Cần giúp đỡ về Led matrix
  • vietthanh123
    • Mar 2011
    • 479
    Em đi thẳng vào vấn đề luôn nhé.
    Em có chương trình hiện thị chữ bằng ma trận led 8x8 (Lấy từ http://lab3i.com/). Tuy nhiên có vài dòng lệnh em chưa hiểu đựơc. Rất mong các bác trên diễn đàn giải thích chi tiết giúp em. Trình độ về VDK của em vẫn còn rất kém, tuy nhiên thấy Code viết hay quá (ngắn hơn rất nhiều so với những cái em đã từng gặp) nên cố gắng tìm hiểu .
    Những dòng em chưa hiểu em viết chữ màu đỏ.
    #include <REGX52.H>
    #include <string.h>
    //******************BANG MA ASCII on LED matrix font 5x7 ****************
    unsigned char code code_Tab[97][6]={
    0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,//SPACE 0
    0xFF,0xFF,0xA0,0xFF,0xFF,0xFF,//! 1
    0xFF,0xFF,0xF8,0xF4,0xFF,0xFF,//' 2
    0xEB,0x80,0xEB,0x80,0xEB,0xFF,//# 3
    0xDB,0xD5,0x80,0xD5,0xED,0xFF,//$ 4
    0xD8,0xEA,0x94,0xAB,0x8D,0xFF,//% 5
    0xC9,0xB6,0xA9,0xDF,0xAF,0xFF,//& 6
    0xFF,0xFF,0xF8,0xF4,0xFF,0xFF,//' 7
    0xFF,0xE3,0xDD,0xBE,0xFF,0xFF,//( 8
    0xFF,0xBE,0xDD,0xE3,0xFF,0xFF,//) 9
    0xD5,0xE3,0x80,0xE3,0xD5,0xFF,//* 10
    0xF7,0xF7,0xC1,0xF7,0xF7,0xFF,//+ 11
    0xFF,0xA7,0xC7,0xFF,0xFF,0xFF,//, 12
    0xF7,0xF7,0xF7,0xF7,0xF7,0xFF,//- 13
    0xFF,0x9F,0x9F,0xFF,0xFF,0xFF,//x 14
    0xFF,0xC9,0xC9,0xFF,0xFF,0xFF,// / 15
    0xC1,0xAE,0xB6,0xBA,0xC1,0xFF,//0 16
    0xFF,0xBD,0x80,0xBF,0xFF,0xFF,//1 17
    0x8D,0xB6,0xB6,0xB6,0xB9,0xFF,//2 18
    0xDD,0xBE,0xB6,0xB6,0xC9,0xFF,//3 19
    0xE7,0xEB,0xED,0x80,0xEF,0xFF,//4 20
    0xD8,0xBA,0xBA,0xBA,0xC6,0xFF,//5 21
    0xC3,0xB5,0xB6,0xB6,0xCF,0xFF,//6 22
    0xFE,0x8E,0xF6,0xFA,0xFC,0xFF,//7 23
    0xC9,0xB6,0xB6,0xB6,0xC9,0xFF,//8 24
    0xF9,0xB6,0xB6,0xD6,0xE1,0xFF,//9 25
    0xFF,0xC9,0xC9,0xFF,0xFF,0xFF,//: 26
    0xFF,0xA4,0xC4,0xFF,0xFF,0xFF,//// 27
    0xF7,0xEB,0xDD,0xBE,0xFF,0xFF,//< 28
    0xEB,0xEB,0xEB,0xEB,0xEB,0xFF,//= 29
    0xFF,0xBE,0xDD,0xEB,0xF7,0xFF,//> 30
    0xFD,0xFE,0xAE,0xF6,0xF9,0xFF,//? 31
    0xCD,0xB6,0x8E,0xBE,0xC1,0xFF,//@ 32
    0x83,0xF5,0xF6,0xF5,0x83,0xFF,//A 33
    0xBE,0x80,0xB6,0xB6,0xC9,0xFF,//B 34
    0xC1,0xBE,0xBE,0xBE,0xDD,0xFF,//C 35
    0xBE,0x80,0xBE,0xBE,0xC1,0xFF,//D 36
    0x80,0xB6,0xB6,0xB6,0xBE,0xFF,//E 37
    0x80,0xF6,0xF6,0xFE,0xFE,0xFF,//F 38
    0xC1,0xBE,0xB6,0xB6,0xC5,0xFF,//G 39
    0x80,0xF7,0xF7,0xF7,0x80,0xFF,//H 40
    0xFF,0xBE,0x80,0xBE,0xFF,0xFF,//I 41
    0xDF,0xBF,0xBE,0xC0,0xFE,0xFF,//J 42
    0x80,0xF7,0xEB,0xDD,0xBE,0xFF,//K 43
    0x80,0xBF,0xBF,0xBF,0xFF,0xFF,//L 44
