Xilinx ISE 13.1 link Mediafire.com
  • laptrinhc++
    • Aug 2010
    • 46
    Thấy trên mạng đã có ra bản 13.1 nên Up lên trên Mediafire cho anh em dễ download về để thực hành !Đầu tiên các bạn down tất cả các file về máy !sau đó Joini các phần lại đc sau đó dùng winrar để giải nén ra !
    nói qua về bản này 1 chút :
    Renewed professional solution with full support for FPGA (FPGA) 7-Serieswhich provides improved tools with a new team Design Flowto speed up the design at all levels of the project.
    About Xilinx Inc.
    The company Xilinx Inc. - American developer and manufacturer of integrated circuit programmable logic (PLDFPGA). Founded in 1984the company in the 2006/2007 financial year achieved a turnover of 1.84 billion with net income of $ 350 million. Share of Xilinx FPGAs in the world market isaccording to the company51%.
    The company's Xilinx programmable chips:
    - CPLD (complex programmable logic device)
    Chips differ the most simple structure and significant limitations in designing devices for thembut they do have one advantage - they do not need a configuration ROM. Limitations include the "greed" on the triggers and lack of flexibility. Howeverthe CPLD are easy to learn andthereforeare ideal for getting started with FPGAs in general.
    - FPGA (field-programmable gate array)
    Chip is much more complicated arranged (some even contain several processor cores PowerPC)requires a configuration ROM (this is explained by the fact that the chips themselves are built on technology Static RAMthat isevery time I turn them to "load")but they are capable of accommodate a much more complex and larger projects than the CPLD and flexible enough for the designer (in particular removed the restriction on the number of triggers).
    - Configuration ROM
    Intended to boot SRAM FPGA. Family XC17xx - the oldestis a single programmable chip. XC18xx - EEPROMwhich means that they can be reprogrammed repeatedly. Platform Flash - a new family configuration chips made by technology Flash ROM.
    Varieties FPGA - IC FPGA (Field Programmable Gate Array)reprogrammable chips with traditional architecture PAL (Complex Programmable Logic Devicesor CPLD)- as well as their means of designing and debuggingmanufactured by Xilinxthe device uses digital processing of information - for examplein the systems of telecommunications and computingand peripheral testing equipmenthousehold appliances. The company manufactures chips in various types of buildings and in several versionsincluding industrialmilitaryand radiation-resistant.
    About Xilinx ISE Design Suite 13.1
    New to the award winning design tool and IP suite are enhancements which improve productivity across SoC design teams and progression towards true plug-and-play IP that targets Spartan (R) -6Virtex (R) -6 and 7 series FPGAsincluding the industry-leading 2-million-logic-cell Virtex-7 2000T device. Focusing on decreasing development time and costISE Design Suite 13 introduces accelerated verificationplug-and-play IP with IP-XACT Support and a new team design methodology that shortens design As Xilinx delivers FPGAs with multi-million system gate capacitiessuch as the Virtex-7 2000T device built using Stacked Silicon Interconnect technologyas well as capabilities to combine serialparallel and digital signal processing on a single chipand offer transceiver speeds of up to 28 Gbpsthe need for productivity is paramount in these highly complex designs.
    To stay on the productivity curvehoweverthe industry needs to achieve 50 percent cycle time improvement according to the International Technology Roadmap for Semiconductors.
    With over half of the design cycle spent in verificationthe ISE Design Suite 13 new hardware Co-Simulation capability and AMBA (R) 4 AXI4 (Advanced Extensible Interface) bus functional simulation models provide direct productivity gains for design verification teams.
    và sau đây là link Foder download
    PHP Code:
    http://www.mediafire.com/?h32asze2sp8or
    Anh em nhớ thanks cái cho nó hứng thế !!!`
  • robocon2011
    • Mar 2010
    • 435
    Điều quan trong hơn đó là nó có license k bác? Nếu không có down về dùng dc 30 ngày cũng để cho nặng ổ đĩa.
    • laptrinhc++
      • Aug 2010
      • 46
      license trên diễn đàn đã có 1 bác Up lên rồi mà !!!các bạn thử tìm lại coi !tớ nhớ đọc bài đó rồi
      • robocon2011
        • Mar 2010
        • 435
        Hiiii.. Cái đó chỉ là anh hungthientu hướngd dẫn làm file license thôi. Em làm theo mà nó có chạy đâu. Em k hiểu em làm sai chỗ nào nữa.
