em đang làm đồng hồ dùng 4led.
em có dùng timer để quét led, nhưng vấn đề là khi đọc DS1307 thì lại sai. (phần cừng hoàn toàn đúng, em có test ko dùng timer thì đã ok)
Mong các bác góp ý.
Mong các bác góp ý.
Code:
#include <mega8.h>
#include <delay.h>
// I2C Bus functions
#asm
.equ __i2c_port=0x15 ;PORTC
.equ __sda_bit=4
.equ __scl_bit=5
#endasm
#include <i2c.h>
// DS1307 Real Time Clock functions
#include <ds1307.h>
#define S1 PORTB.0
#define S2 PORTB.1
#define S3 PORTB.2
unsigned char Font[11]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
unsigned char a[8];
unsigned char i=0,n=0;
unsigned char hour,min,sec;
//unsigned char day,month,year;
void Display_time()
rtc_get_time(&hour,&min,&sec);
a[0] = hour/10;
a[1] = hour%10;
a[2] = min/10;
a[3] = min%10;
//void Display_date()
// rtc_get_time(&day,&month,&year);
// a[4] = day/10;
// a[5] = day%10;
// a[6] = month/10;
// a[7] = month%10;
// Timer 1 output compare A interrupt service routine
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
// Place your code here
PORTC = 0xFF - (1<<i);
PORTD = Font[a[i]];
i++;
if (i>3) i=0;
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=In Func1=In Func0=In
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=P State1=P State0=P
PORTB=0x07;
DDRB=0xF8;
// Port C initialization
// Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTC=0x00;
DDRC=0x7F;
// Port D initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTD=0x00;
DDRD=0xFF;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: 1000.000 kHz
// Mode: CTC top=OCR1A
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: On
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x0A;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x07;
OCR1AL=0xD0;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x10;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// I2C Bus initialization
i2c_init();
// DS1307 Real Time Clock initialization
// Square wave output on pin SQW/OUT: Off
// SQW/OUT pin state: 0
rtc_init(0,0,0);
// Global enable interrupts
#asm("sei")
rtc_set_time(13,18,00);
//rtc_set_date(20,10,9);
while (1)
Display_time();
delay_ms(50);
//Display_date();
//delay_ms(50);
