Hỏi về code cho LED ma trận 8x8 (lần 2)
  • Hỏi về code cho LED ma trận 8x8 (lần 2)
    em có 1 số thắc mắc mong mọi người giúp đỡ
    em co đoạn code như thế này:
    $MOD51
    HANG DATA P2 ;HANG PORT2 TICH CUC MUC THAP
    COT DATA P3 ;COT PORT3 TICH CUC MUC CAO
    SELECT0 BIT P0.0 ;CAC BIT CHON LED TICH CUC
    SELECT1 BIT P0.1
    SELECT2 BIT P0.2
    SELECT3 BIT P0.3
    SELECT4 BIT P0.4
    CHONCT BIT P0.7 ;BIT CHON CHUONG TRINH NAO SE DUOC THUC THI
    START BIT P0.6 ;BIT CHO CHAY CHUONG TRINH DUOC CHON
    STARTS:
    MOV P2,#0FFH ;XOA HANG
    MOV P3,#00H ;XOA COT
    MOV R0,#00H ;NAP GIA TRI DAU TIEN CHO R0
    MAIN: ;CHUONG TRINH CHINH,KIEM TRA VA CHO THUC
    ;HIEN CHUONG TRINH DUOC NGUOI SU DUNG CHON
    CJNE R0,#00,HS1
    LCALL SO0
    HS1: CJNE R0,#02,HS2
    LCALL SO1
    HS2: CJNE R0,#04,HS3
    LCALL SO2
    HS3: CJNE R0,#06,HS4
    LCALL SO3
    HS4: CJNE R0,#08,KT0
    LCALL SO4
    KT0: JNB START,SELECT ;NHAY NEU BIT START DUOC NHAN
    ;DEN BANG CHON CHUONG TRINH (SELECT)
    LJMP KT1 ;NEU BIT START CHUA DUOC NHAN ,
    ;KIEM TRA TIEP BIT CHONCT
    KT1: JNB CHONCT,TANGR0 ;NEU BIT CHONCT DUOC NHAN,
    ;TANG R0 DE CHON CT TUONG UNG
    LJMP MAIN ;QUAY LAI DE KIEM TRA TU DAU
    TANGR0:
    INC R0 ;TANG R0 THEM 2,VI LENH AJMP
    ; TRONG BANG NHAY TABLE CHIEM 2 BYTE
    INC R0
    LCALL DELAY ;CHONG NHIEU ,TRONG TRUONG HOP
    ; GIU NUT NHAN LAU HON CHU KI KIEM TRA
    LJMP MAIN ;QUAY LAI KIEM TRA TU DAU
    SELECT: ;NHAY DEN CAC CHUONG TRINH TUONG UNG
    MOV DPTR,#TABLE
    MOV A,R0
    JMP @A+DPTR ;NHAY DEN CHUONG TRINH DUOC CHON
    ; (DO GIA TRI R0 LUC NAY)
    TABLE: ;BANG CHON CHUONG TRINH
    AJMP PR0
    AJMP PR1
    AJMP PR2
    AJMP PR3
    AJMP PR4
    ;CAC CHUONG TRINH CON HIEN THI SO
    SO0:
    CLR SELECT0 ;CHO LED 0 TICH CUC
    MOV DPTR,#MASO0
    LCALL SCAN1MT
    RET
    SO1:
    MOV DPTR,#MASO1
    LCALL SCAN1MT
    RET
    SO2:
    MOV DPTR,#MASO2
    LCALL SCAN1MT
    RET
    SO3:
    MOV DPTR,#MASO3
    LCALL SCAN1MT
    RET
    SO4:
    SETB SELECT1
    MOV DPTR,#MASO4
    LCALL SCAN1MT
    RET
    ;CAC CHUONG TRINH CON DE LUA CHON
    PR0:
    LCALL CT0
    LJMP PR0
    PR1:
    LCALL CT1
    LJMP PR1
    PR2:
    LCALL CT2
    LJMP PR2
    PR3: ;CHUA DUNG
    LJMP PR3
    PR4: ;CHUA DUNG
    LJMP PR4
    ;CAC CHUONG TRINH CHAY CHU
    CT0: ;CHAY DOAN CHU "HAPPY NEW YEAR 2008".
