download từ ieee
nho bac tai giup
1]H. N. Hickok, “Adjustable speed a tool for saving energy losses in pumps, fan, blowers and compressors,” IEEE Trans. Ind. Appl., vol. IA-21, no. 1, pp. 124–136, Jan. 1985.
[2]P. Enjeti and A. Rahman, “A new single phase to three phase converter with active input current shaping for low cost ac motor drives,” IEEE Trans. Ind. Appl., vol. 29, no. 4, pp. 806–813, Jul./Aug. 1993.
[3]F. Blaabjerg, S. Freysson, H.-H. Hansen, and S. Hansen, “A new op-timized space vector modulation strategy for a component minimized voltage source inverter,” IEEE Trans. Power Electron., vol. 12, no. 4, pp. 704–714, Jul. 1997.
[4]C. B. Jacobina and M. B. R. Correa, “Induction motor drive system for low-power application,” IEEE Trans. Ind. Appl., vol. 35, no. 1, pp. 52–61, Jan./Feb. 1999.
[5]R. Madorell and J. Pou, “Modulation techniques for a low-cost single-phase to three-phase converter,” in Proc. IEEE ISIE, 2004, vol. 2, pp. 1279–1284.
[6]G.-T. Kim and T. A. Lipo, “VSI-PWM rectifier/inverter system with a reduced switch count,” in Proc. IEEE IAS Annu. Meeting, 1995, pp. 2327– 2332.
[7]J. T. Boys and A. W. Green, “Current-forced single-phase reversible rectifier,” Proc. Inst. Electr. Eng.—Electr. Power Appl., vol. 136, no. 5, pp. 205–211, Sep. 1989.
[8]R. Srinivasan and R. Oruganti, “A unity power factor converter using half-bridge boost topology,” IEEE Trans. Power Electron., vol. 13, no. 3, pp. 487–500, May 1998.
[9]B. R. Lin, D. J. Chen, and T. L. Hung, “Half-bridge neutral point diode clamped rectifier for power factor correction,” IEEE Trans. Aerosp. Electron. Syst., vol. 38, no. 4, pp. 1287–1294, Oct. 2002.
[10]B. R. Lin and T. Y. Yang, “Single-phase half-bridge rectifier with power factor correction,” Proc. Inst. Electr. Eng.—Electr. Power Appl., vol. 151, no. 4, pp. 443–450, Jul. 2004.
[11]C. B. Jacobina, T. M. Oliveira, and E. R. C. da Silva, “Control of the single-phase three-leg AC/AC converter,” IEEE Trans. Ind. Electron., vol. 53, no. 2, pp. 467–476, Apr. 2006.
[12]K. Toyama, T. Takeshita, and N. Matsui, “Stability and initial estimation of power source voltage sensorless single-phase PWM ac/dc converter,” Trans. Jpn. Inst. Elect. Eng., vol. 116-D, no. 3, pp. 354–360, 1996.
[13]I. Ando and I. Takahashi, “Simple sensorless control of a sinusoidal input current PWM converter,” Trans. Jpn. Inst. Elect. Eng., vol. 118-D, no. 1, pp. 136–137, 1998.
Down giup minh bai bao nay voi. Xin cam on
A nodal link perceptron network with applications to control of a nonholonomic system
Sadegh, N.
George W. Woodruff Sch. of Mech. Eng., Georgia Inst. of Technol., Atlanta, GA
This paper appears in: Neural Networks, IEEE Transactions on
Issue Date: Nov 1995
Volume: 6 Issue: 6
On page(s): 1516 - 1523
ISSN: 1045-9227
INSPEC Accession Number: 5110570
Digital Object Identifier: 10.1109/72.471358
Date of Current Version: 06 August 2002
Anh chị download dùm em bài báo này nha! Em cảm ơn ah!
Title: A Novel and Efficient Synthesis of (6R,7R)-7-Amino-3-hydroxymethyl Cephalosporanic Acid: A Versatile Precursor of Cefuroxime Acid
Authors: Santosh Kumar Singha; R. P. Tiwari; Praveen Jainb
Journal: Synthetic Communications
Issue: Issue 14
Year of publish: 2003
Page: 2475 - 2482
Direct link đến abstract: http://www.informaworld.com/smpp/358...~frm=titlelink
Bạn giúp mình download một số tài liệu này đi .Thank & happy
nhờ các anh chị giúp em down mấy cái tài liệu từ IEEE. em đang cần gắp...
1. http://ieeexplore.ieee.org/search/fr...d%3DSearch+All
2. http://ieeexplore.ieee.org/search/fr...d%3DSearch+All
3. http://ieeexplore.ieee.org/search/fr...d%3DSearch+All
cảm ơn Anh,chị !
Link của bạn nè http://azsharing.com/5ads7czpi0hz/hoanglongroy.zip.htmlNguyên văn bởi hoanglongroy Xem bài viếtnhờ các anh chị giúp em down mấy cái tài liệu từ IEEE. em đang cần gắp...
cảm ơn Anh,chị !
Bạn có thể vào blog http://hoahocxanhtvu.blogspot.com/20...noi-tieng.html để mình giúp bạn trực tiếp hơn
Bạn download giúp cho link sau nhé, cảm ơn nhiều
Link của bạn đâyNguyên văn bởi minhtun Xem bài viếtBạn download giúp cho link sau nhé, cảm ơn nhiều
http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
Bạn có thể vào blog của mình để yêu cầu cho nhanh hơn
Các anh down giùm em tài liệu này với.Em cảm ơn nhiều
Design of UHF RFID reader based on AS3991
links http://ieeexplore.ieee.org/xpl/mostR...=null&asf_pn=6
Nguyên văn bởi jefflieu Xem bài viếtCan thi dua title cua ta`i lieu cho Jeff, Jeff down cho, jeff co' account nhung ko share len duoc ... mong a e thong cam ... truo`ng no' biet duoc no' duoi hoc chet
hôm nay, 03:09 -
hôm nay, 03:03 -
Hôm qua, 07:53 -
Hôm qua, 02:14 -
