Led matran bị giật xin giúp đỡ!
  • sunbin
    Banned
    • Aug 2011
    • 55
    mọi người xem rùi cho ý kiến ha mình post video va code len luon tại sao nó chạy mà cứ bị giật giật chạy không đều làm sao cho nó hết giật hả các huynh
    DSCN0292 - YouTube
    #include <REGX51.H>
    #include "font.h"
    #define scan_led P2
    //////THIET LAP BAN DAU//////
    #define so_led 2 //boi cu?a 8
    #define so_hang 16 //chieu cao cua font chu
    #define multi so_hang+1 //
    #define cot_font 11 //chieu ngang cua font chu
    #define en_run 1 //1: chay <----> 0 dung
    typedef unsigned char uchar;
    typedef unsigned int uint;
    sbit rck=P3^2;
    sbit srck=P3^0;
    sbit ser_in=P3^1;
    sbit en_hc154=P3^3;
    int run=0,en=en_run;
    idata uchar display_buffer[so_hang][so_led];
    idata uchar shift_buffer[so_hang];
    uchar row_buffer[16]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
    uchar row_led[16]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
    uchar tocdoh=0xf6,tocdol=0xd3;
    uchar kitu_code=0;
    char row=multi;
    void shift_dataled();
    //void test_led();
    void clear_buffer();
    void run_string();
    void copy_datacode();
    void scan_dataled_code();
    void init_interrupt();
    ///////ngat timer 0////////////
    void isr_timer0() interrupt 1 using 1
    //clear_buffer();
    TH0=tocdoh,TL0=tocdol;
    if(--row==-1) row=multi-1;
    shift_dataled();
    if(row==so_hang)run=1;
    /////////chuong trinh chinh/////
    void main()
    uchar w;
    init_interrupt();
    //test_led();
    clear_buffer();
    if(en==0) scan_dataled_code();
    while(1)
    if((run==1)&(en==1)){
    IE&=0xfd;
    run_string(),run=0;
    if(++w==8) copy_datacode(),w=0;
    row=so_hang;
    IE|=0x02;
    ////////kiem tra led////////////
    /*void test_led()
    uchar i,j;
    uint t_delay=100;
    for(i=0;i<so_hang;i++)
    for(j=0;j<so_led;j++)
    display_buffer[i][j]=0xff;
    while(--t_delay);
    void clear_buffer()
    char i,j;
    for(i=0;i<so_led;i++)
    for(j=0;j<8;j++){
    ser_in=0;
    srck=1;
    srck=0;
    en_hc154=1;
    rck=1;
    rck=0;
    scan_led=row_led[row];
    en_hc154=0;
    ///////dich data va quet led////
    char i,j;
    srck=0;
    rck=0;
    if(row<so_hang){
    for(j=0;j<8;j++){
    ser_in=display_buffer[row][i]&row_buffer[7-j];
    srck=1;
    srck=0;
    en_hc154=1;
    rck=1;
    rck=0;
    en_hc154=0;
    uchar i;
    static uchar j;
    shift_buffer[i]=Bmp002[Bmp002[2]*i+3+j];
    if(++j==Bmp002[2]) j=0;
    ////////chay chuoi//////////////
    void run_string()
    uchar i,j;
    display_buffer[i][j]<<=1;
    if(j!=(so_led-1)) display_buffer[i][j]|display_buffer[i][j+1]&0x80)>>7);
    else display_buffer[i][j]|shift_buffer[i]&0x80)>>7);
    shift_buffer[i]<<=1;
    uchar i,j;
    for(i=0;i<so_hang;i++){
    for(j=0;j<so_led;j++){
    display_buffer[i][j]=Bmp002[Bmp002[2]*i + 3+j];
    //////khoi dong ngat////////////
    TMOD=0x01; //timer0 che do 1 16b
    TH0=0xF8;
    TL0=0x30;
    TR0=1;
    TR1=1;
    IE=0x82; //cho phep ngat timer0
  • sunbin
    Banned
    • Aug 2011
    • 55
    sao không ai tra loi zay ta lam on giup gium voi minh dang can gap lam
    • nguyentot90
      • Mar 2011
      • 488
      Hic sao ko hiểu là chử j vậy ta. code C mìnnh ko biết. Còn chuyện giật vậy tại delay còn chậm quá. sửa code delay lại cho nhanh hơn nữa.
      • quynhnb
        • Aug 2009
        • 696
        Chỉnh lại thời gian quét xem nào. Nên nhớ nguyên tắc quét phải đáp ứng sinh lý của mắt người đó là 24 hình / giây.
        Mr.Quỳnh 0978706839
        • daiacma_ts
          • Sep 2011
          • 1
          bạn quynhnb nói đúng đấy.bạn chỉnh lại thời gian quét nhỏ thôi để mắt mình không nhìn thấy nhấp nháy của led.
          thân !
          • thanhlamng
            • May 2010
            • 22
            Hoa cả mắt chóng cả mặt
            *** Lam Nguyen ***
            • thanhlamng
              • May 2010
              • 22
              thời gian delay của chú có vẽ chưa hợp lý lắm thì phải, thử giảm thời gian delay rồi tăng số lần quét lên
              *** Lam Nguyen ***
              • consts
                • Apr 2012
                • 222
                #8
                có ai ở đà lạt k? nap giúp mình chuong trinh cho con 89C51 voi, ai giúp được thì pm mình với,
                nick minh la duyngokne329@yahoo.com.vn, cam on nhieu.
                • vimibi
                  • Apr 2010
                  • 3
                  #9
                  Nguyên văn bởi consts Xem bài viết
                  Bạn nào ở Đà Lạt, muốn nạp Code 89C051 vui lòng liên hệ vimibi@gmail.com.
                  sunbin Tìm hiểu thêm về sunbin