    0x80,0xFD,0xF3,0xFD,0x80,0xFF,//M 45
    0x80,0xFD,0xFB,0xF7,0x80,0xFF,//N 46
    0xC1,0xBE,0xBE,0xBE,0xC1,0xFF,//O 47
    0x80,0xF6,0xF6,0xF6,0xF9,0xFF,//P 48
    0xC1,0xBE,0xAE,0xDE,0xA1,0xFF,//Q 49
    0x80,0xF6,0xE6,0xD6,0xB9,0xFF,//R 50
    0xD9,0xB6,0xB6,0xB6,0xCD,0xFF,//S 51
    0xFE,0xFE,0x80,0xFE,0xFE,0xFF,//T 52
    0xC0,0xBF,0xBF,0xBF,0xC0,0xFF,//U 53
    0xE0,0xDF,0xBF,0xDF,0xE0,0xFF,//V 54
    0xC0,0xBF,0xCF,0xBF,0xC0,0xFF,//W 55
    0x9C,0xEB,0xF7,0xEB,0x9C,0xFF,//X 56
    0xFC,0xFB,0x87,0xFB,0xFC,0xFF,//Y 57
    0x9E,0xAE,0xB6,0xBA,0xBC,0xFF,//Z 58
    0xFF,0x80,0xBE,0xBE,0xFF,0xFF,//[ 59
    0xFD,0xFB,0xF7,0xEF,0xDF,0xFF,//\ 60
    0xFF,0xBE,0xBE,0x80,0xFF,0xFF,//] 61
    0xFB,0xFD,0xFE,0xFD,0xFB,0xFF,//^ 92
    0x7F,0x7F,0x7F,0x7F,0x7F,0xFF,//_ 63
    0xFF,0xFF,0xF8,0xF4,0xFF,0xFF,//' 64
    0xDF,0xAB,0xAB,0xAB,0xC7,0xFF,//a 65
    0x80,0xC7,0xBB,0xBB,0xC7,0xFF,//b 66
    0xFF,0xC7,0xBB,0xBB,0xBB,0xFF,//c 67
    0xC7,0xBB,0xBB,0xC7,0x80,0xFF,//d 68
    0xC7,0xAB,0xAB,0xAB,0xF7,0xFF,//e 69
    0xF7,0x81,0xF6,0xF6,0xFD,0xFF,//f 70
    0xF7,0xAB,0xAB,0xAB,0xC3,0xFF,//g 71
    0x80,0xF7,0xFB,0xFB,0x87,0xFF,//h 72
    0xFF,0xBB,0x82,0xBF,0xFF,0xFF,//i 73
    0xDF,0xBF,0xBB,0xC2,0xFF,0xFF,//j 74
    0xFF,0x80,0xEF,0xD7,0xBB,0xFF,//k 75
    0xFF,0xBE,0x80,0xBF,0xFF,0xFF,//l 76
    0x83,0xFB,0x87,0xFB,0x87,0xFF,//m 77
    0x83,0xF7,0xFB,0xFB,0x87,0xFF,//n 78
    0xC7,0xBB,0xBB,0xBB,0xC7,0xFF,//o 79
    0x83,0xEB,0xEB,0xEB,0xF7,0xFF,//p 80
    0xF7,0xEB,0xEB,0xEB,0x83,0xFF,//q 81
    0x83,0xF7,0xFB,0xFB,0xF7,0xFF,//r 82
    0xB7,0xAB,0xAB,0xAB,0xDB,0xFF,//s 83
    0xFF,0xFB,0xC0,0xBB,0xBB,0xFF,//t 84
    0xC3,0xBF,0xBF,0xDF,0x83,0xFF,//u 85
    0xE3,0xDF,0xBF,0xDF,0xE3,0xFF,//v 86
    0xC3,0xBF,0xCF,0xBF,0xC3,0xFF,//w 87
    0xBB,0xD7,0xEF,0xD7,0xBB,0xFF,//x 88
    0xF3,0xAF,0xAF,0xAF,0xC3,0xFF,//y 89
    0xBB,0x9B,0xAB,0xB3,0xBB,0xFF,//z 90
    0xFB,0xE1,0xE0,0xE1,0xFB,0xFF,//^ 62
    0xE3,0xE3,0xC1,0xE3,0xF7,0xFF,//-> 93
    0xF7,0xE3,0xC1,0xE3,0xE3,0xFF,//<- 94
    0xEF,0xC3,0x83,0xC3,0xEF,0xFF,// 95
    0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,//BLANK CHAR 96
    unsigned char code KT_la[1][8]={0xC3,0xAD,0x5A,0x5E,0x5A,0xAD,0xC3,0 }; //ma ky tu: mat cuoi
    //0xB6,0x80,0xB6,0xBE,0xC1,0xFF, //ma ky tu: DD
    sbit SDA = P2^0; //Dau vao du lieu noi tiep
    sbit SCL = P2^1; // Dau vao xung clock
    sbit STR = P2^2; //Dau vao chot du lieu
    sfr DataPort = 0x90; // P1 (dieu khien hang)
    unsigned char *String_input ="HAPPY BIRTH DAY TO YOU!";
