Hi bác Rommel.de,
Em đã làm theo những chỉ dẫn của bác như sau:
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# ifconfig
eth0 Link encap:Ethernet HWaddr f4:ce:46:2e:9b:29
inet addr:192.168.194.131 Bcast:192.168.194.191 Mask:255.255.255.192
inet6 addr: fe80::f6ce:46ff:fe2e:9b29/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:158613 errors:0 dropped:0 overruns:0 frame:0
TX packets:96558 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:114448196 (114.4 MB) TX bytes:14208934 (14.2 MB)
Interrupt:43 Base address:0xc000
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# wine ./MentorKG.exe -i calibre.txt -h f4:ce:46:2e:9b:29 -o license.dat
calibre.txt:line 1:Invalid parameter (-42,298)
calibre.txt:line 1: "FEATURE mgc_s mgcld 2021.040 13-apr-2021 0 4D8C96FD4B5D1C1877F0 " ..."
Hostid required for uncounted feature
Invalid license file syntax (-2,269)
( bị lỗi này đến tân line cuối là line 57)
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# export MGC_HOME=/usr/local/cadence/Calibre_setup/ixl_cal_2009.1_46.27
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# export PATH=$PATH:$MGC_HOME/bin
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# export LM_LICENSE_FILE=/usr/local/cadence/Calibre_setup/license.dat
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# calibre -gui &
[1] 5847
root@ubuntu:/usr/local/cadence/Calibre_setup/dft_calibrelicgen# WARNING: This version of Linux is not qualified for use with Calibre products.
WARNING: Ubuntu 10.10 \n \l
/usr/local/cadence/Calibre_setup/ixl_cal_2009.1_46.27/pkgs/icv/pvt/cgi_app: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory "
Với lỗi này em không biết là do mình tạo file license.dat chưa đúng hay là phiên bản của Ubuntu không phù hợp với Calibre?
Bác chỉ giáo cho em với!
Trân trọng,
[1] 5847
Trân trọng,
