giúp em với 2 ngày nay ròi!!!!
  • hungtrinh36
    • Apr 2011
    • 346
    em đang làm hiển thị lcd 8 bít mà sao mãi chưa được, bác nào từng viết lcd 8 bít tìm lỗi sai trong code này em với
    This program was produced by the
    CodeWizardAVR V2.05.5a Evaluation
    Automatic Program Generator
    © Copyright 1998-2011 Pavel Haiduc, HP InfoTech s.r.l.
    HP InfoTech, Development Tools for Microcontrollers, C Compilers, In-System Programmers
    Project :
    Version :
    Date : 3/6/2012
    Author : Freeware, for evaluation and
    non-commercial use only
    Company :
    Comments:
    Chip type : ATmega16
    Program type : Application
    AVR Core Clock frequency: 8.000000 MHz
    Memory model : Small
    External RAM size : 0
    Data Stack size : 256
    #include <mega16.h>
    #include <delay.h>
    #define RS PORTD.2
    #define RW PORTD.1
    #define E PORTD.1
    #define PC PORTC
    unsigned char ten[]={"trinh phi hung"};
    unsigned char lop[]={"d09dta1"};
    int i,j;
    void kiemtra(void)
    {unsigned char kt;
    kt=0x80;
    DDRC=0x00;
    while((kt&0x80)==0x80)
    { RS=0;
    RW=1;
    kt=PC;
    E=1;
    E=0;
    delay_us(200);
    void ghilenh(unsigned char lenh)
    { kiemtra();
    DDRC=0xFF;
    RS=0;
    RW=0;
    PC= lenh;
    E=1;
    delay_us(200);
    E=0;
    void ghikitu(unsigned char kitu)
    { kiemtra();
    DDRC=0xFF;
    RS=1;
    RW=0;
    PC=kitu;
    E=1;
    delay_us(200);
    E=0;
    void khoidong(void)
    { ghilenh(0x38);
    ghilenh(0x0e);
    ghilenh(0x80);
    void xoalcd(void)
    { ghilenh(0x01);
    ghilenh(0x80);
    unsigned char dongcot[2]={0x80,0xc0};
    void gotoxy(unsigned char x,unsigned char y)
    { kiemtra();
    ghilenh(dongcot[y]+x);
    void main(void)
    // Input/Output Ports initialization
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0x00;
    DDRA=0x00;
    // Port B initialization
    PORTB=0x00;
    DDRB=0x00;
    // Port C initialization
    PORTC=0x00;
    DDRC=0x00;
    // Port D initialization
    PORTD=0x00;
    DDRD=0x00;
    // Graphic LCD initialization
    // The KS0108 connections are specified in the
    // Project|Configure|C Compiler|Libraries|Graphic LCD menu:
    // DB0 - PORTC Bit 0
    // DB1 - PORTC Bit 1
    // DB2 - PORTC Bit 2
    // DB3 - PORTC Bit 3
    // DB4 - PORTC Bit 4
    // DB5 - PORTC Bit 5
    // DB6 - PORTC Bit 6
    // DB7 - PORTC Bit 7
    // E - PORTD Bit 0
    // RD /WR - PORTD Bit 1
    // RS - PORTD Bit 2
    // /RST - PORTB Bit 3
    // CS1 - PORTB Bit 4
    // CS2 - PORTB Bit 5
    khoidong();
    xoalcd();
    while (1)
    { gotoxy(0,0);
    for(i=0;i<15;i++)
    ghikitu(ten[i]);
    ghilenh(0xc0);
    for(j=0;j<8;j++)
    ghikitu(lop[j]);
    em sử dụng chức năng chạy từng dòng trong proteus thì thấy nó chỉ lẩn quẩn trong cái hàm con kiemtra() thôi.ai có cách khắc phục thì giúp em với 2 ngày này em điên đầu với cái này lắm ròi
  • hoangdt_1989
    • Dec 2009
    • 32
    Nguyên văn bởi hungtrinh36 Xem bài viết
    Project :
    Version :
    Date : 3/6/2012
    Company :
    Comments:
    #include <mega16.h>
    #include <delay.h>
    #define RS PORTD.2
    #define RW PORTD.1
    #define E PORTD.1
    #define PC PORTC
    int i,j;
    void kiemtra(void)
    {unsigned char kt;
    kt=0x80;
    DDRC=0x00;
    { RS=0;
    RW=1;
    kt=PC;
    E=1;
    E=0;
    delay_us(200);
    { kiemtra();
    DDRC=0xFF;
    RS=0;
    RW=0;
    PC= lenh;
    E=1;
    delay_us(200);
    E=0;
    { kiemtra();
    DDRC=0xFF;
    RS=1;
    RW=0;
    PC=kitu;
    E=1;
    delay_us(200);
    E=0;
    void khoidong(void)
    { ghilenh(0x38);
    ghilenh(0x0e);
    ghilenh(0x80);
    void xoalcd(void)
    { ghilenh(0x01);
    ghilenh(0x80);
    { kiemtra();
    void main(void)
    PORTA=0x00;
    DDRA=0x00;
    PORTB=0x00;
    DDRB=0x00;
    PORTC=0x00;
    DDRC=0x00;
    PORTD=0x00;
    DDRD=0x00;
    // E - PORTD Bit 0
    // RS - PORTD Bit 2
    khoidong();
    xoalcd();
    while (1)
    { gotoxy(0,0);
    for(i=0;i<15;i++)
    ghikitu(ten[i]);
    ghilenh(0xc0);
    for(j=0;j<8;j++)
    ghikitu(lop[j]);
    bạn xem lại :
    sao lại gán kt=0x80 rồi lại while((kt&0x80)==0x80)
    bạn phải đọc cờ bận của LCD rồi so sánh với 0x80
    Sau đây là code kiểm tra cờ bận 8051 với LCD, bạn làm tương tự với AVR:
    void busy_flag (void)
    unsigned char x;
    P2=0XFF; port 2 nối với LCD
    RD_LCD=0; chân RD
    RD_LCD=1; chân WR
    do
    E_LCD=1; chân Enable
    for(j=1;j<=3;j++); delay 3 chu kỳ
    E_LCD=0;
    x=P2; gán x=vào port 2
    x=x&0x80; che bit khôg cần thiết
    while(x=!128); so sánh x với 0x80(=128 Ở hệ 10),nếu x=0x80 tức là LCD đang bận và chờ đến khi hết bận,nếu sai là không bận có thể thao tác với LCD được
    • hungtrinh36
      • Apr 2011
      • 346
      cảm ơn anh nhé em sẽ kiểm tra xem sao,nếu không được em sẽ hỏi thêm
      • hungtrinh36
        • Apr 2011
        • 346
        có ai cho em hỏi sao em dùng lcd 4 bit dùng mấy lệnh có sẵn như putsf char''xxxxxx...." thì hiện bình thường mà dùng đoạn code trên thì ko có 1 chữ nào hiện lên cả,ai chỉ ra chổ sai phần hiện em với
        • vuxuansyhut
          • Jul 2009
          • 303
          Trong codevision avr có thư viện các hàm lcd chạy khá ổn. Nếu bạn muốn tự viết thư viện để hiểu sâu hoạt động của lcd hãy thử tham khảo ở trang này nhé Text LCD .
          Giải pháp điện tử của bạn
          hungtrinh36 Tìm hiểu thêm về hungtrinh36
