Giúp sửa lỗi chương trinh viết cho pic16f887
  • Giúp sửa lỗi chương trinh viết cho pic16f887
    Em dùng mplab x ide và mplab xc8
    Sẵn cho em hỏi cách đưa code lên diễn đàn, tìm cách post code trong diễn đàn mà chưa thấy.
    Cám ơn mọi người nhiều ạ.
    PHẦN CHƯƠNG TRÌNH
    #include<pic16f887.h>
    #include<xc.h>
    #include<stdio.h>
    #include<stdlib.h>
    // CONFIG1
    #pragma config FOSC = XT // Oscillator Selection bits (XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
    #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
    #pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
    #pragma config MCLRE = OFF // RE3/MCLR pin function select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD)
    #pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
    #pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
    #pragma config BOREN = OFF // Brown Out Reset Selection bits (BOR disabled)
    #pragma config IESO = OFF // Internal External Switchover bit (Internal/External Switchover mode is disabled)
    #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled)
    #pragma config LVP = OFF // Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming)
    // CONFIG2
    #pragma config BOR4V = BOR21V // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
    #pragma= OFF config WRT = OFF // Flash Program Memory Self Write Enable bits (Write protection
    #define _XTAL_FREQ 4000000
    void main (void)
    void port_init();
    void adc_init();
    void in_init();
    while(1){
    __delay_ms(10);
    GODONE = 1;
    void port_init(void){
    ANSEL = 0xO8;
    ANSELH = 0;
    TRISA2 = 1;
    TRISE = 0;
    PORTE = 0xff;
    void adc_init(){
    ADCON0bits.ADCS1 = 0;
    ADCON0bits.ADCS0 = 1;
    VCFG0 = 0;
    VCFG1 = 0;
    CHS3 = 0;
    CHS2 = 0;
    CHS1 = 1;
    CHS0 = 0;
    ADFM = 1;
    ADON = 1;
    __delay_ms(1);
    void in_init(){
    GIE = 1;
    PEIE = 1;
    ADIE = 1;
    ADIF = 0;
    void interrupt IRS(){
    int adc_result;
    if(PIE && ADIE && ADFE){
    if (adc_result> 818)
    PORTE=0b000; //Turn LEDs ON
    else if(adc_result> 613)
    PORTE=0b101;
    else if(adc_result> 409)
    PORTE=0b011;
    else if(adc_result> 204)
    PORTE=0b110;
    PHẦN LỖI
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory 'E:/dien/nhap_project16f/adc_bai1.X'
    make -f nbproject/Makefile-default.mk dist/default/production/adc_bai1.X.production.hex
    make[2]: Entering directory 'E:/dien/nhap_project16f/adc_bai1.X'
    "C:\Program Files (x86)\Microchip\xc8\v1.34\bin\xc8.exe" --pass1 --chip=16F877 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/adc.p1 adc.c
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1157 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1248)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1158 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1249)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1161 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1252)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1162 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1253)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1163 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1254)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1164 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_SIZE" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1255)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1165 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_LENGTH" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1256)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1166 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1257)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1172 : warning: (111) redefining preprocessor macro "_ADCON0_GO_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1263)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1173 : warning: (111) redefining preprocessor macro "_ADCON0_GO_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1264)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1176 : warning: (111) redefining preprocessor macro "_ADCON0_GO_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1267)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1177 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1268)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1178 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1269)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1181 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1272)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1182 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1273)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1183 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1274)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1186 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1277)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1187 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1278)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1188 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1279)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1191 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1282)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1202 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1298)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1203 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1299)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1206 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1302)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1207 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1303)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1208 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1304)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1211 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1307)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2225 : warning: (111) redefining preprocessor macro "CHS0_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3655)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2227 : warning: (111) redefining preprocessor macro "CHS1_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3657)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2229 : warning: (111) redefining preprocessor macro "CHS2_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3659)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2259 : warning: (111) redefining preprocessor macro "GO_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3709)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2261 : warning: (111) redefining preprocessor macro "GO_DONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3711)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2263 : warning: (111) redefining preprocessor macro "GO_nDONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3713)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2591 : warning: (111) redefining preprocessor macro "nDONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 4213)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2224 : error: (1098) conflicting declarations for variable "CHS0" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2224 )
    (908) exit status = 1
    nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/adc.p1' failed
    make[2]: Leaving directory 'E:/dien/nhap_project16f/adc_bai1.X'
    nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
    make[1]: Leaving directory 'E:/dien/nhap_project16f/adc_bai1.X'
    make[2]: *** [build/default/production/adc.p1] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
    BUILD FAILED (exit value 2, total time: 1s)
    Chỉ cần duy nhất dòng #include là đủ, bỏ 3 dòng #include còn lại đi. Chú ý có khoảng trắng giữa chỉ thị #include và tên tệp.
