LED MATRIX DISPLAY
This topic is closed.
  • Nguyên văn bởi thanhthuong Xem bài viết
    nếu chơưng trình 1 em sửa lại như thế này thì nó chỉ đếm dc 255 chữ là thôi không đếm tiếp nữa:
    dn1 bit p3.0
    dn2 bit p3.1
    dn3 bit p3.2
    dn4 bit p3.3
    dn5 bit p3.4
    dn6 bit p3.5
    dn7 bit p3.6
    dn8 bit p3.7
    dn9 bit p0.7
    dn10 bit p0.6
    dn11 bit p0.5
    dn12 bit p0.4
    dn13 bit p0.3
    dn14 bit p0.2
    dn15 bit p0.1
    dn16 bit p0.0
    dn17 bit p1.7
    dn18 bit p1.6
    dn19 bit p1.5
    dn20 bit p1.4
    dn21 bit p1.3
    dn22 bit p1.2
    dn23 bit p1.1
    dn24 bit p1.0
    d1 data 10h
    d2 data 11h
    d3 data 12h
    d4 data 13h
    d5 data 14h
    d6 data 15h
    d7 data 16h
    d8 data 17h
    xuat equ p2
    lap equ r2
    tang equ r1
    org 00h
    mov a,#00h
    mov dptr,#BEGIN
    mov p3,#00h
    mov lap,#0
    mov d1,#00h
    mov d2,#00h
    mov d3,#00h
    mov d4,#00h
    mov d5,#00h
    mov d6,#00h
    mov d7,#00h
    mov d8,#00h
    org 40h
    main:
    lcall ctxl
    xoay:
    lcall ctht
    djnz lap,xoay
    ljmp main
    ctxl:
    mov d1,d2
    mov d2,d3
    mov d3,d4
    mov d4,d5
    mov d5,d6
    mov d6,d7
    mov d7,d8
    mov a,#00h
    movc a,@a+dptr
    mov d8,a
    CALL TRE
    inc tang
    cjne a,#0C0h,thoat
    mov dptr,#00h
    mov tang,#00h
    thoat:
    mov a,tang
    ret
    ctht:
    clr dn8
    mov xuat,d8
    lcall tre
    setb dn8
    clr dn7
    mov xuat,d7
    lcall tre
    setb dn7
    clr dn6
    mov xuat,d6
    lcall tre
    setb dn6
    clr dn5
    mov xuat,d5
    lcall tre
    setb dn5
    clr dn4
    mov xuat,d4
    lcall tre
    setb dn4
    clr dn3
    mov xuat,d3
    lcall tre
    setb dn3
    clr dn2
    mov xuat,d2
    lcall tre
    setb dn2
    clr dn1
    mov xuat,d1
    lcall tre
    setb dn1
    ret
    tre:
    mov r5,#1
    de: mov r6,#30
    djnz r6,$
    djnz r5,de
    ret
    org 200h
    BEGIN: db 01h,01h,0ffh,01h,01h,00h,0ffh,11h,11h,11h,0eeh,00h ,0fch,12h,11h,12h,0fch,00h,0ffh,0ch,08h,30h,0ffh,0 0h,00h,01h,01h,0ffh,01h,01h,00h,0ffh,08h,08h,08h,0 ffh,00h,7fh,80h,80h,80h,0ffh,00h,7eh,81h,81h,81h,7 eh,00h,0ffh,0ch,08h,30h,0ffh,00h
    q: db 7eh,81h,81h,91h,0f1h,00h,00h,0ffh,89h,81h,81h,7eh, 00h,01h,01h,0ffh,01h,01h,00h,3fh,40h,80h,40h
    h: db 3fh,00h,01h,01h,0ffh,01h,01h,00h,00h,0ffh,89h,81h, 81h,7eh,00h,0fch,12h,11h,12h,0fch,00h,0ffh,00h,00h ,0ffh,08h,08h,08h,0ffh,00h,7eh,81h,81h,81h,7eh,00h ,0c0h
