Code chương trình dèn giao thông
  • taituan102
    • Sep 2008
    • 10
    ;Khai bao port va bit
    P_LED DATA P0 ;port du lieu LED7seg
    P_ADD DATA P2 ;port dia chi LED7seg
    P_LIGHT DATA P1 ;port tin hieu den
    ;PORT_p1
    RED1 BIT P1.0 ;thu tu cac LED don
    YELLOW1 BIT P1.1
    GREEN1 BIT P1.2
    RED2 BIT P1.3
    YELLOW2 BIT P1.4
    GREEN2 BIT P1.5
    ;PORT_p1
    LED1A_ADD BIT P2.0 ;thu tu cac LED7seg
    LED1B_ADD BIT P2.1
    LED2A_ADD BIT P2.2
    LED2B_ADD BIT P2.3
    ;Khai bao cac bien
    BSEG AT 10H
    DSEG AT 20H
    ;Bien gia tri cac LED
    LED1: DS 1 ;gia tri LED1
    LED2: DS 1 ;gia tri LED2
    ;Bien quet LED
    LOOP_VALUE: DS 1 ;so vong lap quet LED
    ;Bien HEX2DEC
    CHUC: DS 1 ;so hang chuc
    DONVI: DS 1 ;so hang don vi
    CSEG AT 00H
    ORG 0000h
    LJMP MAIN
    ;Khai bao cac hang so
    RED_TIME EQU 33;thoi gian den do 33s
    YELLOW_TIME EQU 03;thoi gian den vang 3s
    GREEN_TIME EQU 30;thoi gian den xanh 30s
    ;Chuong trinh chinh
    MAIN:
    ;Khoi tao cac port
    MOV P2,#0ffh
    MOV P0,#0ffh
    MOV P1,#0ffh
    ;Khoi tao gia tri ban dau cua cac bien
    MOV LED1,#0
    MOV LED2,#0
    MOV LOOP_VALUE,#25 ;so vong lap quet LED
    MOV CHUC,#0
    MOV DONVI,#0
    ;Vong lap chinh
    MAIN_LOOP:
    ;LED1: Do 33 LED2:Xanh 30
    MOV LED1,#33;nap thoi gian ban dau
    MOV LED2,#30
    setb RED1 ; bat den do, den xanh
    setb GREEN2
    LOOP1A: ;giam gia tri thoi gian
    CALL SCANLED
    DEC LED1
    DJNZ LED2,LOOP1A
    clr GREEN2 ;tat den xanh
    ;LED1: Do 30 LED2:Vang 30
    MOV LED2,#3 ; nap thoi gian ban dau
    setb YELLOW2 ;giu den do, bat den vang
    LOOP1B: ;giam gia tri thoi gian
    CALL SCANLED
    DEC LED1
    DJNZ LED2,LOOP1B
    clr RED1 ;tat den do
    clr YELLOW2 ;tat den vang
    ;LED1:Xanh 0-24 LED2: Do 33-3
    MOV LED2,#33 ; thoi gian ban dau
    MOV LED1,#30
    setb RED2 ; bat den do, den xanh
    setb GREEN1
    LOOP2A: ;giam gia tri thoi gian
    CALL SCANLED
    DEC LED2
    DJNZ LED1,LOOP2A
    clr GREEN1 ;tat den xanh
    ;LED1: Vang 4-0 LED2: Do 4-0
    MOV LED1,#3 ; nap thoi gian ban dau
    setb YELLOW1 ;giu den do, bat den vang
    LOOP2B: ;giam gia tri thoi gian
    CALL SCANLED
    DEC LED2
    DJNZ LED1,LOOP2B
    clr RED2 ;tat den do
    clr YELLOW1 ;tat den vang
    LJMP MAIN_LOOP ;vong lap lien tuc
    ;Chuong trinh quet LED
    SCANLED:
    ;LED 1
    MOV A,LED1 ;nap gia tri LED1
    CALL HEX2DEC ;tach so
    MOV A,CHUC ;hang chuc LED1
    CALL CODE7SEG
    MOV P_LED,A
    clr LED1A_ADD
    CALL DELAY01ms_1
    setb LED1A_ADD
    MOV A,DONVI ;quet hang don vi LED1
    CALL CODE7SEG
    MOV P_LED,A
    clr LED1B_ADD
    CALL DELAY01ms_1
    setb LED1B_ADD
    ;LED2
    MOV A,LED2 ;nap gia tri LED2
    MOV A,CHUC ;quet hang chuc LED2
    CALL CODE7SEG
    MOV P_LED,A
    clr LED2A_ADD
    CALL DELAY01ms_1
    setb LED2A_ADD
    MOV A,DONVI ;quet hang don vi LED2
    CALL CODE7SEG
    MOV P_LED,A
    clr LED2B_ADD
