Quartus không báo lỗi nhưng chạy không ra kết quả
  • nguyenchipon
    Thành viên mới
    • Sep 2008
    • 10
    Code:
    module chia(A, B, Q, S, Y);
     input [15:0] A;
     input [7:0] B;
     output [7:0] Q, S, Y;
     reg [7:0] Q, S, Y,  D;
     reg [15:0] temps, temp, not_B, temp1;
     integer j;
     always @ ( A or B)
      begin
        begin
      D = ~B;
      temp = B<<8;
      not_B = D <<8;
      temps = A <<1;
        end
         for (j = 7 ; j >= 0; j = j- 1)
          begin
            begin
           temp1 = temps <<1;
           Y = temp1 > temp;
             end
           if ( Y==1)
               begin
                    Q[j] = 1'b1;
                    temps = temps + not_B;
                end
            else
                begin
                     Q[j] = 1'b0;
                     temps = temps <<1;
                end
                S[7:0] = temps>>8;
           end
      end
      endmodule
    quartus đưa ra warning như thế này
    Code:
    Info: Running Quartus II Analysis & Synthesis
    	Info: Version 9.0 Build 235 06/17/2009 Service Pack 2 SJ Web Edition
    	Info: Processing started: Thu Dec 03 13:05:06 2009
    Info: Command: quartus_map --read_settings_files=on --write_settings_files=off chia -c chia
    Info: Found 1 design units, including 1 entities, in source file chia.v
    	Info: Found entity 1: chia
    Info: Elaborating entity "chia" for the top level hierarchy
    Warning (10230): Verilog HDL assignment warning at chia.v(34): truncated value with size 16 to match size of target (8)
    Warning: Output pins are stuck at VCC or GND
    	Warning (13410): Pin "Y[1]" is stuck at GND
    	Warning (13410): Pin "Y[2]" is stuck at GND
    	Warning (13410): Pin "Y[3]" is stuck at GND
    	Warning (13410): Pin "Y[4]" is stuck at GND
    	Warning (13410): Pin "Y[5]" is stuck at GND
    	Warning (13410): Pin "Y[6]" is stuck at GND
    	Warning (13410): Pin "Y[7]" is stuck at GND
    Warning: Design contains 1 input pin(s) that do not drive logic
    	Warning (15610): No output dependent on input pin "A[15]"
    Info: Implemented 306 device resources after synthesis - the final resource count might be different
    	Info: Implemented 24 input pins
    	Info: Implemented 24 output pins
    	Info: Implemented 258 logic cells
    Info: Quartus II Analysis & Synthesis was successful. 0 errors, 11 warnings
    	Info: Peak virtual memory: 176 megabytes
    	Info: Processing ended: Thu Dec 03 13:05:10 2009
    	Info: Elapsed time: 00:00:04
    	Info: Total CPU time (on all processors): 00:00:05
    Info: *******************************************************************
    Info: Running Quartus II Fitter
    	Info: Processing started: Thu Dec 03 13:05:12 2009
    Info: Command: quartus_fit --read_settings_files=off --write_settings_files=off chia -c chia
    Info: Selected device EP2C5F256C8 for design "chia"
    Info: Low junction temperature is 0 degrees C
    Info: High junction temperature is 85 degrees C
    Info: Fitter is performing an Auto Fit compilation, which may decrease Fitter effort to reduce compilation time
    Warning: Feature LogicLock is not available with your current license
    Info: Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices
    	Info: Device EP2C5F256I8 is compatible
    	Info: Device EP2C5AF256I8 is compatible
    	Info: Device EP2C8F256C8 is compatible
    	Info: Device EP2C8F256I8 is compatible
    	Info: Device EP2C8AF256I8 is compatible
    Info: Fitter converted 3 user pins into dedicated programming pins
    	Info: Pin ~ASDO~ is reserved at location C3
    	Info: Pin ~nCSO~ is reserved at location F4
    	Info: Pin ~LVDS41p/nCEO~ is reserved at location N14
    Warning: No exact pin location assignment(s) for 48 pins of 48 total pins
    	Info: Pin A[15] not assigned to an exact location on the device
    	Info: Pin Q[0] not assigned to an exact location on the device
    	Info: Pin Q[1] not assigned to an exact location on the device
    	Info: Pin Q[2] not assigned to an exact location on the device
    	Info: Pin Q[3] not assigned to an exact location on the device
    	Info: Pin Q[4] not assigned to an exact location on the device
    	Info: Pin Q[5] not assigned to an exact location on the device
    	Info: Pin Q[6] not assigned to an exact location on the device
    	Info: Pin Q[7] not assigned to an exact location on the device
    	Info: Pin S[0] not assigned to an exact location on the device
    	Info: Pin S[1] not assigned to an exact location on the device
