This program was produced by the
CodeWizardAVR V2.03.4 Standard
Automatic Program Generator
© Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
HP InfoTech - CodeVisionAVR C Compiler
Project :
Version :
Date : 21/10/2013
Author :
Company :
Comments:
Chip type : ATmega16
Program type : Application
Clock frequency : 4.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega16.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=1
PORTD=0x01;
DDRD=0xFF;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
Value[]={8,15,23,30,38,45,52,59,65,70,76,81,85,89,92,95,9 7,98,99,100,99,98,97,95,92,89,85,81,76,70,65,59,52 ,45,38,30,23,15,8};
//song sin dau ra chua duoc chuan: sua lai chuoi value[] la ok
while (1)
// Place your code here
OCR1A=0;
OCR1B=0;
delay_us(250);
for(i=0;i<=38;i++)
OCR1B=Value[i];
delay_us(250);
OCR1B=0;
OCR1A=0;
delay_us(250);
for(i=0;i<=38;i++)
OCR1A=Value[i];
delay_us(250);
Chả là em làm sóng sin cho inverter. Sao buil nó cứ báo lỗi chỗ này các bác ak.
Project :
Version :
Date : 21/10/2013
Author :
Company :
Comments:
#include <mega16.h>
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0xFF;
PORTD=0x01;
DDRD=0xFF;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
ACSR=0x80;
SFIOR=0x00;
while (1)
OCR1A=0;
OCR1B=0;
delay_us(250);
for(i=0;i<=38;i++)
OCR1B=Value[i];
delay_us(250);
OCR1B=0;
OCR1A=0;
delay_us(250);
for(i=0;i<=38;i++)
OCR1A=Value[i];
delay_us(250);
