SIMATIC WinCC flexible 2007
  • vaiduakhu
    • Apr 2007
    • 41
    Greater Performance,
    more Panels, increased Productivity
    SIMATIC WinCC flexible is the innovative HMI software under Windows for all machine-oriented and process-oriented applications of the machine, series machine and plant construction. The engineering software enables the integrated configuration of all HMI operator devices ranging from the Micro Panel up to the PC-based visualization -all of this with the highest level of configuration efficiency.
    The new SIMATIC WinCC flexible 2007 version comes up with a couple of interesting innovations
    On this page:
    Performance optimization in the Engineering
    • Central user administration with SIMATIC LOGON
    • New operator interfaces and Soft-PLC SIMATIC WinAC MP
    • Funcion expansions for the smaller Panels
    • New communication possibilities
    Performance Increase for the Engineering
    WinCC flexible 2007 2007 contains extensive optimizations, which further increase the performance of the Engineering. The new version, for example, reduces the generation time of a project by avoiding complete generation runs as far as possible in favor of a delta compilation.
    Furthermore, if there are multiple devices in a project, each one can be generated separately.
    In the integrated mode, WinCC flexible and STEP7 now work even faster, for example when opening an HMI project from STEP7 or when creating, copying or deleting an HMI device.
    The WinCC flexible setup as well was made faster thanks to an optimized installation scope. The user now only installs those programs, which he or she needs for the work with WinCC flexible.
    Code:
    http://rapidshare.com/files/50126994/WinCC_flex_CSA.part01.rar
    http://rapidshare.com/files/50278103/WinCC_flex_CSA.part02.rar
    http://rapidshare.com/files/50127443/WinCC_flex_CSA.part03.rar
    http://rapidshare.com/files/50278228/WinCC_flex_CSA.part04.rar
    http://rapidshare.com/files/50127912/WinCC_flex_CSA.part05.rar
    http://rapidshare.com/files/50128180/WinCC_flex_CSA.part06.rar
    http://rapidshare.com/files/50128378/WinCC_flex_CSA.part07.rar
    http://rapidshare.com/files/50278661/WinCC_flex_CSA.part08.rar
    http://rapidshare.com/files/50128808/WinCC_flex_CSA.part09.rar
    http://rapidshare.com/files/50129053/WinCC_flex_CSA.part10.rar
    http://rapidshare.com/files/50129259/WinCC_flex_CSA.part11.rar
    http://rapidshare.com/files/50129543/WinCC_flex_CSA.part12.rar
    http://rapidshare.com/files/50129744/WinCC_flex_CSA.part13.rar
    http://rapidshare.com/files/50278790/WinCC_flex_CSA.part14.rar
    http://rapidshare.com/files/50130606/WinCC_flex_CSA.part15.rar
    http://rapidshare.com/files/50130824/WinCC_flex_CSA.part16.rar
    http://rapidshare.com/files/50131018/WinCC_flex_CSA.part17.rar
    http://rapidshare.com/files/50326549/WinCC_flex_CSA.part18.rar
    http://rapidshare.com/files/50315479/WinCC_flex_CSA.part19.rar
    http://rapidshare.com/files/50327193/WinCC_flex_CSA.part20.rar
    WinCC flexible 2007 complete DVD
    MultiLanguage with ASIA support
    Only for W2k SP4 and XP SP2
    19 x 97,7MB + 13,5MB
  • nghaiha
    • Jul 2006
    • 744
    Mục đích của cái Flexible là gì? có giống cái WinCC thông thường không? Em cài thử cái Flex 2005 lên, thấy giao diện lạ hoắc không biết đường nào mà lần.
    Em thấy mấy cái HMI của Siemens có dùng cái Flex và Protool để config cho nó. Như vậy cái Flex và Protool có mục đích khác à?
    Email: - Mobil: tạm thời ngừng liên lạc 1 thời gian
    • HPECOM
      • Oct 2005
      • 361
      Theo tôi đựoc biết, WinCC Flexible dùng để thiết kế cho màn hình cảm ứng, nó có thể giả lập để chạy bằng PC nhưng đòi hỏi PC phải rất mạnh. Protool, Protool pro dùng cho các màn hình Text, và các màn hình cảm ứng nhỏ.
      Một bông hồng cho những ai đang còn mẹ,
      Đang còn mẹ để lòng vui sướng hơn ..
      • sad_eye
        • Aug 2007
        • 22
        bạn HPECOM dùng bản wincc6.0 dùng ***** sp2 phải ko?
        Theo mình được biết bản wincc flexible 2005 này chạy trên nền net frame work, có lẽ tương tự như dot net.
        Bạn nào biết có thể nói rõ hơn về wincc flexible ko?Và ta nên dùng cái mới này chủ yếu vào ứng dụng jì?
