Nguyên văn bởi 207.207
download từ ieee
Bạn taolao ơi down giùm tớ cái này nhé.
Cảm ơn bạn nhiều.
Link: http://ieeexplore.ieee.org/Xplore/lo...3B+Cihlar%2C+J.
Development of a robust haze removal algorithm: assessment using temporally invariant targetsYing Zhang; Guindon, B.; Cihlar, J.
Geoscience and Remote Sensing Symposium, 2002. IGARSS apos;02. 2002 IEEE International
Volume 1, Issue , 2002 Page(s): 101 - 103 vol.1
Digital Object Identifier 10.1109/IGARSS.2002.1024954
Summary: A robust haze-removal algorithm based on the Haze Optimized Transformation (HOT) is applied to ETM+ imagery. Its effectiveness is evaluated using temporally invariant targets identified in a multi-temporal data set of scenes of WRS-2 Path15/Row29. In the data set, clear scenes serve as 'benchmarks' against which the effectiveness of haze removal can be assessed. In the quantitative assessment, two hundred coniferous forest patches were randomly sampled and served as 'benchmark' targets since they exhibit both spatial and temporal radiometric invariance on clear data. Comparisons were made of the radiometric characteristics of the patch population in hazy vs. de-hazed and de-hazed vs. clear image pairs. Results show that image contaminated by low to moderate haze can be significantly improved. Reductions of 20 to 90% in intra-scene radiometric dispersion have been achieved with the de-hazed scenes exhibiting residual dispersion levels comparable to those of the benchmark scenes.
Bác taolao có thể lấy giùm e mấy tiêu chuẩn sau đây được ko:
1. IEEE Std 1048-1990: Hướng dẫn của IEEE cho việc bảo vệ chạm đất các đường dây tải điện - IEEE guide for protective grounding of power lines.
http://ieeexplore.ieee.org/Xplore/lo...799.pdf?temp=x
2. IEEE Std 1036-1992: Hướng dẫn của IEEE cho việc ứng dụng các tụ công suất bù ngang - IEEE guide for application of shunt power capacitors.
http://ieeexplore.ieee.org/Xplore/lo...735.pdf?temp=x
3. IEEE Std 1019-2004 (Revision of IEEE Std 1019-1991): Khuyến nghị của IEEE cho các thông số kỹ thuật của cáp chôn ngầm - Cách điện Polypropylene - IEEE Recommended Practice for Specifying Electric Submersible Pump Cable-Polypropylene Insulation
http://ieeexplore.ieee.org/Xplore/lo...number=1425767
4. IEEE Std 1124-2003: Hướng dẫn cho việc phân tích và xác định sóng hài một chiều của hệ thống truyền dẫn HVDC - IEEE guide for the analysis and definition of DC-side harmonic performance of HVDC transmission systems
http://ieeexplore.ieee.org/Xplore/lo...number=1237536
Thanks bác nhiều
DownloadPhen này ông quyết buôn băng dính,
Vừa bán vừa hm... hm... cũng đắt hàng.
Bac down giup minh tai lieu nay nhe, minh dang can lam, gui qua mail dum minh. Chan thanh cam onNguyên văn bởi jefflieu Xem bài viếtNhieu lam, chiu kho' search di roi chi ra chinh xac tai lieu na`o roi Jeff down cho ....
my mail: quoc_tho2003@yahoo.com
link: http://ieeexplore.ieee.org/xpl/freea...rnumber=502360
Doubly fed induction generator using back-to-back PWM convertersand its application to variable-speed wind-energy generation
Pena, R. Clare, J.C. Asher, G.M.
