content/q1kt88gm134bqmt6/
4. http://www.springerlink.com/content/q16211u52165m77h/
5. http://www.springerlink.com/content/f87p6hl37q426413/
6. http://www.springerlink.com/content/p1738046u7545878/
7. http://www.springerlink.com/content/hw2757514h311317/
8. http://www.springerlink.com/content/15777728n1321601/
9. http://www.springerlink.com/content/a6hap5b7x134a23b/
10. http://www.springerlink.com/content/15777728n1321601/
11. http://www.springerlink.com/content/3nhclwv9bcdj36m1/
Cám ơn các bác rất nhiều.
Mình ghi cả tên bài báo ra cho mọi người tiện theo dõi .Làm ơn tải giúp mình một số tài liệu sau trên springerlink:
1.A Hybrid Parallel Loop Scheduling Scheme on Grid Environments
http://www.mediafire.com/?phs4hlx062nz6i0
2.A Performance-Based Parallel Loop Self-scheduling on Grid Computing Environments
http://www.mediafire.com/?po0dt9cnl301b7p
3. Agent-Based Grid Computing
http://www.mediafire.com/?4drp32tfbwa75xd
4. An Agent-Based Approach for Scheduling Multiple Machines
http://www.mediafire.com/?v3umt5otr8nslom
5. Application of Genetic Algorithms to a Manufacturing Industry Scheduling Multi-Agent System
http://www.mediafire.com/?a8i9l9ik3vc02dt
6. Efficient Batch Job Scheduling in Grids Using Cellular Memetic Algorithms
http://www.mediafire.com/?63t96f8etz38itz
7. Performance Evaluation of a Grid Computing Architecture Using Realtime Network Monitoring
http://www.mediafire.com/?xc11podfo1l4m98
8. Resource and Job Monitoring in the Grid
http://www.mediafire.com/?va9zuolxal9syk0
9. Semantic Support for Meta-Scheduling in Grids
http://www.mediafire.com/?uq7kb7xy8yztosi
10. Using Genetic Algorithms and Heuristics for Job Shop Scheduling with Sequence-Dependent Setup Times
http://www.mediafire.com/?64756b1d5dci078==>
UP LAI HỘ EM CÁI NÀY VỚI
Chờ hồi lâu thì vẫn down được. Thôi mình đính kèm cho nhanh
Attached Files==>
Nhờ bạn load giúp mình các bài báo sau:
1.Distributed Self-Optimization of Handover for the Long Term Evolution
2.Uplink Power Control Performance in UTRAN LTE Networks
3.Avoid Unnecessary Handovers in a High Dense Environment
Cảm ơn rất nhiều!
anh giúp em down tài liệu này với
A CMOS low complexity Gaussian pulse generator for ultra wideband communications
Của bạn superman87:
http://www.mediafire.com/?kva5qki1v5i5pqs
http://www.mediafire.com/?w5b1p9b43q1jf7y
http://www.mediafire.com/?hyv38mvmkyig3u3
Của bạn xalembk:
http://www.mediafire.com/?re79wbjwr6k4u54==>
Đặt hàng & tư vấn
Hà Nội024.3640 8561
TP.HCM028.3811 9870
Hôm qua, 16:33 -
25-10-2026, 03:09 -
25-10-2026, 03:03 -
24-10-2026, 07:53 -
24-10-2026, 02:14 -