    MOV DPTR,#MAHIENTHI2
    LAP2:
    LCALL SCAN5MT
    INC DPTR
    MOV A,DPL
    CJNE A,#LOW(MAHIENTHI2+144),LAP2
    RET
    CT1: ;HIEN THI "DIEN TU"
    MOV DPTR,#DIENTU
    LCALL SCAN5MT
    RET
    CT2: ;HIEN THI "X CUONG".
    MOV DPTR,#CUONG
    LCALL SCAN5MT
    RET
    ;CAC CHUONG TRINH QUET MA TRAN
    SCAN1MT: ;CHUONG TRINH QUET MOT MA TRAN
    PUSH 00H
    PUSH 01H
    PUSH ACC
    MOV R0,#00H
    MOV R1,#80H ;R1 DUNG DE QUET COT(10000000B)
    SCAN:
    MOV A,R0
    MOVC A,@A+DPTR ;LAY MA HIEN THI
    MOV HANG,A ;DUA DU LIEU RA HANG
    MOV COT,R1 ;QUET COT
    LCALL DELAY2
    MOV COT,#00H ;CHONG LEM
    INC R0 ;TANG R0 DE LAY DU LIEU KE
    MOV A,R1 ;DICH PHAI R1,DE QUET COT KE
    RR A
    MOV R1,A
    CJNE R0,#08,SCAN ;KIEM TRA QUET DU 8 COT
    POP ACC
    POP 01H
    POP 00H
    RET
    ;CHUONG TRINH QUET 5 MA TRAN.
    SCAN5MT:
    PUSH 00H
    PUSH 01H
    PUSH 03H
    PUSH ACC
    MOV R0,#00H ;OFFSET LAY MA HIEN THI
    MOV R3,#11101111B ;DUNG DE CHON MA TRAN TICH CUC,
    ;TICH CUC LED 4 DAU TIEN
    SCAN2: ;NAP LAI SAU KHI DA QUET XONG 1 MA TRAN
    MOV R1,#80H ;QUET COT
    MOV P0,R3 ;TICH CUC MA TRAN
    SCAN1:
    MOV A,R0
    MOVC A,@A+DPTR
    MOV HANG,A
    MOV COT,R1
    LCALL DELAY3
    INC R0 ;TANG R0 DE LAY MA HIEN THI KE
    MOV A,R1 ;DICH PHAI R1 DE QUET COT KE
    RR A
    MOV R1,A
    CJNE R1,#80H,SCAN1;NHAY KHI CHUA QUET HET 8 COT
    MOV A,R3 ;DICH PHAI R3 DE TICH CUC MA TRAN TIEP THEO
    RR A
    MOV R3,A
    CJNE R3,#01111111B,SCAN2 ;NHAY KHI CHUA HET 5 MA TRAN
    POP ACC
    POP 03H
    POP 01H
    POP 00H
    RET
    ;CAC CHUONG TRINH DELAY
    DELAY: ;CHUONG TRINH DELAY 0.5S
    PUSH 00H
    MOV TMOD,#01H
    MOV R0,#200
    LOOP:
    MOV TH0,#0F6H
    MOV TL0,#03CH
    SETB TR0
    JNB TF0,$
    CLR TR0
    CLR TF0
    DJNZ R0,LOOP
    POP 00H
    RET
    DELAY2: ;CHUONG TRINH DELAY 2.5MS
    PUSH 00H
    PUSH 01H
    MOV R1,#5
    LOOP2:
    MOV R0,#250
    DJNZ R0,$
    DJNZ R1,LOOP2
    POP 01H
    POP 00H
    RET
    DELAY3: ;CHUONG TRINH DELAY 1.25 MS
    PUSH 00H
    PUSH 01H
    MOV R1,#3
    LOOP3:
    MOV R0,#210
    DJNZ R0,$
    DJNZ R1,LOOP3
    POP 01H
    POP 00H
    RET
    ;BANG MA DU LIEU HIEN THI
    MASO0:
    DB 0FFH,0FFH,0C1H,0BEH,0BEH,0BEH,0C1H,0FFH ;SO 0