Dept. of Electr. & Electron. Eng., Nottingham Univ.;
This paper appears in: Electric Power Applications, IEE Proceedings -
Publication Date: May 1996
Volume: 143, Issue: 3
On page(s): 231-241
ISSN: 1350-2352
References Cited: 21
CODEN: IEPAER
INSPEC Accession Number: 5292558
Posted online: 2002-08-06 20:26:09.0
Abstract
The paper describes the engineering and design of a doubly fed induction generator (DFIG), using back-to-back PWM voltage-source converters in the rotor circuit. A vector-control scheme for the supply-side PWM converter results in independent control of active and reactive power drawn the supply, while ensuring sinusoidal supply currents. Vector control of the rotor-connected converter provides for wide speed-range operation; the vector scheme is embedded in control loops which enable optimal speed tracking for maximum energy capture from the wind. An experimental rig, which represents a 7.5 kW variable speed wind-energy generation system is described, and experimental results are given that illustrate the excellent performance characteristics of the system. The paper considers a grid-connected system; a further paper will describe a stand-alone system
hic, ko biết lấy gì cảm ơn bác đây, giá như bác ở Đà Nẵng thì e có dịp hậu tạ. Luôn tiện bác down thêm giùm e mấy cái tiêu chuẩn nữa được ko?
http://ieeexplore.ieee.org/Xplore/lo...number=1277892
http://ieeexplore.ieee.org/Xplore/lo...619.pdf?temp=x
http://ieeexplore.ieee.org/iel1/3273...rnumber=467494
http://ieeexplore.ieee.org/Xplore/lo...number=1194457
http://ieeexplore.ieee.org/xpl/freea...&punumber=5076
http://ieeexplore.ieee.org/Xplore/lo...294.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...661.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1315281
http://ieeexplore.ieee.org/Xplore/lo...003.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1424424
http://ieeexplore.ieee.org/Xplore/lo...rnumber=863650
http://ieeexplore.ieee.org/Xplore/lo...837.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1225051
http://ieeexplore.ieee.org/Xplore/lo...number=1355860
http://ieeexplore.ieee.org/Xplore/lo...number=1042562
http://ieeexplore.ieee.org/Xplore/lo...number=1203094
http://ieeexplore.ieee.org/Xplore/lo...rnumber=916616
http://ieeexplore.ieee.org/iel1/2900...rnumber=182873
http://ieeexplore.ieee.org/xpl/stand...?isnumber=5491
http://ieeexplore.ieee.org/Xplore/lo...976.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...620.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...rnumber=475522
http://ieeexplore.ieee.org/Xplore/lo...arnumber=30653
http://ieeexplore.ieee.org/Xplore/lo...number=1033175
http://ieeexplore.ieee.org/xpl/freea...number=4014492
http://ieeexplore.ieee.org/xpl/freea...number=1519743
http://ieeexplore.ieee.org/Xplore/lo...985.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...923.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...481.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...768.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1611106
http://ieeexplore.ieee.org/Xplore/lo...rnumber=875997
http://ieeexplore.ieee.org/Xplore/lo...number=1605067
http://ieeexplore.ieee.org/Xplore/lo...977.pdf?temp=x
Thanks bác trước
Nhờ download tài liệu IEEEXPLORE
Bạn Taolao oi giúp minh cái này với :
Measuring asymmetric link bandwidths in Internet using a multi-packet delay model
Yu Lin; Haitao Wu; Shiduan Cheng; Wenyan Wang; Chonggang Wang
Communications, 2003. ICC apos;03. IEEE International Conference on
Volume 3, Issue , 11-15 May 2003 Page(s): 1601 - 1605 vol.3
Digital Object Identifier 10.1109/ICC.2003.1203872
Summary: Accurate measurement of network bandwidth is crucial for many flexible Internet applications and protocols. Based on a new multi-packet delay model, this paper presents a new algorithm called ALBP (asymmetric link bandwidth probing) to measure each hop's link bandwidth in both directions in an IP network, and uses the kernel density estimator to produce a final estimate. Compared with previous techniques, ALBP can eliminate (at least partially) the errors introduced by ICMP replies through the use of interarrival time of two probing packets, and avoid the problem of error accumulation. Simulation results show that ALBP is usually more accurate than both one-packet and packet tailgating techniques, and the bandwidth consumption of ALBP is close to that of packet tailgating.