    CALL DELAY01ms_1
    setb LED2B_ADD
    DJNZ LOOP_VALUE,SCANLED
    MOV LOOP_VALUE,#25
    RET
    ;Chuong trinh HEX to DEC - Tach so ra thanh dang CHUC-DONVI
    ;Mo ta: - Dua gia tri can tach vao A - Ket qua CHUC va DONVI
    HEX2DEC:
    MOV B,#10
    DIV AB
    MOV CHUC,A
    MOV DONVI,B
    RET
    ;Chuong trinh hien thi LED7seg
    ;Mo ta: Dua gia tri can quet vao A - Ket qua tra ve A
    CODE7SEG:
    MOV DPTR,#TBL
    MOVC A,@A+DPTR
    RET
    TBL: DB 0C0H,0F9H,0A4H,0B0H,099H,092H,082H,0F8H,080H,090H ;anode chung
    ;Chuong trinh delay 10ms
    DELAY01:
    mov r1,#20h
    DELAY01MS_1:
    MOV R2,#100h
    DJNZ R2,$
    DJNZ R1,DELAY01MS_1
    RET
    END
  • taituan102
    • Sep 2008
    • 10
    em viết cái này xuất mức cao nha, mới cấp nguồn vào thì nó đếm thời gian dúng, ngưng tất cả các đèn đều sáng.em muốn nó mới vào thì đèn đỏ với xanh sáng.bác nao biết sai chổ nào giúp em với.thx
    mail: taituan102@gmail.com
    • dt_love
      • Feb 2007
      • 509
      Nguyên văn bởi taituan102 Xem bài viết
      ;PORT_p1
      YELLOW1 BIT P1.1
      GREEN1 BIT P1.2
      RED2 BIT P1.3
      YELLOW2 BIT P1.4
      GREEN2 BIT P1.5
      ;PORT_p1
      LED1B_ADD BIT P2.1
      LED2A_ADD BIT P2.2
      LED2B_ADD BIT P2.3
      ;Khai bao cac bien
      BSEG AT 10H
      DSEG AT 20H
      ;Bien quet LED
      ;Bien HEX2DEC
      CSEG AT 00H
      ORG 0000h
      LJMP MAIN
      ;Chuong trinh chinh
      MAIN:
      ;Khoi tao cac port
      MOV P2,#0ffh
      MOV P0,#0ffh
      MOV P1,#0ffh
      MOV LED1,#0
      MOV LED2,#0
      MOV CHUC,#0
      MOV DONVI,#0
      ;Vong lap chinh
      MAIN_LOOP:
      MOV LED2,#30
      setb GREEN2
      CALL SCANLED
      DEC LED1
      DJNZ LED2,LOOP1A
      CALL SCANLED
      DEC LED1
      DJNZ LED2,LOOP1B
      MOV LED1,#30
      setb GREEN1
      CALL SCANLED
      DEC LED2
      DJNZ LED1,LOOP2A
      CALL SCANLED
      DEC LED2
      DJNZ LED1,LOOP2B
      SCANLED:
      ;LED 1
      CALL CODE7SEG
      MOV P_LED,A
      clr LED1A_ADD
      CALL DELAY01ms_1
      setb LED1A_ADD
      CALL CODE7SEG
      MOV P_LED,A
      clr LED1B_ADD
      CALL DELAY01ms_1
      setb LED1B_ADD
      ;LED2
      CALL CODE7SEG
      MOV P_LED,A
      clr LED2A_ADD
      CALL DELAY01ms_1
      setb LED2A_ADD
      CALL CODE7SEG
      MOV P_LED,A
      clr LED2B_ADD
      CALL DELAY01ms_1
      setb LED2B_ADD
      MOV LOOP_VALUE,#25
      RET
      HEX2DEC:
      MOV B,#10
      DIV AB
      MOV CHUC,A
      MOV DONVI,B
      RET
      CODE7SEG:
      MOV DPTR,#TBL
      MOVC A,@A+DPTR
      RET
      DELAY01:
      mov r1,#20h
      DELAY01MS_1:
      MOV R2,#100h
      DJNZ R2,$
      DJNZ R1,DELAY01MS_1
      RET
      END
      bạn dk mức cao, mà vào ctr bạn lại cho nó lên mức 1 thì bảo sao nó ko sáng hết dc?
      mình ko đọc hết nhưng bạn nên sửa chỗ này lại, hoặc là sau đoạn này, bạn cho tắt tất cả các led trc khi chạy ctrinhf.
      taituan102 Tìm hiểu thêm về taituan102
