Các bạn ơi giúp mình Download các bài báo này với! Mình đang rất rất rất ...cần!
Cảm ơn các bạn trước nhé!
1. Fault location scheme for a multi-terminal transmission line using synchronized voltage measurements
2. Fault Location on a Transmission Line Using Synchronized Voltage Measurements
3. Distance protection and fault location utilizing only phase current phasors
4. Fault location using the distributed parameter transmission line model
5. Transmission line protection based on wavelet transform
6. Fault location in transmission lines using one terminal post fault voltage data
7. Development of a new type fault locator using the one terminal voltage and current data
8. ANN-based techniques for estimating fault location on transmission lines using Prony method
9. Fault location on two-terminal transmission lines based on voltages
(Rất)^3 cần thì bạn cũng làm ơn cho cái link, không ai có thời gian đi tìm hộ bạn được.