        • hungthientu
          • Mar 2009
          • 156
          đó là license của mình cho hostid của mình ,không phải hostid của bạn thì làm sao chạy được ,của bạn thì tất nhiên phải khác rồi
          license này luôn chạy tốt cho version 13.1 kể cả 13.2 bây giờ
          • hungthientu
            • Mar 2009
            • 156
            all feature cho xilinx ise 13.1 và cũng cho any hostid ,copy và tạo license.lic ,khi install hỏi license thì chỉ tới nó ,good license for 13.1+IP
            INCREMENT v6_emac xilinxd 2017.06 permanent uncounted B61C56E59A3D \
            VENDOR_STRING=License_Type:Bought;****_Comtech,v6_ emac,ip,evaluation,_123456789_123456_123456789 \
            HOSTID=ANY ISSUER="Xilinx Inc" NOTICE="The license for this \
            core was generated for ****_Comtech." START=01-May-2010 TS_OK
            FEATURE v6_emac_v1 xilinxd 2017.06 permanent uncounted C7A688B541F0 \
            VENDOR_STRING=License_Type:Bought HOSTID=ANY ISSUER=Xilinx \
            NOTICE="The license for this core was generated for \
            ****_Comtech." TS_OK
            INCREMENT System_Edition xilinxd 2017.06 permanent uncounted \
            9195EC0EF919 \
            VENDOR_STRING=****_Comtech,System_Edition,software ,permanent,_123456789_123456_123456789 \
            HOSTID=ANY ISSUER="Xilinx Inc" START=01-May-2010 TS_OK
            INCREMENT V6_S6_EA xilinxd 2017.06 permanent uncounted BAFA3DB0D60E \
            VENDOR_STRING=****_Comtech,V6_S6_EA,software,evalu ation,_123456789_123456_123456789 \
            INCREMENT plbv46_pcie xilinxd 2017.06 permanent uncounted \
            4C22D8B3A501 \
            VENDOR_STRING=License_Type:Bought;****_Comtech,plb v46_pcie,ip,evaluation,_123456789_123456_123456789 \
            FEATURE plb_v46_pcie_v3 xilinxd 2017.06 permanent uncounted \
            CFD4E846268A VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            ISSUER=Xilinx NOTICE="The license for this core was generated \
            for ****_Comtech." TS_OK
            INCREMENT v6_pcie xilinxd 2017.06 permanent uncounted 160D68A949FF \
            VENDOR_STRING=License_Type:Bought;****_Comtech,v6_ pcie,ip,evaluation,_123456789_123456_123456789 \
            FEATURE v6_pcie_v1 xilinxd 2017.06 permanent uncounted DC40BEA9061C \
            3740F85F66E3 \
            VENDOR_STRING=****_Comtech,System_Edition,software ,evaluation,_123456789_123456_1 \
            INCREMENT s6_pcie xilinxd 2017.06 permanent uncounted 4B5B2506A140 \
            VENDOR_STRING=License_Type:Bought;****_Comtech,s6_ pcie,ip,evaluation,_123456789_123456_123456789 \
            FEATURE s6_pcie_v1 xilinxd 2017.06 permanent uncounted 8E8553A404FA \
            PACKAGE System_Edition xilinxd 2017.06 5D1F6BE748C9 \
            COMPONENTS="AccelDSP ChipscopePro_SIOTK ChipscopePro ISIM \
            SysGen ISE sdk xps PlanAhead" OPTIONS=SUITE
            PACKAGE V6_S6_EA xilinxd 2017.06 55882ECBAA79 COMPONENTS="XC6SLX4 \
            XC6SLX9 XC6SLX18 XC6SLX25 XC6SLX45 XC6SLX100 XC6SLX150 \
            XC6SLX25T XC6SLX45T XC6SLX100T XC6SLX150T XCVLX75T XCVLX130T \
            XCVLX195T XCVLX240T XCVLX365T XCVLX550T XCVLX760 XCVSX315T \
            XCVSX475T " OPTIONS=SUITE
            FEATURE apu_fpu_v2 xilinxd 2017.06 permanent uncounted 798ECBC24A47 \
            FEATURE apu_fpu_virtex5_v1 xilinxd 2017.06 permanent uncounted \
            609B07DF5ED9 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_atmc_v1_00_b xilinxd 2017.06 permanent uncounted \
            188546C88A87 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_atmc_v2_00_a xilinxd 2017.06 permanent uncounted \
            EB7488DBBF25 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernet_v1_00_j xilinxd 2017.06 permanent uncounted \
            D93BCDF4F34F VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernet_v1_00_k xilinxd 2017.06 permanent uncounted \
            30507A882A6E VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernet_v1_00_l xilinxd 2017.06 permanent uncounted \
            9BFB8F7851E1 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernet_v1_00_m xilinxd 2017.06 permanent uncounted \
            158C9CC45020 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernet_v1_01_a xilinxd 2017.06 permanent uncounted \
            D91795986578 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernet_v1 xilinxd 2017.06 permanent uncounted \
            F405E83FF5D7 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernetlite_v1_00_a xilinxd 2017.06 permanent uncounted \
            403BECB0E310 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_ethernetlite_v1 xilinxd 2017.06 permanent uncounted \
            711F0B6C89F6 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_hdlc_v1_00_b xilinxd 2017.06 permanent uncounted \
            D3C59BA99898 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_hdlc_v1 xilinxd 2017.06 permanent uncounted 8283C7C7D59C \
            FEATURE opb_hdlc_v2_00_a xilinxd 2017.06 permanent uncounted \
            F226AFA2C3B2 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_hdlc_v2 xilinxd 2017.06 permanent uncounted 9651F39424C0 \
            FEATURE opb_iic_v1_01_a xilinxd 2017.06 permanent uncounted \
            A59588E98E8A VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_iic_v1_01_b xilinxd 2017.06 permanent uncounted \