    v: db 7eh,81h,81h,81h,81h,00h,00h,7eh,81h,81h,0c1h,0feh, 00h,7fh,80h,80h,80h,0ffh,00h,07h,08h,0f8h,08h,07h, 00h,00h,0ffh,0ch,08h,30h,0ffh,00h,0ffh,08h,08h,08h ,0ffh,00h,7eh,81h,81h,81h,7eh,00h,0ffh,0ch,08h,30h ,0ffh,00h,08h,08h,08h,08h,00h,0ffh,08h,08h,08h
    c1: db 0ffh,00h,0fch,12h,11h,12h,0fch,00h,07h,08h,0f8h,08 h,07h,00h,00h,3fh,40h,80h,40h,3fh,00h,7fh,80h,80h, 80h,0ffh,00h,7eh,81h,81h,81h,7eh,00h,01h,01h,0ffh, 01h,01h,00h,00h,7eh,81h,81h,0c1h,0feh,00h,7fh,80h, 80h,80h,0ffh,00h
    a1: db 0fch,12h,11h,12h,0fch,00h,00h,0ffh,02h,04h,02h,0ff h,00h,0ffh,00h,0ffh,04h,08h,10h,20h,0ffh,00h
    m: db 0ffh,08h,08h,08h,0ffh,00h,00h,00h,00h
    x: db 7eh,81h,81h,81h,81h,00h,00h,7eh,81h,81h,0c1h,0feh, 00h,7fh,80h,80h,80h,0ffh,00h,07h,08h,0f8h,08h,07h, 00h,00h,0ffh,0ch,08h,30h,0ffh,00h,0ffh,08h,08h,08h ,0ffh,00h,7eh,81h,81h,81h,7eh,00h,0ffh,0ch,08h,30h ,0ffh,00h,08h,08h,08h,08h,00h,0ffh,08h,08h,08h
    CHUC: DB 3EH,41H,41H,41H,22H,00h,7FH,08H,08H,08H,7FH,00h,3F H,40H,40H,40H,3FH,00h,3EH,41H,41H,41H,22H ;chuc
    MUNG: DB 00h,00h,00h,7FH,02H,04H,02H,7FH,00h,3FH,40H,40H,40 H,3FH,00h,7FH,06H,08H,30H,7FH,00h,3EH,41H,41H,49H, 7AH ;mung
    NAM: DB 00h,00h,00h,7FH,06H,08H,30H,7FH,00h,7EH,09H,09H,09 H,7EH,00h,7FH,02H,04H,02H,7FH ;nam
    MOI: DB 00h,00h,00h,7FH,02H,04H,02H,7FH,00h,3EH,41H,41H,41 H,3EH,00h,41H,41H,7FH,41H,41H,00h,00h,5FH ;moi !
    HAPPY: DB 00h,00h,00h,7FH,08H,08H,08H,7FH,00h,7EH,09H,09H,09 H,7EH,00h,7FH,09H,09H,09H,06H,00h,7FH,09H,09H,9H,0 6H,00h,03H,04H,78H,04H,03H ;happy
    NEW:
    machu: db 0ffh,0ffh,81h,7eh,7eh,7eh,0ffh,0ffh
    machu1: db 0f1h,0efh,0efh,0efh,0efh,0efh,0efh,0e1h
    ma: db 22h,22h,22h,3eh,22h,22h,22h,22h,00h,0C0H
    end
    VÌ EM MUÓN CHẠY 1 BẢNG QUẢNG CÁO DÀI NHƯNG EM LÀM MÃI MÀ KO DC.CÁC BÁC GIẢI DÙM EM NHÉ.
    thì đúng rồi thanh ghi Rx của bạn là 8 bit ma,bạn nen chia nhỏ đoạn dữ liệu ra rồi hiển thị miễn sao <255 là ok chúc thành công
    • Nguyên văn bởi tungtot_vl Xem bài viết
      tôi dốt về vb lắm nhưng nói râu ria thế này nhé.
      bạn tạo một cơ sở dữ liệu trong vb
      ví dụ như tạo một cái tủ có nhiều ngăn (ví dụ 24 ngăn. ngăn 1 bạn chứa code mã hoá 16 byte của font chử a, ngăn 2 chữ b...... 24 chữ z)
      còn trong phần text bạn làm gì thì làm nhưng khi gỏ vào đó chữ a thì cái text này hiểu mã của nó là 1, b mã là 2.... z mã 24.