    MASO1:
    DB 0FFH,0FFH,0EEH,0DEH,080H,0FEH,0FEH,0FFH ;SO 1
    MASO2:
    DB 0FFH,0FFH,0D8H,0B6H,0B6H,0B6H,0CEH,0FFH ;SO 2
    MASO3:
    DB 0FFH,0FFH,0DDH,0B6H,0B6H,0B6H,0C9H,0FFH ;SO 3
    MASO4:
    DB 0FFH,0FFH,0E3H,0DBH,0BBH,0FBH,080H,0FFH ;SO 4
    CUONG:
    DB 0FFH,09CH,0EBH,0F7H,0EBH,09CH,0FFH,0FFH,0FFH ; CHU X
    DB 0C1H,0BEH,0BEH,0BEH,0DDH,0FFH ; CHU C
    DB 081H,0FEH,0FEH,0FEH,081H,0FFH ; CHU U
    DB 0C1H,0BEH,0BEH,0BEH,0C1H,0FFH ; CHU O
    DB 080H,0DFH,0EFH,0F7H,080H,0FFH ; CHU N
    DB 0C1H,0BEH,0B6H,0B6H,0D1H,0FFH,0FFH ; CHU G
    DIENTU:
    DB 0FFH,080H,0BEH,0BEH,0BEH,0C1H,0FFH ; CHU D
    DB 0BEH,0BEH,080H,0BEH,0BEH,0FFH ; CHU I
    DB 080H,0B6H,0B6H,0B6H,0B6H,0FFH ; CHU E
    DB 0FFH,0FFH,0BFH,0BFH,080H,0BFH,0BFH,0FFH ; CHU T
    DB 081H,0FEH,0FEH,0FEH,081H,0FFH,0FFH; CHU U
    MAHIENTHI2:
    DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FFH
    DB 0FFH,0FFH,0FFH,080H,0F7H,0F7H,0F7H,080H,0FFH ; CHU H
    DB 0E0H,0DBH,0BBH,0DBH,0E0H,0FFH ; CHU A
    DB 080H,0B7H,0B7H,0B7H,0CFH,0FFH ; CHU P
    DB 09FH,0EFH,0F0H,0EFH,09FH,0FFH ; CHU Y
    DB 0FFH,0FFH,080H,0DFH,0EFH,0F7H,080H,0FFH ; CHU N
    DB 080H,0FDH,0FBH,0FDH,080H,0FFH ; CHU W
    DB 0FFH,0FFH,09FH,0EFH,0F0H,0EFH,09FH,0FFH ; CHU Y
    DB 080H,0B7H,0B3H,0B5H,0CEH,0FFH ; CHU R
    DB 0FFH,0FFH,0D8H,0B6H,0B6H,0B6H,08EH,0FFH ;SO 2
    DB 0C1H,0BEH,0BEH,0BEH,0C1H,0FFH ;SO 0
    DB 0C9H,0B6H,0B6H,0B6H,0C9H,0FFH ;SO 8
    END
    em muốn chữ chạy rồi đứng yên khoảng 2 giây rồi chạy tiếp thì phải sữa chỗ nào
    ai bít giúp em nha (vdk AT89S51 điều khiển 5 led matrix )
    8051 là con em viết thành thạo. em sẵn sàng giúp đỡ các pác nếu em có thể
    Doạn code này nhìn quen quen
    Hỏi code cho LMD 8x8 mà đem ứng dụng cho 5LMD là sao?
    Trần Đức Sơn
    tel:0934691385
      Re: theo to nghĩ thì hok được đâu
      tớ cũng đồng ý với cddt061
        hi các pác thông cảm em mới làm led matrix lần đầu và dùng đoạn code trên làm mẫu (cái này coppy bên ant7)
        vậy cho em đoạn code điều khiển 5 led matix chạy chữ "happy new year" rồi dừng 2 giây và chạy tiếp em dùng vdk AT89S51 chân P0 tích cực mức cao va P2 tích cực mức thấp
        giúp em nha
        thanks trước
          Cái họ 8951 này hồi trước mình dùng suốt .
