Duyphi dạo này bị seo thế
. Đang định chỉ cho cái app notes AVR230 nhưng chắc đọc rồi hả.
(AVRProg chạy block mode cũng nhanh không kém thì phải ) !
void main(void)
unsigned char i;
PULLUPPORT = PULLUPPIN; // Pull up on RX line
_UBRRL = (XTAL / (16 * BAUDRATE)) - 1; //set baud rate;
_UCSRB = 0x18; // Rx enable Tx Enable
_UCSRC = 0x86; // Asyn,NoParity,1StopBit,8Bit
#ifdef RS485DDR
RS485DDR |= RS485TXE; // RS485 Tranceiver switch pin as output
RS485PORT &= ~RS485TXE; // RS485 in Rx mode
#endif
do
i = _UDR; // read and ignore data until buffer clear
while(_UCSRA & 0x80);
TxChar('>');
if (RxChar() == '<')
TxChar(DeviceID);
TxChar(FlashSize);
TxChar(BootSize);
TxChar(PageSize);
TxChar(EEpromSize);
TxChar('!');
while (1)
GetPageNumber();
if (RealPageAddress == 0xffff) break;
if (WriteFlash()) TxChar('!');
else TxChar('@');
#ifdef EEPROM
EEpromLoad();
#endif
#ifdef LOCKBIT
LockBit();
#endif
#ifdef RAMPZ_FLAG
RAMPZ = 0;
#endif
#ifdef INTVECREG
INTVECREG = 0x01; // Enable interrupt vector select
INTVECREG = 0x00; // Move interrupt vector to flash
#endif
_UCSRA |= (1<<_TXC);
[COLOR="Red"]TxChar('X');[/COLOR]
[COLOR="Blue"]asm("jmp 0x0000"); // Run application code[/COLOR]
TxChar('X');
void main(void)
unsigned char i;
#ifdef RS485DDR
#endif
do
TxChar('>');
TxChar(DeviceID);
TxChar(FlashSize);
TxChar(BootSize);
TxChar(PageSize);
TxChar(EEpromSize);
TxChar('!');
while (1)
GetPageNumber();
else TxChar('@');
#ifdef EEPROM
EEpromLoad();
#endif
#ifdef LOCKBIT
LockBit();
#endif
#ifdef RAMPZ_FLAG
RAMPZ = 0;
#endif
#ifdef INTVECREG
#endif
TxChar('X');
Pó tay với cái lỗi này. (Các bác đọc xong đừng cười nhé.
Đỡ tốn tiền xăng qua chỗ PNLab.