            97B074A65604 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_iic_v1 xilinxd 2017.06 permanent uncounted 7EA0C03A0F9C \
            FEATURE opb_uart16550_v1_00_c xilinxd 2017.06 permanent uncounted \
            670AB64E90D7 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE opb_uart16550_v1 xilinxd 2017.06 permanent uncounted \
            99994B469042 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_atmc_v1_00_a xilinxd 2017.06 permanent uncounted \
            C9CB20E27BFC VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_ethernet_v1_00_a xilinxd 2017.06 permanent uncounted \
            3D68714F1637 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_ethernet_v1 xilinxd 2017.06 permanent uncounted \
            D92E4920BD88 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_gemac_v1_00_a xilinxd 2017.06 permanent uncounted \
            7EF2C7673181 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_gemac_v1_00_b xilinxd 2017.06 permanent uncounted \
            BAD812768F98 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_gemac_v1_01_a xilinxd 2017.06 permanent uncounted \
            B6F97970F19D VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_gemac_v2 xilinxd 2017.06 permanent uncounted 59C5F8D49B96 \
            FEATURE plb_temac_v1 xilinxd 2017.06 permanent uncounted 44D75A3204FF \
            FEATURE plb_uart16550_v1_00_b xilinxd 2017.06 permanent uncounted \
            7BD95F831568 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plb_uart16550_v1_00_c xilinxd 2017.06 permanent uncounted \
            913F87850890 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE plbv46_pcie_v3 xilinxd 2017.06 permanent uncounted \
            16801D3D3072 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE soft_temac_wrap_v1 xilinxd 2017.06 permanent uncounted \
            CD781EDA4C6F VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE soft_temac_wrap_v2 xilinxd 2017.06 permanent uncounted \
            BEF3C77E5BDB VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE xps_ethernetlite_v1 xilinxd 2017.06 permanent uncounted \
            CBBEC300E374 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE xps_iic_v1 xilinxd 2017.06 permanent uncounted C34DB61F2932 \
            FEATURE xps_iic_v2 xilinxd 2017.06 permanent uncounted 4F5E314F46DA \
            FEATURE xps_ll_temac_v1 xilinxd 2017.06 permanent uncounted \
            94240CC31C02 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE xps_ll_temac_v2 xilinxd 2017.06 permanent uncounted \
            2315C864845C VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            FEATURE xps_uart16550_v1 xilinxd 2017.06 permanent uncounted \
            4BA92D0E8082 VENDOR_STRING=License_Type:Bought HOSTID=ANY \
            • quandai
              • Mar 2011
              • 2
              bản này có tích hợp EDK không vậy? Mình đang cần quá...
              • robocon2011
                • Mar 2010
                • 435
                #8
                Nguyên văn bởi quandai Xem bài viết
                Tích hợp đầy đủ công cụ luôn.
                • quandai
                  • Mar 2011
                  • 2
                  #9
                  sao mình add cái license trên mà edk vẫn không có key:
                  • laptrinhc++
                    • Aug 2010
                    • 46
                    #10
                    đÂy là bản tớ down từ trang chủ của Xilinx và upload lên mediafire : http://www.mediafire.com/?jq67b9wm7kusk
                    • vannghia
                      • Mar 2009
                      • 54
                      #11
                      Mình đang dùng bản 13.2 load từ trang chủ của Xilinx, license mình đang sử dụng đến năm 2022, ai cần thì email cho mình.
                      Tạo license thật đơn giản bằng cách chạy file exe, license để đâu tùy ý các bạn, sau đó vào phần copy license trong manage xilinx license rồi dẫn đến vị trí lưu file license của bạn.
                      sau khi add xong license, các bạn vào mục C:\Xilinx\13.2\ISE_DS\EDK\data\core_licenses và xóa file xilinx.lic đi
                      DSP, Embedded System, FPGA/MCU boards & Kits
                      • chaugiang
                        • Feb 2011
                        • 6
                        #12
                        em chào anh Nghĩa em đang tìm hiểu về FPGA để làm đồ án tốt nghiệp.nhưng chưa có license của xilinx EDK 13.2 nên chưa thể ***** dc phần mềm này. xin anh cho em cái lincense của anh nhé.thanks anh!mong anh sớm trả lời
                        • vannghia
                          • Mar 2009
                          • 54
                          #13
                          chaugiang gui cho minh email minh gui cho ban.
                          • chaugiang
                            • Feb 2011
                            • 6
                            #14
                            email của em là:gaubong_hp1988@yahoo.com
                            em thanks anh!
                            • ganyfun
                              • Dec 2007
                              • 25
                              #15
                              Chao Nghia! minh cung moi down ban ISE 13.2 cua Xilinx ve nhung chua co key ban co the share key cho minh khong? Email cua minh la ndt.bktry@gmail.com. Cam on ban rat nhieu
                              laptrinhc++ Tìm hiểu thêm về laptrinhc++