    	Info: Pin S[2] not assigned to an exact location on the device
    	Info: Pin S[3] not assigned to an exact location on the device
    	Info: Pin S[4] not assigned to an exact location on the device
    	Info: Pin S[5] not assigned to an exact location on the device
    	Info: Pin S[6] not assigned to an exact location on the device
    	Info: Pin S[7] not assigned to an exact location on the device
    	Info: Pin Y[0] not assigned to an exact location on the device
    	Info: Pin Y[1] not assigned to an exact location on the device
    	Info: Pin Y[2] not assigned to an exact location on the device
    	Info: Pin Y[3] not assigned to an exact location on the device
    	Info: Pin Y[4] not assigned to an exact location on the device
    	Info: Pin Y[5] not assigned to an exact location on the device
    	Info: Pin Y[6] not assigned to an exact location on the device
    	Info: Pin Y[7] not assigned to an exact location on the device
    	Info: Pin B[7] not assigned to an exact location on the device
    	Info: Pin B[6] not assigned to an exact location on the device
    	Info: Pin A[13] not assigned to an exact location on the device
    	Info: Pin B[5] not assigned to an exact location on the device
    	Info: Pin A[12] not assigned to an exact location on the device
    	Info: Pin B[4] not assigned to an exact location on the device
    	Info: Pin A[11] not assigned to an exact location on the device
    	Info: Pin B[3] not assigned to an exact location on the device
    	Info: Pin A[10] not assigned to an exact location on the device
    	Info: Pin B[2] not assigned to an exact location on the device
    	Info: Pin A[9] not assigned to an exact location on the device
    	Info: Pin B[1] not assigned to an exact location on the device
    	Info: Pin A[8] not assigned to an exact location on the device
    	Info: Pin B[0] not assigned to an exact location on the device
    	Info: Pin A[7] not assigned to an exact location on the device
    	Info: Pin A[6] not assigned to an exact location on the device
    	Info: Pin A[5] not assigned to an exact location on the device
    	Info: Pin A[3] not assigned to an exact location on the device
    	Info: Pin A[4] not assigned to an exact location on the device
    	Info: Pin A[2] not assigned to an exact location on the device
    	Info: Pin A[1] not assigned to an exact location on the device
    	Info: Pin A[0] not assigned to an exact location on the device
    	Info: Pin A[14] not assigned to an exact location on the device
    Info: Fitter is using the Classic Timing Analyzer
    Info: Timing requirements not specified -- quality metrics such as performance and power consumption may be sacrificed to reduce compilation time.
    Info: Starting register packing
    Info: Finished register packing
    	Extra Info: No registers were packed into other blocks
    Info: Statistics of I/O pins that need to be placed that use the same VCCIO and VREF, before I/O pin placement
    	Info: Number of I/O pins in group: 48 (unused VREF, 3.3V VCCIO, 24 input, 24 output, 0 bidirectional)
    		Info: I/O standards used: 3.3-V LVTTL.
    Info: I/O bank details before I/O pin placement
    	Info: Statistics of I/O banks
    		Info: I/O bank number 1 does not use VREF pins and has undetermined VCCIO pins. 2 total pin(s) used --  33 pins available
    		Info: I/O bank number 2 does not use VREF pins and has undetermined VCCIO pins. 0 total pin(s) used --  43 pins available
    		Info: I/O bank number 3 does not use VREF pins and has undetermined VCCIO pins. 1 total pin(s) used --  38 pins available
    		Info: I/O bank number 4 does not use VREF pins and has undetermined VCCIO pins. 0 total pin(s) used --  41 pins available
    Info: Fitter preparation operations ending: elapsed time is 00:00:01
    Info: Fitter placement preparation operations beginning
    Info: Fitter placement preparation operations ending: elapsed time is 00:00:00
    Info: Fitter placement operations beginning
    Info: Fitter placement was successful
    Info: Fitter placement operations ending: elapsed time is 00:00:00
    Info: Fitter routing operations beginning
    Info: Average interconnect usage is 1% of the available device resources
    	Info: Peak interconnect usage is 2% of the available device resources in the region that extends from location X14_Y0 to location X28_Y14
    Info: Fitter routing operations ending: elapsed time is 00:00:00
    Info: The Fitter performed an Auto Fit compilation.  Optimizations were skipped to reduce compilation time.