        • HueDN
          • Jan 2006
          • 317
          Bản WinCC Flexible 2007 này OK. Bạn tải về dùng.
          Nhưng mình thấy Protool là vừa rồi, nó cũng có phần RT mô phỏng tốt.
          Các loại màn hình lớn giá cả rất đắt khó mó tới.
          Ngay cả HMI TP 170B mono (dùng protool lập trình cho nó cũng được) giá đã mười mấy triệu, choán, đừng nói chi tới mấy màn hình màu.
          Bản WF2007 cài vào nó choán hết hơn 1G ổ cứng.
          • sad_eye
            • Aug 2007
            • 22
            Bản demo của wincc 2007 thì trong trang của siemens có cho down đấy, cả hướng dẫn,nhưng thú thật là mình vẫn chưa biết điểm khác nhau cơ bản nhất của nó với bản wincc6.0 mà thiên hạ hay dùng.Điểm hơn hẳn của wincc2007 so với wincc6.0 là gì nhỉ, có phải chỉ là nhanh hơn so với 6.0 và lập trình cho màn hình cảm ứng ko?
            Và ứng dụng của nó ở Việt Nam có phổ biến ko?vào việc gì?
            Cao thủ nào biết chỉ giáo chút làm định hướg cho anh em mới vào đời wincc.
            • vaiduakhu
              • Apr 2007
              • 41
              Có ai đọc phần giới thiệu tiếng Anh tôi post không vậy?
              • sad_eye
                • Aug 2007
                • 22
                #8
                Hehe.Sau một hồi tìm hiểu về thằng wincc flexible bạn đã có kết luận sau:
                *Cài cực dễ.Mô fỏng cực đơn jản. ko lằng nhằng nhứ chú 6.0, cứ nhét đĩa vào là next đều tay.Đây là điểm cực mạnh cho những pác nào mới vào nghề wincc.
                *Giao diện trên nền dot net jống hệt VB.net, dùng cực dễ, cách thức kết nối dễ dàng và trực quan hơn nhiều.Hỗ trợ tiếng việt thôi rồi
                *Hỗ trợ thiết kế cho cả các giao diện với cả các thiết bị HMI với sự đa dạng
                *Kết nối với rất nhiều loại, nhiều hãng(xem mục communication biết liền)
                Bây jờ anh em có thể thảo luận về vấn đề flexible được chứ?
                .Pác vaiduakhu cao thủ cầm trịch đi.
                đã bạn nào biết cách nhúng exel như 6.0 chưa?à cả vẽ đồ thị nữa.
                à quan trọng là có cao thủ nào có licence của thằng này chưa?Ta có thể cùng nhau trao đổi trực tiếp kinh nghiệm cũng như licence, my yahoo+nick: thesad77@yahoo.com
                • SIMATIC
                  • Sep 2007
                  • 2
                  #9
                  WinCC Flexible được dùng để config các thế hệ màn hình OP/TP mới của SIEMENS và là công cụ thay cho Protool sẽ không còn phát hành nữa (bản cuối cùng là Protool 6.0 SP3). Chẳng hạn nếu như trước đây ta config TP170A bằng Protool thì màn hình thay thế cho TP170A là TP177A sẽ được config bằng WinCC Flexible.
                  WinCC 6.0 dùng trong hệ thống SCADA lớn và có nhiều tuỳ chọn như WinCC Server, WinCC Redundant, Web navigator,...
                  WinCC Flexble chỉ dùng config cho các HMI vận hành tại các công đoạn nào đó trong 1 dây chuyền sản xuất, và có thể dùng WinCC Runtime cho máy tính thông thường mà không nhất thiết phải dùng OP/TP của SIEMENS.
                  • sad_eye
                    • Aug 2007
                    • 22
                    #10
                    Nguyên văn bởi SIMATIC Xem bài viết
                    Nói vậy flexible chỉ dùng cho ứng dụng phạm vi nhỏ thôi bạn?Mình thấy cách giao diện flexible là một bước phát triển về sự thuận tiện cũng như thẩm mỹ so với wincc 6.0, tính năng khá đủ và giống 6.0.Vậy mà nó lại kém so với 6.0 à?Bạn có vẻ biết khá rõ, có thể nói rõ hơn ko?Tại sao nó lại ko thể dùng cho hệ thống lớn?Ưu điểm lớn nhất của nó chỉ là "dùng WinCC Runtime cho máy tính thông thường mà không nhất thiết phải dùng OP/TP của SIEMENS" thôi sao?
                    Mình rất thắc mắc rốt cuộc ta nên dùng cái gì đây?(với nhu cầu fục vụ đồ án )
                    • SIMATIC
                      • Sep 2007
                      • 2
                      #11
                      [QUOTE=sad_eye;61088]
                      Ngay trong catalog của SIEMENS cũng định nghĩa rõ 2 khái niệm:
                      SIMATIC WinCC flexible engineering software:
                      SIMATIC WinCC flexible Micro/Compact/Standard/Advanced
                      are innovative engineering tools for configuring SIMATIC HMI
                      devices, the operating component of SIMATIC C7 devices, the
                      SIMOTION/SINUMERIK Panel PCs, and the PC-based visualization
                      system WinCC flexible Runtime.