      #include <pic16f887.h>
      thế là đủ. #inculde [dấu cách] <tên tệp >
      Module RF chuyên dụng điều khiển, truyền dữ liệu, thiết kế các loại đề tài, dự án điện tử - chuyển giao công nghệ... website: http://rfvn.tk ĐT: 090 496 4977
        1. Em cám ơn, e đã sửa được một số lỗi, em đang tự học con pic này, giải thích giúp em tại sao ta phải bỏ 3 dòng lệnh đó vậy, những bài tập trước em làm không bỏ 3 dòng đó chương trình vẫn không bị lỗi.
        2. Chương trình còn 1 số lỗi, khi em nhấp vô nó không báo lỗi ở chương trình mà hiện ra file mới: Makefile-default.mk, Makefile-impl.mk. Chương trình bị sao vậy ạ? Em phải sửa thế nào?
        Em cám ơn mọi sự hỗ trợ của mọi người nhiều ạ.
          - 2 dòng include cuối của bạn ko cần thiết vì bộ nhớ của PIC nhỏ (ko như PC), ít khi dùng các hàm printf hay scanf...
          - 2 dòng include đầu chỉ cần 1 trong 2, mình thường chọn xc.h. Vì khi bạn setup project đã chọn 1 con PIC, include xc.h có chức năng tương tự như include picxxx.h. Mình thường chọn xc.h, chừng nào trình dịch ko nhận ra con PIC mình sẽ include như 2 bác ở trên.
          - Hồi trước cũng gặp lỗi này, check con PIC cũng ko phải PIC mới. Bạn thử cài compiler cũ hoặc mới hơn xem thế nào.
          - Còn về chương trình, nhìn vào hàm ngắt thì thấy chắc khó mà chạy đúng như ý muốn, cái này fix từ từ bằng code sau
          - Cái CONFIG1 của bạn là dùng crystal ngoài 4MHz (thấy define là 4MHz) à? Có nhầm lẫn gì ko? 4MHz thì bằng xung nội xài thạch anh làm chi?
            Nguyên văn bởi chanhmuoi Xem bài viết
            #include dùng để khai báo sử dụng tên file header ( chứa các định nghĩa, tên hàm ... ) mà sẽ cần phải dùng.
            Nếu không cần đến header thì không nên include nó, vừa gây chậm biên dịch + không có tác dụng + có thể gây lỗi không mong muốn.
            2 cái cuối không dùng nên không include, cái thứ 1 và thứ 2 chỉ dùng 1 cái ( cái xc.h không nên dùng ).
              Vì sao ko nên dùng xc.h vậy bạn?
                  Nguyên văn bởi htc2k14 Xem bài viết
                  Em dùng bộ dao động thạch anh, do em xem mấy video trên youtube đa số dùng bộ dao động ngoại nên e dùng theo, chứ chưa hiểu sâu, anh có tài liệu vi xử lí gì hay share qua mail cho e với, e đang tự học.
                  mail: anhvan1608@gmail.com
                  chanhmuoi Tìm hiểu thêm về chanhmuoi
                  • dtgjau
                    [Hỏi] Quấn dây máy phát điện 1pha như thê nào ra điện mạnh ạ.
                    dtgjau
                    Mình chỉ mới tập tành quấn. Của zin là nóa quấn 72vòng dây, dây 0,7mm. Mình quấn lại 100vòng, dây 1mm nhưng điện ra vẫn chưa mạnh.
