vấn đề về pwm trong avr(atmega32)
  • maithuatri
    • Feb 2009
    • 11
    Em muốn tạo xung pwm trong avr để điều khiển động cơ dc. Em có đoạn code sau nhưng em chưa hiểu được công dụng của các lệnh. Mong các bác giúp em với:
    This program was produced by the
    CodeWizardAVR V2.04.1 Evaluation
    Automatic Program Generator
    © Copyright 1998-2009 Pavel Haiduc, HP InfoTech s.r.l.
    CodeVisionAVR C Compiler for Atmel AVR microcontrollers
    Project :
    Version :
    Date : 6/12/2009
    Author : Freeware, for evaluation and non-commercial use only
    Company :
    Comments:
    Chip type : ATmega32
    Program type : Application
    AVR Core Clock frequency: 8.000000 MHz
    Memory model : Small
    External RAM size : 0
    Data Stack size : 512
    #include <mega32.h>
    // Timer 0 overflow interrupt service routine
    interrupt [TIM0_OVF] void timer0_ovf_isr(void)
    // Place your code here
    // Timer 0 output compare interrupt service routine
    interrupt [TIM0_COMP] void timer0_comp_isr(void)
    // Declare your global variables here
    void main(void)
    // Declare your local variables here
    // Input/Output Ports initialization
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=Out Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=0 State2=T State1=T State0=T
    PORTB=0x00;
    DDRB=0x08;
    // Port C initialization
    PORTC=0x00;
    DDRC=0x00;
    // Port D initialization
    // Func7=Out Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
    // State7=0 State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
    PORTD=0x00;
    DDRD=0xB0;
    // Timer/Counter 0 initialization
    // Clock source: System Clock
    // Clock value: 125.000 kHz
    // Mode: Phase correct PWM top=FFh
    // OC0 output: Inverted PWM
    TCCR0=0x73;
    TCNT0=0x00;
    OCR0=0x7f;
    // Timer/Counter 1 initialization
    // Clock value: 31.250 kHz
    // Mode: Fast PWM top=03FFh
    // OC1A output: Inverted
    // OC1B output: Non-Inv.
    // Noise Canceler: Off
    // Input Capture on Falling Edge
    // Timer 1 Overflow Interrupt: Off
    // Input Capture Interrupt: Off
    // Compare A Match Interrupt: Off
    // Compare B Match Interrupt: Off
    TCCR1A=0xE3;
    TCCR1B=0x0C;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x08;
    OCR1AL=0xe2;
    OCR1BH=0x0f;
    OCR1BL=0x0f;
    // Timer/Counter 2 initialization
    // Clock value: 7.813 kHz
    // Mode: Fast PWM top=FFh
    // OC2 output: Non-Inverted PWM
    ASSR=0x00;
    TCCR2=0x6F;
    TCNT2=0x00;
    OCR2=0x00;
    // External Interrupt(s) initialization
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    // Timer(s)/Counter(s) Interrupt(s) initialization
    TIMSK=0x03;
    // Analog Comparator initialization
    // Analog Comparator: Off
    // Analog Comparator Input Capture by Timer/Counter 1: Off
    ACSR=0x80;
    SFIOR=0x00;
    // Global enable interrupts
    #asm("sei")
    while (1)
    Các bác có thể hướng dẫn cho em thêm cách khởi tạo pwm trong timer0, tại nó có nhiều lựa chọn mà em lại quá gà để có thể hiểu được. Em cảm ơn các bác nhiều.
  • enter88
    • Nov 2008
    • 238
    bạn đọc datasheet của nó ý ,khá chi tiết
    • maithuatri
      • Feb 2009
      • 11
      Nguyên văn bởi enter88 Xem bài viết
      mà bạn có datasheet của atmega32 bằng tiếng việt ko? chứ tiếng anh em còn tệ lắm. Thank bạn!
      • zinix
        • Apr 2009
        • 61
        Các thông số thiết lập trong timer0 như sau:
        -Clock source: chon clock của hệ thống hay từ pin TOSC1.
        -Clock value: giá trị cho bộ đếm timer0
        -Mode:
        *Normal mode: chế độ timer bình thường đếm từ 0-0xFF
        *Phase correct PWM top va Fast PWM: chạy timer và khởi tạo xung PWM, so sánh gia trị timer với OCR0 rồi xuất ra PWM (nếu chọn output PWM) và có thể tạo ra output compare interrupt..
        * CTC: ở chế độ này khi timer0 đếm đến giá trị cua OCR0 thì bộ đếm reset về 0 trở lại.
        -Output:
        *disconnect: ko kết nối.
        * toggle: lật
        * set, clear: lên mức 1 hoặc xuống mức 0 khi co sự kiện ngắt.
        * Non-inverted PWM: chân OCR0 xuất tín hiệu như sau: bằng 1 từ giá trị 0x00 dến gia trị OCR0, bằng 0 từ OCR0 đến 0xFF
        * Inverted PWM: ngược lại với cái ở trên
        Các thông số còn lại chắc dễ hiểu. Khuyên bạn cố gắng đọc tiếng Anh, từ từ sẽ quen,tài liệu tiếng Việt ít và ko chuẩn bằng..Nhiều khi đọc tiếng Anh dễ hiểu hơn tiếng Việt đấy
        • kkkk
          • Apr 2007
          • 434
          Nguyên văn bởi maithuatri Xem bài viết
          DATA sheet bạn cứ tập đọc bằng tiếng anh đi dần dần mới quen chứ
          hầu hết đều là bằng tiếng anh thôi.
          • votuananhs
            • Jul 2007
            • 43
            đọc datasheet thì cũng ra vẫn đề thật nhưng mà đây là mẫu tạo ra trong phần mềm CodeWizardAVR các bác giả thích cho maithuatri đi.
            • votinh_kt
              • Sep 2008
              • 292
              PMW bạn nên dùng time 1 , ok
              • maithuatri
                • Feb 2009
                • 11
                #8
                Nguyên văn bởi zinix Xem bài viết
                -Mode:
                -Output:
                * toggle: lật
                ok. thanhk các bạn nhiêu. Để mình cố gắng cày một thời gian xem sao. Hi vọng là mình ko còn gà nữa.....
                • daihoa
                  • Aug 2008
                  • 53
                  #9
                  bạn đọc tài liệu này nhe. rất dễ hiểu
                  Search, download and share files from 4shared: music, video, images, books, apk. Use advanced search filters to find favorite songs, video clips and mobile apps.
                  maithuatri Tìm hiểu thêm về maithuatri