                      SIMATIC WinCC SCADA system:
                      SIMATIC WinCC is designed for visualizing and operating processes,
                      production flows, machines and plants. With its powerful
                      process interfaces (to the SIMATIC range in particular) and secure
                      data archiving, WinCC provides fault-tolerant solutions for
                      instrumentation and control.
                      Mình đã thấy rất nhiều đồ án tốt nghiệp của ĐHBK HN đều viết bằng WinCC và PCS7 (WinCC based). Lời khuyên cho bạn -> WinCC 6.2
                      • sad_eye
                        • Aug 2007
                        • 22
                        #12
                        Thực ra mình lúc đầu học wincc thì đâm luôn vào flexible chưa làm cả 2 cái nên chưa có cái nhìn tổng wan.Bạn simatic có khẳng định flexible ko thể giám sát và điều khiển cho toàn bộ nhà máy mà chỉ môt công đoạn của dây chuyền.Có thể giải thích rõ hơn vì sao ko?nó thiều gì ở thằng Win6.0?Bạn nào có ý kiến gì thêm ko.flexible ko chỉ lập trình cho các thiết bị HMI mà cho cả PC khi chạy runtime.Thế wincc6.0 cũng dùng cho HMI được còn PC thế nào ? tại sao ko dùng cho PC thường được?
                        Rất mong được chỉ bảo thêm về thực tế.
                        • vaiduakhu
                          • Apr 2007
                          • 41
                          #13
                          Đã là HMI thì màn hình máy tính, màn hình TD/MP, ... cũng là HMI nhưng ở các cấp độ quản lí thì hoàn toàn khác nhau. Nếu theo mô hình hệ thống điều khiển quá trình được chia thành 3 cấp thì những màn hình kiểu TD ở cấp thấp nhất, có chức năng vận hành, giám sát 1 khâu nào đó, 1 cơ cấu chấp hành nào đó. Cấp quản lí cao nhất, quản lí toàn bộ hệ thống thường là một vài máy tính. Giao diện HMI cho những chiếc máy tính này cũng phải quản lí cả dây chuyền như bình thường, cho phép hiển thị và thay đổi các thông số được điều khiển.
                          Còn process visualization thì thiên về "làm phim hoạt hình" mô tả về quá trình bạn đang điều khiển: bạn có thể hiển thị thông tin, lưu trũ chúng vào database, phân quyền cho hệ thống, ...
                          Còn tại sao đồ án thường làm với cái nọ cái kia không phải vì cái nào tổng quan hơn cái nào mà đơn giản là hiện nay sinh viên khó có đủ tầm để làm 1 đồ án mà kiến thức bao trùm toàn bộ những công cụ cho việc thiết kế và vận hành 1 hệ thống điều khiển quá trình cỡ lớn.
                          Nếu quan tâm bạn có thể vào trang của Siemens để tìm hiểu kĩ hơn.
                          http://www.automation.siemens.com/hm...incc/index.htm
                          http://www.automation.siemens.com/hm...ible/index.htm
                          Bạn sẽ thấy cả 2 đều là HMI software
                          No matter if you run SIMATIC WinCC flexible or SIMATIC WinCC: The platform for Operator stations and servers are Standard PCs and the decision to employ an office or Industry PC depends on the environmental conditions.
                          For applications close to the machine a SIMATIC Panel PC is the best choice.
                          Therefore SIMATIC HMI offers complete systems with a freely configurable Panel PC and HMI Runtime software in a package:
                          • easy to order
                            saving you expenses in comparison with the costs of the separate components
                            always a hardware that meets the requirements of SIMATIC HMI-Software
                            fully tested systems
                          • nbqvdp
                            • Aug 2006
                            • 29
                            #14
                            WinCC Flexible 2007
                            Bạn có thể chép cho tôi bộ phần mểm WinCC Flexible 2007 Fullversion . Tôi đang sử dụng bản 2005, lang thang trên mạng thấy có bản mới nhưng lớn quá tải ko nổi.
                            Bạn cứ thanh tóan chi phí và đưa ra giá bộ phần mềm trên, nếu thấy hợp lí thì OK
                            Liên hệ: QUOC 0937 319 716
                            mail: madem_anthitbo@yahoo.com
                            • ituma
                              • May 2008
                              • 1
                              #15
                              ευχαριστω πολυ φγηφγηη
                              Nguyên văn bởi vaiduakhu Xem bài viết
                              On this page:
                              Code:
                              vaiduakhu Tìm hiểu thêm về vaiduakhu
