quét led bằng pic16f877a
  • minh2208
    • Sep 2013
    • 15
    bác nào cao tay chỉ giúp em sửa cái code này cho nó quét cùng lúc 4 led với..........em mới học nên chưa biết nhiều ạ
    code đây ạ
    #include <16f877a.h>
    #fuses XT,HS,NOWDT,PUT
    #use delay(clock=4000000)
    #use fast_IO(a)
    #use fast_IO(d)
    #use fast_io(c)
    #byte portd=0x08
    #byte portc=0x06
    #bit RA0=0x05.0
    #bit RA1=0x05.1
    #bit RA2=0x05.2
    #bit RA3=0x05.3
    int u[10]={0b11000000,0b11111001,0b10100100,0b10110000,0b10 011001,0b10010010,0b10000010,0b11111000,0b10000000 ,0b10010000};
    signed int x,i,y,z,n,m,l;
    int chuc,donvi,chuc1,donvi1,chuc2,donvi2,chuc4,donvi4, chuc5,donvi5,chuc6,donvi6;
    void main()
    set_tris_a(0b0000);
    set_tris_d(0);
    set_tris_c(0b00000000);
    while(true)
    { x=30;
    y=27;
    z=3;
    n=27;
    m=3;
    l=30;
    //----------cot1---------
    //---------------do1--------------
    while(x>=0)
    output_c(0b00000100);
    chuc=x/10;
    donvi=x%10;
    for(i=0;i<50;i++)
    portd=u[chuc];
    RA0=0;
    delay_ms(5);
    RA0=1;
    portd=u[donvi];
    RA1=0;
    delay_ms(5);
    RA1=1;
    x--;
    output_c(0b00000000);
    //--------------xanh1-----------
    while(y>=0)
    output_c(0b00000010);
    chuc1=y/10;
    donvi1=y%10;
    for(i=0;i<50;i++)
    portd=u[chuc1];
    RA0=0;
    delay_ms(5);
    RA0=1;
    portd=u[donvi1];
    RA1=0;
    delay_ms(5);
    RA1=1;
    y--;
    //--------vang1--------
    while(z>=0)
    output_c(0b01000000);
    chuc2=z/10;
    donvi2=z%10;
    for(i=0;i<50;i++)
    portd=u[chuc2];
    RA0=0;
    delay_ms(5);
    RA0=1;
    portd=u[donvi2];
    RA1=0;
    delay_ms(5);
    RA1=1;
    z--;
    //----------cot2---------------------
    //----------xanh2----------------
    while(n>=0)
    output_c(0b00100000);
    chuc4=n/10;
    donvi4=n%10;
    for(i=0;i<50;i++)
    portd=u[chuc4];
    RA2=0;
    delay_ms(5);
    RA2=1;
    portd=u[donvi4];
    RA3=0;
    delay_ms(5);
    RA3=1;
    n--;
    //-----------vang2--------------
    while(m>=0)
    output_c(0b00010000);
    chuc5=m/10;
    donvi5=m%10;
    for(i=0;i<50;i++)
    portd=u[chuc5];
    RA2=0;
    delay_ms(5);
    RA2=1;
    portd=u[donvi5];
    RA3=0;
    delay_ms(5);
    RA3=1;
    m--;
    //------do2-----------------
    while(l>=0)
    output_c(0b00001000);
    chuc6=l/10;
    donvi6=l%10;
    for(i=0;i<50;i++)
    portd=u[chuc6];
    RA2=0;
    delay_ms(5);
    RA2=1;
    portd=u[donvi6];
    RA3=0;
    delay_ms(5);
    RA3=1;
    l--;
  • tjeunjnzah
    • Feb 2009
    • 719
    tạm thời code tạm ổn bây giờ phần mô phỏng bạn tháy bằng 4led 7leg gép liên với nhau rùi chứ không phải riêng nhé
    hãy làm theo cách của bạn!
    • minh2208
      • Sep 2013
      • 15
      Nguyên văn bởi tjeunjnzah Xem bài viết
      vậy giờ sửa lại sao hả bác.....nếu làm mô hình thì 4led mắc như vậy mà. em định làm ra mô hình luôn đó bác. bác chỉ em với
      • tjeunjnzah
        • Feb 2009
        • 719
        bạn gửi cả file code và mô phỏng lên mình sửa phần cứng cho.bạn đang làm đề tài đèn giao thông à?