      nếu bạn gỏ vào dong text chử "chu" thì khi đó trong dòng text có chuỗi mã là " 3,14,20". khi bạn nhấn nút send để gởi data lên vdk. khi đó vòng lập kiểm tra thấy chữ c có mã là 3 thì con trỏ chạy đến tủ có ngăn số 3 để lấy 16 byte font này gởi ra vdk, khi kiểm tra đến chữ h có mã là 14 thì nó chạy đến tủ lấy ngăn 14 chứa 16 byte của font chử h để gởi đi. và cuối cùng là chử u thì cũng như vậy thôi. khi đã gởi xong thì trong eeprom của vđk đã lưu được font đã mã hoá của chử "chu" khi đó chỉ cần đọc data trong EEprom ra là xong. tôi nói nếu ko đúng thì mong bác góp ý thêm.
      cái này cũng giống như bác đi gởi xe đạp thôi. trên tay bác cầm cái vé số 10 thì đi tìm cái xe có số 10 mà lấy chứ lấy lộn số 12 thì bầm mắt đấy.
      theo như cách của bác thì bộ font nằm sẵn trong VDK rồi, ta chỉ cần so sánh mã truyền từ máy tính xuống rồi chọn kí tự thích hợp đưa vào Ram và thể hiện lên quang báo. cách này ko phải ý của e. bởi vì bác ko thể mã hóa toàn bộ mấy trăm font trên máy tính và kích cỡ font cũng bị giới han. thay vì vậy ta mã hóa font trên máy tính luôn, VDK chỉ có việc nhận data và show nó lên QB. bác hiểu ý em chứ
      • lmd
        Nguyên văn bởi phong25_2 Xem bài viết
        bạn xem lại chứ. cách của tôi là toàn bộ font được lưu sẳn trên máy tính mà. nó nằm trong cơ sở dữ liệu của vb còn gì. còn việc gởi xuống vdk chỉ gởi font của những ký tự mà mình đã viết trên text thôi.
        LMD 238 Tăng Bạc Hổ - TP. Quy Nhơn.
          ...việc gởi xuống vdk chỉ gởi font của những ký tự mà mình đã viết trên text thôi.
          gởi font của kí tự xuống VDK là sao hở bạn, mình chưa hiểu ý của bạn. giả sử khi ta viết chữ A thì theo mã ASCII là 65 còn nếu mã hóa sẽ là 0,1E,3E,48,48,3E,1E,0. Chữ A theo font VNI Times hay Times New Roman thì cùng có mã ASCII là 65 nhưng mã trên led matrix là khác nhau. vậy thì máy tính truyền xuống cho VDK mã gì vậy ban.
          • bác nghaiha hình như có vẻ rất thích Delphi thì phải, bác có thể nói những ưu điểm nổi bật của Delphi cho e biết với, thấy tốt thì e chuyển sang xài thằng này luôn.
            • Nguyên văn bởi phong25_2 Xem bài viết
              Thì truyền xuống cái 0,1E,3E,48,48,3E,1E,0 chớ cái gì. Cái mớ mã hóa đó là VNI-Times thì nó là VNI-Times, Times New Roman thì là Times New Roman chớ sao nữa.
              Email: - Mobil: tạm thời ngừng liên lạc 1 thời gian
              • e biết là mình fai truyền cái mớ 0,1E,3E,48,48,3E,1E,0 nhưng do hổng hiểu ý bác tungtot_vl là bác í truyền cái gì xuống, vì bác tungtot_vl nói là toàn bộ font dc luu trong CSDL của VB nên e ko hiểu chính xác là nó luu cái mớ 0,1E,3E,48,48,3E,1E,0 hay cái gì khác. vì nếu như bác nghaiha nói về cách vẽ lên các control rồi mã hóa nó thì cần gì phải luu vào CSDL nào. vui lòng giai thich dùm e.
