help me!!!! AVR code doi số bcd sang mã hex
  • tvh147
    • May 2012
    • 11
    chào các a!
    có ai pro avr có thể giúp e chuyen đoạn code viết cho 89051 sang cho avr đc ko?
    đoạn code của e là:
    ;=============== khai bao ================
    byte_cao equ 60h
    byte_thap equ 62h
    thuong_high equ 7eh
    thuong_low equ 7dh
    sbc_high equ 7ch
    sbc_low equ 7bh
    sodu equ 7ah
    led0 equ 40h
    led1 equ 41h
    led2 equ 42h
    led3 equ 43h
    led4 equ 44h
    ;=========== voidmain ====================
    org 0x0000
    mov byte_cao,#0xff
    mov byte_thap,#0xff
    mov dptr,#led7_code
    sjmp voidmain
    org 0x0040
    voidmain:
    lcall dem
    lcall bcd_hex
    lcall display
    sjmp voidmain
    ;============== bcd_hex ==================
    bcd_hex:
    mov sbc_high,byte_cao
    mov sbc_low,byte_thap
    lcall chia10
    mov led0,sodu
    mov sbc_high,thuong_high
    mov sbc_low,thuong_low
    lcall chia10
    mov led1,sodu
    lcall chia10
    mov led2,sodu
    lcall chia10
    mov led3,sodu
    lcall chia10
    mov led4,sodu
    ret
    ;============= chia 10 ===================
    chia10:
    mov a,sbc_high
    mov b,#10
    div ab
    mov thuong_high,a
    mov a,b
    swap a
    mov b,a
    mov a,sbc_low
    swap a
    anl a,#0fh
    orl a,b
    mov b,#10
    div ab
    swap a
    mov thuong_low,a
    mov a,b
    swap a
    mov b,a
    mov a,sbc_low
    anl a,#0fh
    orl a,b
    mov b,#10
    div ab
    orl a,thuong_low
    mov thuong_low,a
    mov sodu,b
    ret
    ;============== display ==================
    display:
    mov a,led0
    movc a,@a+dptr
    mov led0,a
    mov a,led1
    movc a,@a+dptr
    mov led1,a
    mov a,led2
    movc a,@a+dptr
    mov led2,a
    mov a,led3
    movc a,@a+dptr
    mov led3,a
    mov a,led4
    movc a,@a+dptr
    mov led4,a
    mov p2,led0
    setb p3.0
    lcall delay
    clr p3.0
    mov p2,led1
    setb p3.1
    lcall delay
    clr p3.1
    mov p2,led2
    setb p3.2
    lcall delay
    clr p3.2
    mov p2,led3
    setb p3.3
    lcall delay
    clr p3.3
    mov p2,led4
    setb p3.4
    lcall delay
    clr p3.4
    ret
    ;============= delay =====================
    delay:
    mov r1,#20
    mov r0,#230
    LAP:
    djnz r0,lap
    djnz r1,lap
    ret
    ;============= dem =======================
    dem:
    mov a,#0xff
    inc byte_thap
    cjne a,byte_thap,__countup_exit
    mov 0x25,#0x00
    inc byte_cao
    cjne a,byte_cao,__countup_exit
    mov 0x26,#0x00
    __countup_exit:
    ret
    ;============ led7_code ==================
    org 0x0500
    led7_code:
    db 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90
    end
    mong các pro giúp e!!!!!!!
    thanks!!!!!!!
  • havian
    • Jun 2011
    • 66
    Các trình biên dịch cho AVR có cả loại dùng ASM và C. Như AVRstudio . Tôi thấy đoạn code trên bạn dùng ASM
    Bạn chỉ việc cài AVR studio và làm theo hướng dẫn là nó sẽ tự tạo ra file hex để nạp vào con AVR, mà bạn định dùng con AVR nào
    tvh147 Tìm hiểu thêm về tvh147