Cảm ơn nhiều nhiều
Wind Energy
On page(s): 231-241
ISSN: 1350-2352
CODEN: IEPAER
Abstract
Download hereNguyên văn bởi 207.207 Xem bài viếtBạn Taolao oi giúp minh cái này với :
Cảm ơn nhiều nhiềuPhen này ông quyết buôn băng dính,
Download hereNguyên văn bởi thotran Xem bài viếtBac down giup minh tai lieu nay nhe, minh dang can lam, gui qua mail dum minh. Chan thanh cam on
Trả lời cho Máy đo khuôn mẫubởi vi van phamQuá dễ, Mua cái máy xq quét tòan thân, lấy bàn và khung di chuyển. Tháo đầu xquang ra bán ve chai, mua cái máy siêu âm gắn vào vị trí đầu đèn. Setup máy là chạy chính xác, còn file Setup thì chưa nghĩ ra....
Channel: Đo lường và điều khiển dùng máy tính
07-06-2026, 08:49 -
Trả lời cho Máy Phun sương tạo ầm Trung Quốc.bởi nguyendinhvanMạch tạo sương là tự dao động.
Mach 555 là đóng mở chu kỳ tần số thấp.
IC 555 giá rẻ, chỉ chạy lên tần số vài trăm ki lô hẹc thôi. Thăng cao hơn là méo dạng rồi tịt.
Mach sương thì dao động tần số tầm 2 mê ga hẹc cơ !...-
07-06-2026, 00:09 -
Cái máy đo này mắc tiền quá !
Anh em dtvn có giải pháp nào tự chế được không ?...-
07-06-2026, 00:00 -
bởi nguyendinhvanOi giời.
Thơi buổi PLC rồi, cậu còn hỏi mấy thứ cổ lỗ sĩ này nữa.-
06-06-2026, 22:59 -
bởi nguyendinhvanChuyện này cũ rồi.
Họ trả lương cho CN, sau đó lại bán hàng thu tiền về. Họ còn cấp các dịch vụ như chỗ ăn ở, quán cafe , giải trí, phương tiện giao thông. Mục đích là thu tối đa số tiền đã chi trả.
Hàng hóa sx ra, chuyển...-
Channel: Tìm mua
06-06-2026, 22:56 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi vi van phambao nhiêu năm quên bẳng đi, là mình còn có 1 chút xíu nghệ thuật bài bản, đã dạy cho con cháu chơi đàn, dù bố mẹ và chúng không xem là quan trọng. Hôm qua ngày bế mạc lớp lá, bỗng dưng thằng cháu ngoại thấy con bé được sơ giới thiệu...
06-06-2026, 21:58 -
bởi ittcChào các anh em, tình hình là mình lo làm ăn không để ý sức khỏe, giờ có chút vấn đề rồi? không biết trên này có anh em nào độ tuổi U35 -> 40 đang có dùng các loại thuốc, thuốc bổ hay thực phẩm chức năng giúp bổ thận tráng dương,...
05-06-2026, 12:28 -
bởi theidiotcatTrong thế giới phần cứng năm 2026, AMD Ryzen 5 7500X3D không chỉ là một cái tên mới, nó là một tuyên ngôn về hiệu suất. Dựa trên các thử nghiệm khắt khe trong môi trường chơi game chuyên nghiệp, con chip này đã chứng minh rằng: bạn không cần...
05-06-2026, 10:05 -
bởi VinhPham92Chào các bác,
Em vừa dự một cái Odoo Business Show 2026 tuần rồi, ngồi nghe mấy session về tự động hóa sản xuất mà em thấy có vài điểm thấy đáng chia sẻ với mấy anh em làm kỹ thuật ở đây.
Câu hỏi của các doanh nghiệp.
Hôm đấy đi thì các doanh...-
Channel: Lập trình PLC và ứng dụng
05-06-2026, 09:18 -
bởi quang4789Mình có cái tay chuyển số chơi game của PXN, hiệu là PXN shifter A7, nó bị lỗi 1 con biến trở chỗ gạt lên xuống dùng để xác định là đang đẩy lên, ở giữa, hay gạt về. Con biến trở này giá trị là 10kOhm, sau khi bị hư thì mình đo chỉ...
03-06-2026, 12:04 -