                  ... nếu 16 hàng thì mổi chử sau khi mã hoá được 16 byte.
                  khi bác viết vào dòng text chử "bác" và nhấn nút send để gởi xuông vdk thì tương ứng với chử b gởi xuống 16 byte của mã chử b. chử á sẽ gởi xuống 16 byte................
                  dó là LMD 1 màu còn 2 màu thì gởi xuống 32 byte bác ạ
                  bac tungtot_vl gởi cái " 0,1E,3E,48,48,3E,1E,0 " chứ hổng phải mã ASCII
                  • bac nghaiha ơi! e đã mã hóa dc theo như cách vẽ lên picture box. tuy nhiên khi dòng chữ quá dài thì nó chỉ thể hiện dc nội dung bằng với kích thước hộp picture đó thôi, có cách nào giải quyết nó ko bác, chắc là có nhưng e chưa nghĩ ra. bác làm rồi thì gợi ý cho e nhé. thanks alot
                    • Cáh điều khiển M74HC595
                      - Mình đưa ra chương trình này dành cho các bạn mới tìm hiểu về quang báo dùng 74HC595, Chương tình này đã test và chạy rất OK. Trình biên dịch MIDE-51, các bạn có thể download từ 4shared.com mình đã gửi up tất cả trình biên dịch cho vdk link: http://www.4shared.com/file/43956836...8/Tap_hop.html
                      - Các đầu ra được nối với 8 led đơn nối âm chung
                      * Cách 1:
                      Chương trình đơn giản
                      Đây là chương trình điều khiển led sáng dần và tắt dần
                      ;SHcp = STcp = CK P 2.0
                      ;DI = Data = P 2.1
                      ;LED NOI DUONG CHUNG
                      ;SANG DAN TAT DAN
                      ;CO THE DUNG LDE MATRIX DE TEXT NHO THEM CONG P0 =1
                      CK BIT P2.0
                      DATAB BIT P2.1
                      ORG 0000H
                      SJMP MAIN
                      ORG 0003H
                      MAIN:
                      MOV P2,#0FFH ;DATA=1 (P2.1)
                      CALL DELAY_2
                      CLR CK ;1
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;2
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;3
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;4
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;5
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;6
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;7
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;8
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;9
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;10
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;11
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;12
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;13
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;14
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;15
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;16
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;17
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;18
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;19
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;20
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;21
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;22
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;23
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;24
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;25
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;26
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;27
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;28
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;29
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;30
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;31
                      SETB CK
                      CALL DELAY_1
                      CLR DATAB ;DATA=0 (P2.1)
                      CLR CK ;1
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;2
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;3
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;4
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;5
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;6
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;7
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;8
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;9
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;10
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;11
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;12
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;13
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;14
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;15
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;16
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;17
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;18
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;19
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;20
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;21
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;22
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;23
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;24
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;25
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;26
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;27
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;28
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;29
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;30
                      SETB CK
                      CALL DELAY_1
                      CLR CK ;31
                      SETB CK
                      CALL DELAY_1
                      LJMP MAIN
                      DELAY_1:
                      CALL DELAY
                      RET
                      DELAY_2:
                      CALL DELAY
                      CALL DELAY
                      CALL DELAY
                      CALL DELAY
                      RET
                      DELAY:
                      MOV R1,#40
                      L1: MOV R2,#150
                      l2: DJNZ R2,L2
                      DJNZ R1,L1
                      RET
                      END
                      * Cách 2:
                      Chương trình rut gọn
                      ;SHcp = STcp = CK P2.0
                      ;DI = Data = 2.1
                      ;SANG DAN TAT DAN
                      ;PHIEN BAN 2 (VERSION 2)
                      CK BIT P2.0
                      DATAB BIT P2.1
                      ORG 0000H
                      SJMP MAIN
                      ORG 0003H
                      MAIN:
                      MOV P2,#0FFH ;DATA=1 (P2.1) CK =1 (P2.0)
                      CALL DELAY_1
                      MOV R3,#00H
                      NEXT_TOI:
                      CLR CK ;22
                      SETB CK
                      CALL DELAY_1
                      INC R3
                      CJNE R3,#30,NEXT_TOI
                      MOV R3,#00H
                      NEXT_LUI:
                      CLR CK ;22
                      SETB CK
                      CALL DELAY_1
                      INC R3
                      CJNE R3,#30,NEXT_LUI
                      SJMP MAIN
                      DELAY_1:
                      CALL DELAY
                      RET
                      DELAY_2:
                      CALL DELAY
                      CALL DELAY
                      CALL DELAY
                      CALL DELAY
                      RET
                      DELAY:
                      MOV R1,#30
                      L1: MOV R2,#255
                      l2: DJNZ R2,L2
                      DJNZ R1,L1
                      RET
                      END
                      • Lmd
                        nếu dùng mã ascii làm mã để gán cho font thì hạn chế quá rồi vì số mã ascii trên bàn phím không đủ để mã hóa các chữ cho tiếng việt. do đó bạn nên tạo ra một mã riêng cho mình chứ cần gì lệ thuộc vào mã ascii.