    // Ghi chuoi ky tu can hien thi
    unsigned int Pos=0,lengh_STR; // Khai bao cac bien
    unsigned char Tic=0; // Khai bao bien Tic: Thoi gian hien thi cac ky tu
    #define With_of_font 6
    wait(unsigned int N){while(N--);} // Ham tre
    void main ()
    unsigned char Temp_code;
    unsigned int j;
    TMOD=0x01; //Timer0 o che do dem 16bit
    TR0=1; //Cho phep Timer0 chay
    ET0=1; //Cho phep ngat Timer0
    lengh_STR = strlen(String_input)*6; // Em ko hiểu dòng này
    EA=1; //Cho phep ngat toan cuc
    while(1)
    SDA=1; //Cho SDA len 1 ==> san sang de quet cot(Cot la Anot cua led)
    for(j=Pos;j<32+Pos;j++) //Quet 32 cot
    Temp_code=code_Tab[ String_input[(j%lengh_STR)/With_of_font] -32][j%With_of_font]; //Em ko hiểu dòng này
    DataPort=0xFF; // Cho hang cua matrix len 1 ==> Ma trix tat het (hang la Catot cua led)
    SCL=1; // Xuat 1bit vao 74hc595 (bit nay co gia tri 1)
    SCL=0;
    STR=1; // Xuat bit ra de quet cot dau tien
    STR=0;
    DataPort = Temp_code; // Gia tri cua hang
    SDA=0; // Cho SDA =0 de san sang cho chu ky tiep theo
    wait(60); //Tre 60us.
    void INT_Timer0()interrupt 1 // Ham ngat Timer0
    Tic++; // Tang bien Tic len 1
    if(Tic==4)
    { //Neu Tic==2 thi gan Tic=0
    Tic=0;
    Pos++; //Tang Poc len 1
    if(Pos>=lengh_STR)Pos=0; //Neu chay het chu thi quay lai tu dau.
    Còn đây là chương trình mô phỏng:
    http://www.mediafire.com/?97kitxt6h1xb4qp
    Mua bán thiết bị điện công nghiệp tại Hà Nội, toàn quốc.
    http://diencongnghiep360.com/
    http://tudienhathe.vn/
  • hoangdai
    • Nov 2005
    • 2720
    Nên hiểu nguyên tắc_Ko nên đọc code rồi suy ra nguyên tắc.
    • vietthanh123
      • Mar 2011
      • 479
      Nguyên văn bởi hoangdai Xem bài viết
      Chán.Code trên có 1 số "hàm lạ"" với em. Ví dụ như hàm "strlen" ... . Chứ phương pháp quét led ma trận thì em cũng hiểu sơ sơ rồi (E có thể quét 4 led nhưng mà chữ đứng yên). Hôm trước tìm được code này trên mạng thấy viết ngắn gọn quá nên em muốn tìm hiểu thêm,chứ ko phải là đồ án môn học gì cả. Mà em ko học nghanhf điện tử nên kiến thức về lập trình ko có nhiều,tranh thủ mấy tuần nghỉ hè tìm hiểu thêm về đt,xung quanh lại ko có ai để hỏi nên mới lên diễn đàn hỏi mọi người. Bác nào biết thì trả lời dùm em với. Thông thường, khi em rất"bí" rồi thì mới đặt câu hỏi trên diễn đàn và đôi khi em cũng rất ngại khi đặt ra những câu hỏi "ngu ngơ". Tuy nhiên do ko được đào tạo bài bản cũng như tư duy kém nên đành...phải hỏi. Mong mọi người giúp đỡ.!