          Mình nhớ là mạch điều khiển Led Matrix này có gì khó đâu nhỉ, quan trọng là bạn design cái mạch điều khiển là như thế nào thôi mà?
          Sau khi thiết kế được mạch điều khiển thì bạn sẽ tính toán các chữ H,A,P,Y... thành mã (hồi trước tớ làm thủ công lắm, tốn bao nhiêu giấy mới xong được cái mã này), rồi chỉ insert cái mã này vào 8951 là xong thôi. Dừng 2 giây chứ 10 giây cũng làm được .
            Khó với những người mới tìm hiểu về 8051. Cứ làm nhiều test nhiều vào phải đầu tư!. Ô bây giờ có nhiều phần mềm tạo phông chữ không tốn giấy như bác tortoise nói đâu.
            Ngày mai bắt đầu từ ngày hôm nay!!!
              pác tortoise ko hiểu ý em rồi
              em cũng đã có phần mêm tạo kiểu chữ rồi còn viết chương trình với các hiệu ứng thì em chịu .cái cốt lõi cua vấn đề ở đây là em cần 1 đoạn code để tạo hiệu ứng như:
              + chữ chạy rồi dừng rồi chạy tiếp
              + đoạn chữ khác chạy từ dưới lên rồi đứng rồi chạy tiếp ....
              ai bít thì chỉ em đi mà em dùng ngôn ngữ asm
              em đang rất cần
                cái này có vẻ khó với mấy pác nhỉ
                thảo nào tìm trên mạng ko có
                có ai giúp mình dc ko nhỉ
                  Nguyên văn bởi hoangphat Xem bài viết
                  ặc ặc
                  không phải là khó
                  mà là chính ở bạn thân bạn không chịu khó
                  bạn phải đưa phần cứng thì người khác xem có giúp bạn được không chứ
                  và lại bạn muốn tạo hiệu ứng thì đầu tiên bạn phải làm được là đứng yên đã
                  sau đó thử địch từ trái qua phải ...
                  rồi tự khắc biết làm à
                  chứ viết code cho bạn bạn đọc cũng khó mà hiểu được
                  bạn có thể xem demo tai đây
                  http://vn.myblog.yahoo.com/dangtiend...e?new=1&mid=16
                  chúc bạn thành công
                  Điện thoại:
                  email:
                    em đang tìm cái mạch đó ai bít thì giúp em nhá
                    em tim nó lâu rồi nhưng ko có kết quả
                      pác dang dung có mạch và code của bảng này ko em đang rất cần nó
                      hình như nó dùng 74hc595 thì phải
                      pác cho em xin mạch này đi đa tạ pác
                        Các bác cho mình hỏi tí.
                        Mình dùng thanh ghi R tăng dần để cập nhật ký tự trong bảng mã.
                        Vì Thanh ghi R chỉ có 8 bit nên mình chỉ cập nhật tối đa được có 255 ký tự thôi.(Hàng chữ rất ngắn).
                        Các bác có cách nào khác để truy tìm hết các ký tự trong bản mã ko?
                        Mình ko dùng rom ngoài nhé.
                          Dùng dual 2 thanh ghi đi!
                          Dual 2 thanh là 65025! Chưa thấy con nào khủng thế, mới dùng con 8x55 (20k)
                          Chép vài bài hát nhìn chơi!
                          Trần Đức Sơn
                          tel:0934691385
                            Cảm ơn bác.
                            Nhưng con này tập lệnh có giống con 89c51 ko nhỉ?
                            Bác bật mí tí nhé!Bác có tài liệu về lệnh của nó ko?
                              89C hay 89S gì thì tập lệnh cũng là 1 hết mà thôi!
                              Đã test với mã ASM còn C thì chưa thử vì ko học!
                              Trần Đức Sơn
                              tel:0934691385
                              hoangphat đam mê về ngành điện tử Tìm hiểu thêm về hoangphat