                    Mình muốn hỏi là dùng dây nhỏ quấn ít vòng hay làm sao cho nóa mạnh ạ. Đính chính là 1pha nha ae.
                    hôm nay, 07:34
                  • trthnguyen
                    Trả lời cho [Hỏi] Quấn dây máy phát điện 1pha như thê nào ra điện mạnh ạ.
                    trthnguyen
                    "Điện mạnh" là một khái niệm chung chung, mơ hồ. Bạn cần mạnh về cái gì? Điện áp, dòng hay công suất?
                    Quấn nhiều vòng hơn thì điện áp mạnh hơn, nhưng để quấn được nhiều vòng thì phải dùng dây cỡ...
                    hôm nay, 09:03
                  • TP_Electro
                    Trả lời cho TỰ LÀM 600W PURESINE INVERTER 12VDC - 220VAC (Mở lại chủ đề của thanhfdc bị xóa nhầm)
                    TP_Electro
                    OK, Bác nào đặt gach test thì xác nhận nha! Mình thì chỉ cần 1 bo để test firmware. Bác dinhthuong80 1 bo, bác havansony 5 bo. còn 3 bo nữa! bác nào có cảm hứng thì lượm luôn. Mình thêm bo nữa cũng đc!
                    hôm nay, 08:39
                  • Quocthaibmt
                    Trả lời cho SONY . Tập hợp các vấn đề về màn hình màu SONY
                    Quocthaibmt
                    điện áp Vcc IC vert đến 30v thì bạn sửa lại phần nguồn cho trở lại 24v rồi tính tiếp , chứ áp cao vậy thì IC không chạy hoặc có thể bị hư luôn ....
                    hôm nay, 08:14
                  • owncity065
                    [Hỏi đáp] Thiết bị phát âm thanh đơn giản
                    owncity065
                    Chào mọi người. Mình là dân CNTT cũng mò mò sơ sơ về lập trình cho atmega (Chạy led, LCD, Ma trận phím,...). Nay mình có ý tưởng làm một thiết bị cầm tay đơn giản, thiết bị có 4 nút, khi bấm mỗi nút thì sẽ phát ra 1 file wav được lưu trong...
                    Hôm qua, 22:58
                  • Tranhieu85
                    Tranhieu85
                    Chào các bác . Xin các bác giúp em tivi sam slim 21da x99 bị lằn sáng ngang . Em đã thay mấy tụ hóa , thay ic la 78040 ktra các r , thay nhớ rồi mà ko ra . Em đo tại chân v out của vxl có 3v . Nhưng sao diện áp tại chân vcc của ic vert đến 30v . Em cũng...
                    Hôm qua, 22:32
                  • kythuatmd
                    Nguồn Adapter
                    kythuatmd
                    Mình có 2 loại adapter nguồn xung Blayback công suất đầu ra 5w ( 5V-1A). Mình muốn chuyển điện áp ra thành 12V (12V-1A) hoặc (12V-1,2A) thì làm cách nào đơn giản nhất. Mong các bạn trên diễn đàn tư vấn giúp ( có file gồm 2 mạch nguồn chi tiết kèm...
                    Hôm qua, 11:15
                  • kythuatmd
                    Trả lời cho Nguồn Adapter
                    kythuatmd
                    cảm ơn các thành viên nha! bây giờ mình bắt đầu thực hiện mọi phương án, có kết quả như thế nào sẽ thi tin trên diễn đàn sau.
                    Hôm qua, 20:25
                  • thanhfdc
                    Trả lời cho Mạch sạc accu 3 giai đoạn từ nguồn ATX
                    thanhfdc
                    Nó là mạch so sánh đảo. Chân + nối GND , chân - phân áp từ Vref với áp âm về từ shunt. Khi dòng nhỏ thì điện áp chân 2 ở mức cao. Đầu ra ở mức thấp. Khi dòng lớn, áp âm ở chân shunt về cao lên, sẽ làm giảm dần áp trên chân -. Khi áp...
                    Hôm qua, 17:46
                  • vandoan
                    Trả lời cho amply class A 100W
                    vandoan
                    krell chế độ class AB
                    Hôm qua, 17:29
