╔═══════════════════[ĐIỆN_LƯỚI_220V]════════════════╗
║________________________║___________║____________ ____________║
║________________________║(L)_________║__(N)______ _____________║
║________________________▼___________▼____________ ___________║
║________________________[CB_2_CỰC_2P_6A]______________________║
║________________________║ [LED BÁO] ║_______________________║
║___________║_____________________________________ __║__________║
║___[ADAPTER_12V_5A]_____________[SẠC_FOXSUR_12V_3_GIAI_ĐOẠN]__║
║______(NGUỒN_CHÍNH)__________________________(NGU ỒN_SẠC)_____║
║___________▼_____________________________________ __▼_________║
║___[MẠCH_TRỄ_WJ01]___________________________[BÌNH_ẮC_QUY]____║
║___(Trễ_ổn_định_AC)________________________(12V_9 Ah_Dự_phòng)____║
║___________║_________________________________[CẦU_CHÌ_5A]______║
║___________║_____________________________________ __║___________║
║___________║_____________________________________ __▼__________║
║___________║_____________________________[MẠCH_BẢO_VỆ_M609]___║
║___________║_____________________________(Chống_x ả_cạn_bình)____║
║____[LED_XANH_BÁO_AC]____________________[LED_ĐỎ_BÁO_BÌNH]____║
║______(Cổng_V_IN)_____________________________(Cổ ng_BAT_IN)_____║
╠═══════════╩═══════[MẠCH_YX-850]═══════════╩════════╣
║_____________________(Chuyển_nguồn_tự_động)______ _______________║
║__________________________║________║_____________ ______________║
║_________________________(OUT+)__(OUT-)_________________________║
║__________________________▼________▼_____________ _____________║
║_____________________[MẠCH_ỔN_ÁP_XL6009]_______________________║
║_______________________(Buck-Boost_12V)__________________________║
║___________________________║________║____________ ______________║
║___________________________▼________▼____________ _____________║
╚═════════════════[MODEM_WIFI_12V_2A]═════════════════╝
Dưới đây là giải thích chi tiết về luồng đi của dòng điện và logic vận hành của hệ thống:
### 1. Luồng điện AC (Phần bảo vệ và cấp nguồn)
* **Aptomat 2P - 6A:** Đây là cửa ngõ duy nhất. Khi bạn bật CB, dòng điện 220V cấp đồng thời cho **Adapter 12V** và **Sạc Foxsur**.
* **Nguyên lý:** Nếu một trong hai bộ nguồn bị chập cháy bên trong, CB sẽ nhảy để bảo vệ đường dây điện nhà bạn. Việc dùng CB 2 cực đảm bảo ngắt hoàn toàn cả dây nóng và dây nguội, an toàn khi bạn cần tháo bình hoặc thay mạch.
### 2. Nhánh Nguồn Ưu Tiên (Luồng chính từ lưới điện)
Đường này đi qua **Mạch trễ XY-WJ01**.
* **Nguyên lý:** Khi có điện trở lại sau khi mất điện, điện lưới thường không ổn định ngay (có thể bị chập chờn, vọt áp). Mạch trễ sẽ "đứng canh", nó đếm ngược 60 giây. Trong 1 phút này, đầu ra của nó vẫn ngắt ().
* **Sau 60 giây:** Mạch đóng rơ-le, cấp 12V cho cổng **DC-IN** của mạch **YX-850**. Lúc này **LED Xanh** sáng lên báo hiệu: "Điện lưới đã ổn định và đang được sử dụng".
### 3. Nhánh Nguồn Dự Phòng (Luồng từ Ắc quy)
Đường này có 2 lớp bảo vệ: **Cầu chì** và **Mạch bảo vệ xả cạn XH-M609**.
* **Cầu chì lá 5A:** Bảo vệ ắc quy chống cháy nổ nếu có ngắn mạch xảy ra ở các module phía sau.
* **Mạch XH-M609:** Đây là "bảo vệ sự sống" cho bình. Ắc quy chì nếu xả dưới sẽ bị hỏng (chai bình). Mạch này đo áp bình liên tục. Nếu áp giảm xuống mức cài đặt (ví dụ ), nó sẽ ngắt điện cấp cho mạch YX-850.
* **LED Đỏ:** Đấu sau mạch XH-M609. Nếu LED Đỏ sáng, nghĩa là bình còn điện và sẵn sàng dự phòng. Nếu LED Đỏ tắt, nghĩa là bình đã cạn hoặc bị hỏng.
### 4. Trái tim của hệ thống: Mạch YX-850
Mạch này đóng vai trò một chiếc cầu dao tự động siêu nhanh.
* **Nguyên lý chuyển mạch:** Mạch YX-850 luôn ưu tiên cổng **DC-IN** (nguồn lưới).
* **Khi có điện lưới:** Rơ-le trên mạch hút về phía nguồn lưới, ngắt kết nối với bình.
* **Khi mất điện:** Rơ-le nhả ra ngay lập tức, nối thông cổng **BAT-IN** (bình) ra cổng **OUT**.
### 5. Khâu cuối cùng: Mạch Buck-Boost XL6009
Đây là bộ ổn định điện áp đầu ra.
* **Nguyên lý:** Ắc quy khi đầy, khi yếu. Và Adapter cũng có thể dao động. Mạch XL6009 sẽ lấy bất kỳ mức điện áp nào từ đến ở đầu vào và biến đổi nó thành đúng **12.0V** cố định ở đầu ra.
* **Tác dụng:** Giúp Modem chạy mát hơn, bền hơn và không bị treo do điện áp trồi sụt.
Có thể thêm tụ nếu Modem bị khởi động lại (cần test mạch chưa thêm tụ trước, nếu bị reset mới thêm tụ)
### Tóm tắt logic vận hành
1. **Có điện lưới:** Adapter chạy Đợi 60s LED Xanh sáng Modem chạy bằng Adapter. (Sạc Foxsur đồng thời nạp cho bình).
2. **Mất điện lưới:** Mạch trễ tắt YX-850 nhảy sang dùng Bình LED Xanh tắt, LED Đỏ vẫn sáng Modem chạy bằng Bình qua ổn áp XL6009.
3. **Mất điện lâu ngày:** Bình yếu dần xuống XH-M609 ngắt điện LED Đỏ tắt Toàn bộ hệ thống nghỉ để bảo vệ bình.