        • minh2208
          • Sep 2013
          • 15
          vâng ạ...mình em đang làm đề tài giao thông. nhưng chỉ là qui mô nhỏ thôi. chỉ 1 chế độ đếm mặc định với 2 trạm và 1 cái phím hex thôi ạ. cũng không cần đếm đúng thời gian thực
          code em sửa lại thế này để quét cùng lúc 4 con. nhưng thế này chỉ là đánh lừa thị giác chứ nếu ghép bàn phím vào em sợ không đc. bác xem giúp em
          code:
          #use fast_IO(a)
          #use fast_IO(d)
          #use fast_IO(c)
          #byte portd=0x08
          #byte portc=0x07
          #bit RA0=0x05.0
          #bit RA1=0x05.1
          #bit RA2=0x05.2
          #bit RA3=0x05.3
          int chuc1,donvi1,chuc2,donvi2,chuc3,donvi3,chuc4,donvi 4,chuc5,donvi5,chuc6,donvi6;
          void main()
          set_tris_a(0b0000);
          set_tris_d(0);
          while(1)
          { x=30;///do1
          y=27;//xanh1
          z=3;//vang1
          n=27;
          m=30;
          l=3;
          //---------------lan1--------------
          while(x>0 && y>0)
          chuc1=x/10;
          donvi1=x%10;
          chuc2=y/10;
          donvi2=y%10;
          output_c(0b00100010);
          for(i=0;i<30;i++)
          portd=u[chuc1];
          RA0=0;
          delay_ms(5);
          RA0=1;
          portd=u[donvi1];
          RA1=0;
          delay_ms(5);
          RA1=1;
          portd=u[chuc2];
          RA2=0;
          delay_ms(5);
          RA2=1;
          portd=u[donvi2];
          RA3=0;
          delay_ms(5);
          RA3=1;
          x--;
          y--;
          while(z>0)
          chuc3=z/10;
          donvi3=z%10;
          output_c(0b01000010);
          for(i=0;i<30;i++)
          portd=u[chuc3];
          RA0=0;
          delay_ms(5);
          RA0=1;
          portd=u[donvi3];
          RA1=0;
          delay_ms(5);
          RA1=1;
          portd=u[chuc3];
          RA2=0;
          delay_ms(5);
          RA2=1;
          portd=u[donvi3];
          RA3=0;
          delay_ms(5);
          RA3=1;
          z--;
          //---------------lan2--------------
          while(n>0 && m>0)
          chuc3=n/10;
          donvi3=n%10;
          chuc4=m/10;
          donvi4=m%10;
          output_c(0b00010100);
          for(i=0;i<30;i++)
          portd=u[chuc3];
          RA0=0;
          delay_ms(5);
          RA0=1;
          portd=u[donvi3];
          RA1=0;
          delay_ms(5);
          RA1=1;
          portd=u[chuc4];
          RA2=0;
          delay_ms(5);
          RA2=1;
          portd=u[donvi4];
          RA3=0;
          delay_ms(5);
          RA3=1;
          n--;
          m--;
          while(l>0)
          chuc6=l/10;
          donvi6=l%10;
          output_c(0b00011000);
          for(i=0;i<30;i++)
          portd=u[chuc6];
          RA0=0;
          delay_ms(5);
          RA0=1;
          portd=u[donvi6];
          RA1=0;
          delay_ms(5);
          RA1=1;
          portd=u[chuc6];
          RA2=0;
          delay_ms(5);
          RA2=1;
          portd=u[donvi6];
          RA3=0;
          delay_ms(5);
          RA3=1;
          l--;
          • minh2208
            • Sep 2013
            • 15
            bác nói em ngu em chịu. nhưng sao em gửi file đính kèm không đc... bác cho em cái link facebook hay gmail đc không ạ
            • tjeunjnzah
              • Feb 2009
              • 719
              link facebook mình đây bạn vào in box mình sẽ trả lời nhé https://www.facebook.com/lookingfor.love.904
              minh2208 Tìm hiểu thêm về minh2208
