xin hoi co bac nao biet cho nao ban con ads831 khong?gia bao nhieu?
can ic ADS831
ADS831EG4 — TEXAS INSTRUMENTS — IC, SM ADC 8-BITNguyên văn bởi maivu03 Xem bài viết136k/con hoi dat nhi
Manufacturer: TEXAS INSTRUMENTS
* IC, SM ADC 8-BIT
* Bits, No. of:8
* Channels, No. of:1
* Time, conversion:100µs
* Linearity error, ADC/DAC -:2LSB
* Linearity error, ADC/DAC +:2LSB
* Linearity error:2%
* Temp, op. max:85°C
* Temp, op. min:-40°C
* Pins, No. of:20
* Case style:SOIC
* A/D, D/A features:CMOS, Internal Reference, Parallel O/P, Track and Hold
* Base number:831
* Frequency, conversion:80MHz
* IC Generic number:831
* Interface type:Parallel
* Logic function number:831
* SMD:1
bac lấy đúng hàng của TI thi là 155k/1chu
Đặt hàng & tư vấn
Hà Nội024.3640 8561
TP.HCM028.3811 9870
Hôm qua, 16:33 -
25-10-2026, 03:09 -
25-10-2026, 03:03 -
24-10-2026, 07:53 -
24-10-2026, 02:14 -
