LCD 5510 và atmega16
  • voiviqua
    • Jan 2011
    • 141
    có anh nào đã làm được giao tiếp atmega16 với LCD nokia 5510 chưa vậy.cho em xin code với.em đang làm nó mà nó không chạy.
    code của em.
    #include <mega16.h>
    #include <delay.h>
    //#define DC PORTC.1;
    //#define RESET PORTC.2;
    //#define CS PORTC.3;
    // SPI functions
    #include <spi.h>
    // Declare your global variables here
    void spi_gui(unsigned char data)
    PORTC.3=1;
    delay_us(10);
    PORTC.3=0;
    SPDR=data;
    while((SPSR & 0x80)==0);
    PORTC.3=1;
    void LCDWrite(char data_or_command, unsigned char data1)
    if(data_or_command==0) PORTC.1=0;
    else PORTC.1=1;
    PORTC.3=0;
    spi_gui(data1); // Send the data
    PORTC.3=1;
    void gotoXY(int x, int y)
    LCDWrite(0, 0x80 | x); // Column.
    LCDWrite(0, 0x40 | y); // Row.
    void LCDClear() //Clears the LCD by writing zeros to the entire screen
    unsigned int i;
    for (i = 0 ; i < 504 ; i++) LCDWrite(1, 0x00);
    gotoXY(0, 0); //After we clear the display, return to the home position
    void LCDInit(unsigned char contrast,unsigned char coefficent,unsigned char bias) //This sends the magical commands to the PCD8544
    PORTC.2=1; PORTC.3=1; PORTC.1=1; //Configure control pins
    PORTC.2=0; //Reset the LCD to a known state
    PORTC.2=1;
    LCDWrite(0, 0x21); //Tell LCD that extended commands follow
    LCDWrite(0, 0x80 + contrast); //Set contrast (max 127);
    LCDWrite(0, 0x04 + coefficent); //Set Temp coefficent (max 4);
    LCDWrite(0, 0x10 + bias); //LCD bias mode (max 15);
    LCDWrite(0, 0x20); //We must send 0x20 before modifying the display control mode
    LCDWrite(0, 0x0C); //Set display control, normal mode. 0x0D for inverse
    void main(void)
    // Declare your local variables here
    // Input/Output Ports initialization
    // Port A initialization
    // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
    // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
    PORTA=0xff;
    DDRA=0xff;
    // Port B initialization
    // Func7=Out Func6=In Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
    // State7=0 State6=T State5=0 State4=0 State3=T State2=T State1=T State0=T
    PORTB=0x00;
    DDRB=0xB0;
    // Port C initialization
    PORTC=0x00;
    DDRC=0xff;
    // Port D initialization
    PORTD=0xff;
    DDRD=0xff;
    // SPI initialization
    // SPI Type: Master
    // SPI Clock Rate: 2000.000 kHz
    // SPI Clock Phase: Cycle Half
    // SPI Clock Polarity: Low
    // SPI Data Order: MSB First
    SPCR=0x50;
    SPSR=0x00;
    LCDInit(1,0,0);
    LCDClear();
    while (1)
    // Place your code here
    gotoXY(1,2);
    LCDWrite(1,0x55);
    delay_ms(10000);
    các anh xem hộ em xem nó sai ở đâu mà em làm mãi nó không chạy được gì cả.
  • chung1608
    • Sep 2009
    • 4160
    thử viết bằng SPI mềm đi
    • voiviqua
      • Jan 2011
      • 141
      anh nói rõ hơn đi.viết bằng SPI mềm là thế nào a.
      • voiviqua
        • Jan 2011
        • 141
        #4
        • voiviqua
          • Jan 2011
          • 141
          #5
          sao không ai giúp em vậy.
          • chung1608
            • Sep 2009
            • 4160
            #6
            SPI mềm là tự viết SPI bằng code, mình cũng từng làm với 1100 rồi nhưng dùng SPI cứng vẫn ko chạy.
            Code:
             void lcd_write(char MODE,unsigned char c)
             char i;
             cs = 0;
             sclk = 0;
             sda = MODE;
             sclk = 1;
             for(i=0;i<8;i++)
             sclk = 0;
             if(c & 0x80) sda = 1;
             else sda = 0;
             sclk = 1;
             c <<= 1;
             cs = 1;
            • voiviqua
              • Jan 2011
              • 141
              #7
              cảm ơn bạn nhé.mình làm được rồi.
              voiviqua Tìm hiểu thêm về voiviqua