      • vietthanh123
        • Mar 2011
        • 479
        Mấy hôm trước được tác giả trả lời cho, em xin nói sơ qua cho bạn nào... chậm hiểu giống mình biết.
        Dòng màu đỏ thứ nhất:
        Hàm strlen là hàm trả về giá trị của chuỗi. Như ví dụ trên thì lengh_STR sẽ bằng số ký tự trong chuỗi cần hiện thị *6. (Ví dụ: Muốn hiện thỉ chữ "VIETTHANH" thì lengh_STR=9*6=54)
        Dòng màu đỏ thứ 2:
        Tác giả nói cứ thay số vào rồi tìm ra nguyên tắc.Em làm theo, sau một buổi chiều thì cũng hiểu ra dòng lệnh đó.
        Chương trình này hay cái là muốn mở rộng ra bao nhiêu led ma trận cũng được. Phần cứng và chương trình thay đổi theo rất đơn giản.
        • huuhuy92
          • Sep 2011
          • 6
          Nguyên văn bởi vietthanh123 Xem bài viết
          Em có chương trình hiện thị chữ bằng ma trận led 8x8 (Lấy từ Trang chủ). Tuy nhiên có vài dòng lệnh em chưa hiểu đựơc. Rất mong các bác trên diễn đàn giải thích chi tiết giúp em. Trình độ về VDK của em vẫn còn rất kém, tuy nhiên thấy Code viết hay quá (ngắn hơn rất nhiều so với những cái em đã từng gặp) nên cố gắng tìm hiểu .
          #include <REGX52.H>
          #include <string.h>
          void main ()
          unsigned int j;
          while(1)
          SCL=0;
          STR=0;
          if(Tic==4)
          Tic=0;
          Led ma tran.rar
          bang ma nay minh co the them ky tu vao dc khong anh neu dc thi lam nhu the nao
          ma cac anh co bang ma nao co chu cai co dau khong anh
          gui qua nguyenhuuhuy.qn@gmail.com
          thank cac anh pro nhieu
          • huuhuy92
            • Sep 2011
            • 6
            #include <REGX52.H>
            #include <string.h>
            void main ()
            unsigned int j;
            while(1)
            SCL=0;
            STR=0;
            if(Tic==4)
            Tic=0;
            Led ma tran.rar
            • mast090
              • Oct 2010
              • 1018
              code đã đủ, nhìn là ra đoạn cần thêm mã giống của mình còn mún ăn sẵn thêm nữa ak
              Website chính thức đổi địa chỉ website thành
              Mời các bạn ghé thăm !!!
              • dtcn_112
                • Apr 2012
                • 267
                #8
                bài code này em cũng đọc trên dttt.neme nó không quét được nhiều led như bạn đăng bài này lên,khi mô phỏng 5 led là chớp led,thực tế em chưa thấy ai làm bằng phương pháp này
                • bienhou
                  • Dec 2011
                  • 971
                  #9
                  Nguyên văn bởi mast090 Xem bài viết
                  bài này hình như của bác đúng ko ạ.! e nhìn cái avatar quen quá
                  gmail :
                  • mast090
                    • Oct 2010
                    • 1018
                    #10
                    Nguyên văn bởi bienhou Xem bài viết
                    ko, bài của a khác. nhưng nó cũng viết gần tương tự vậy, và nên làm theo hướng như chủ topic đưa, như vây khi thay dòng chữ hiển thị thì chỉ việc gõ dòng chữ vào mảng các kí tự cần hiển thị thôi mà ko cần tạo lại bảng mã, nhất là làm với ghép nỗi máy tính hay như các quảng cáo, thông báo sử dụng matrix ngoài đường phố người ta cũng đều tạo bảng mã sẵn hết. Còn với các bài mà chỉ hiển thị 1 matrix vs 1 kí tự thì k cần thiết vậy, add mỗi cái mã của chữ đó vào cho nó gọn
                    • jerrythanh
                      • Feb 2012
                      • 53
                      #11
                      bai viết haym mà ngâm cứu không hiểu nỗi, đúng là toàn cao thủ không
                      vietthanh123 Tìm hiểu thêm về vietthanh123