    	Info: Optimizations that may affect the design's routability were skipped
    	Info: Optimizations that may affect the design's timing were skipped
    Info: Started post-fitting delay annotation
    Warning: Found 24 output pins without output pin load capacitance assignment
    	Info: Pin "Q[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[4]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[5]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[6]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Q[7]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[4]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[5]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[6]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "S[7]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[4]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[5]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[6]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    	Info: Pin "Y[7]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
    Info: Delay annotation completed successfully
    Warning: Following 7 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results
    	Info: Pin Y[1] has GND driving its datain port
    	Info: Pin Y[2] has GND driving its datain port
    	Info: Pin Y[3] has GND driving its datain port
    	Info: Pin Y[4] has GND driving its datain port
    	Info: Pin Y[5] has GND driving its datain port
    	Info: Pin Y[6] has GND driving its datain port
    	Info: Pin Y[7] has GND driving its datain port
    Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
    Info: Quartus II Fitter was successful. 0 errors, 5 warnings
    	Info: Peak virtual memory: 198 megabytes
    	Info: Processing ended: Thu Dec 03 13:05:16 2009
    	Info: Total CPU time (on all processors): 00:00:03
    Em là người mới học verilog, đang làm về thủ thuật chia 2 số có dấu, em định làm thử chia 2 số không dấu trước nhưng mà mãi không được, mong các anh ( chị ) đi truóc giúp em với!!! Em đang chật vật tìm hiểu lỗi trên mà không tìm ra, mong được các anh ( chị ) giúp đỡ
  • it4rb
    Thành viên chính thức
    • Jun 2008
    • 97
    Mình mù Verilog nhưng nhìn cái warning thì thấy bạn đã sai chỗ cái Y nên nó mới báo là stuck at GND (nghĩa là mấy cái đó luôn ở mức 0). Không biết bên verilog thì sao chứ mình xài VHDL thì ít khi xài vòng for để tính toán lắm, chủ yếu dùng để duplicate các component thôi, bạn thử xài kiểu khác xem sao nhá.
    Trước tiên thì bạn nêu rõ mục đích của bạn là gì đã, sau đó phác họa sơ sơ ra cái cấu trúc phần cứng rồi hãy code, chứ nhìn code bạn thấy hơi hơi giống code bên phần mềm đó
    Chuyện nhỏ như con thỏ,bắt thỏ mới là chuyện lớn!!!
    • nguyenchipon
      Thành viên mới
      • Sep 2008
      • 10
      Cảm ơn bạn đã góp ý, để mình thử sửa lại cách khác xem sao !!! Các anh chị góp ý dùm em chỗ Q và S không có giá trị khi chạy, em đã chạy đoạn code giống như vòng for nó vẫn ra giá trị bình thường mà
      • phuongnhoc
        • Mar 2006
        • 122
        #4
        Theo kiên thì bạn viết code vậy sẽ gặp rất nhiều bug.
        Cần chú ý code verilog khác với code C. Bạn lồng quá nhiều khối begin ... end lại với nhau. Nên nhớ chúng ta đang thiết kế phần cứng chứ không phải lập trình C. Phần cứng thì không chạy từng dòng lệnh. Mà thay đổi trạng thái sau mỗi chu kỳ xung clocK.
        Muốn thiết kế phần cứng trước hết cần hình dung được hệ thống cần thiết kế, các khối chức năng, các tín hiệu, các trạng thái điều khiển.
        Có thể những điều mình nói trên sẽ không giúp ích gì cho bạn lúc này. Nhưng code thêm 6 tháng tới một năm bạn sẽ hiểu được.
        Thân chào
        Hehe Post xong mới phát hiện ra ý mình giống với ý của it4rb.
        Hihi sorry nhé
        • danbeo85
          • Jul 2007
          • 90
          #5
          Một lưu ý nhỏ khi viết code cho FPGA là việc dùng vòng lặp "for"; vòng lặp này sẽ hữu dụng khi tạo hệ thống tự động trong verilog 2001 nhưng nên hạn chế (nếu không muốn nói là không nên dùng) khi mô tả một module đơn lẽ. Trong Quartus, sô lần lặp có giới hạn, hình như là 5000 (không nhớ rõ lắm). Khi vượt quá giới hạn đó sẽ không thể tổng hợp được. (Xem thêm Quartus HandBook).
          .^_^.
          nguyenchipon Tìm hiểu thêm về nguyenchipon
