Xin giúp đỡ sửa code asm.. Cần lắm các huynh ơi.
  • buiviettrung
    • Feb 2012
    • 39
    E CÓ CODE MẠCH ĐÈN GIAO THÔNG LẤY TRÊN DIỄN ĐÀN NHƯ THẾ NÀY. E NHỜ AI SỬA MÔT CHÚT LÀM SAO CHO ĐÈN ĐỎ NHẤP NHÁY 1 VÀI S TRƯỚC KHI CHUYỂN SANG ĐÈN XANH ( như ở ngoài đường ấy ) Và cái thời gian code này chạy chậm hơn thời gian thực 1 ít ( 3s trong code = 4,5 s thực) . ai sửa hộ e cái. cần lắm. vì e ko biết về code.
    DEM EQU R2
    DEM1 EQU R3
    DEM2 EQU R4
    XANH EQU 16H
    VANG EQU 17H
    DO EQU 18H
    ORG 000
    JMP MAIN
    ORG 0BH
    MOV TH0,3CH
    MOV TL0,0B0H
    INC DEM
    RETI
    MAIN: MOV TMOD,#01
    MOV TH0,#3CH
    MOV TL0,#0B0H
    CLR TF0
    SETB TR0
    MOV IE,#82H
    TD: MOV P1,#21H
    MOV XANH,#17
    MOV VANG,#3
    MOV DO,#20
    MOV DEM1,XANH
    MOV DEM2,DO
    H1: MOV DEM,#0
    LCALL BCD_HEX
    LB1: LCALL HIEN_THI
    CJNE DEM,#20,lb1
    DEC DEM1
    DEC DEM2
    CJNE DEM1,#0,H1
    MOV P1,#22H
    MOV DEM1,VANG
    H2: MOV DEM,#0
    LCALL BCD_HEX
    LB2: LCALL HIEN_THI
    CJNE DEM,#20,LB2
    DEC DEM1
    DEC DEM2
    CJNE DEM1,#-1,H2
    MOV P1,#0CH
    MOV DEM1,DO
    MOV DEM2,XANH
    H3: MOV DEM,#0
    LCALL BCD_HEX
    LB3: LCALL HIEN_THI
    CJNE DEM,#20,LB3
    DEC DEM1
    DEC DEM2
    CJNE DEM2,#0,H3
    MOV P1,#14H
    MOV DEM2,VANG
    H4: MOV DEM,#0
    LCALL BCD_HEX
    LB4: LCALL HIEN_THI
    CJNE DEM,#20,LB4
    DEC DEM1
    DEC DEM2
    CJNE DEM2,#-1,H4
    JMP TD
    BCD_HEX:MOV A,DEM1
    MOV B,#10
    DIV AB
    MOV 12H,A
    MOV 13H,B
    MOV A,DEM2
    MOV B,#10
    DIV AB
    MOV 14H,A
    MOV 15H,B
    RET
    HIEN_THI:MOV DPTR,#500H
    MOV A,12H
    MOVC A,@A+DPTR
    MOV P2,A
    MOV P3,#0FEH
    LCALL DELAY
    MOV P3,#0FFH
    MOV A,13H
    MOVC A,@A+DPTR
    MOV P2,A
    MOV P3,#0FDH
    LCALL DELAY
    MOV P3,#0FFH
    MOV A,14H
    MOVC A,@A+DPTR
    MOV P2,A
    MOV P3,#0FBH
    LCALL DELAY
    MOV P3,#0FFH
    MOV A,15H
    MOVC A,@A+DPTR
    MOV P2,A
    MOV P3,#0F7H
    LCALL DELAY
    MOV P3,#0FFH
    DELAY: MOV R6,#150
    DEL1: DJNZ R6,DEL1
    RET
    ORG 500H
    DB 0C0H,0F9H,0A4H,0B0H,099H,092H,082H,0F8H,080H,090H
    END
    Tokyo Driff
  • buiviettrung
    • Feb 2012
    • 39
    code này đèn đỏ là 21s nhưng mạch thật nó chạy tầm 26s. mọi ng giúp e cái nhé.
    Tokyo Driff
    • buiviettrung
      • Feb 2012
      • 39
      Tokyo Driff
      • buiviettrung
        • Feb 2012
        • 39
        on top nowwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
        Tokyo Driff
        • buiviettrung
          • Feb 2012
          • 39
          Tokyo Driff
          • phongcachya
            • Mar 2011
            • 14
            đầu tư dữ nhỉ. Bạn nếu viết được code thì sửa như ý bạn rất dễ mà.
            • buiviettrung
              • Feb 2012
              • 39
              cái code này lấy trên diễn đàn mà. m ko viết đc code. ai biết sửa jum cái. thanks
              Tokyo Driff
              • buiviettrung
                • Feb 2012
                • 39
                #8
                đang nghiên cứu các câu lệnh asm . nhưng vẫn dốt lắm. bác nào jusp e hướng dẫn qua 1 chút thôi cũng đc
                Tokyo Driff
                • ksclc07i
                  • Jul 2011
                  • 44
                  #9
                  Bác đăng kí cái tài khoản miễn phí trên medaifire.com đi, rồi có gì hay up lên đó rồi share link cho anh em ok ngay.
                  buiviettrung Tìm hiểu thêm về buiviettrung