                        nếu muốn tạo font theo vni times vạy các dạng font gì đó thì tùy bạn, hoặc thư pháp cũng được và có thể có nhiều loại font khác nhau nữa. ở đây tôi không nói cách tạo ra font mà chỉ nói cách gỏi font từ pc xuống vdk thôi.
                        muốn gởi xuống lmd nhiều loại font khác nhau thì bạn cứ mã hóa các loại font muốn hiện lên LMD. sau dó lưu các dạng font và dữ liệu của vb. ví dụ một kiểu font ta lưu thành 1 file. khi muốn gởi dạng font nào thì chỉ việc liên kết đến file đó để gởi nó xuống vdk thôi. do đó bạn muốn gởi bao nhiêu laọi font xuống vdk vẫn được. tuy nhiên một dòng chữ chạy qua chỉ hiển thì một kiểu font hay 1 dạng font mà file của bạn gởi xuống thôi. do dó nếu bạn chạy 10 dòng chữ khác nhau thì mỗi dòng 1 dạng font thì vẫn được.
                        • Nguyên văn bởi nghaiha Xem bài viết
                          cái này bác nói đúng đấy. nếu gán mã 65 để gởi cái 0,1E,3E,48,48,3E,1E,0 xuống thì trên LMD điển thị chữ A còn nếu gán mã 65 để gởi cái hình con trâu xuống thì LMD hiện cái hình con trâu thôi có gì mà phải hỏi
                          • Lmd
                            tốt chỉ nói là chúng ta gởi 1 dòng text trên vb xuống vdk thôi, chứ đâu nói vẽ hình ra để gởi xuống. ví dụ như bạn mã hóa ra toàn bộ các ký tự font vni times rồi lưu vb rồi lưu trong vb khi ta đánh gỏ vào dòng text trên vb chữ " tùng tốt" thì nó gởi xuống font dạng hex đã mã có của chữ "tùng tốt đã có lưu trong vb để hiện lên LMD thôi. còn cái vã hình thì mình không biết. cái vẽ hình chỉ dùng để cho những ai tạo ra LMD sử dụng để đưa lên LMD thồi chứ nếu đưa cho một đưa cu tí mới học lới 1 gởi thì làm sao nó biết.
                              uhm, cám ơn bạn nhiều, cái nguyên lý thì mình hiểu, chỉ là cách mã hóa là chưa biết. bạn biết thì chỉ cho mình với!!!
                              theo như cách của bác nghaiha thì e viết nên dc cái bản demo sau, tuy nhiên tốc độ hiện chữ lên table sao mà chậm quá, chưa thể hiện TV, và câu chữ chưa viết dài dc, các bác down về chạy thử rồi chỉ e với
                              • em viết chương trình ngon hết rồi
                                nhưng lại gặp một vấn đề nữa
                                em muốn hiển thị font chữ bất kì được nhập từ bàn phím
                                cách mã hóa và hiển thị như nào nhỉ
                                các pro chỉ giáo cho em với,thanks!
                                mail: vocam.h@gmail.com
                                0945061338(vocam.h@gmail.com,lehanhdtk3@gmail.com)
                                PROGRAMING(C,ASM),HARDWARE,LMD,RTC,GPRS,GPS....ALL OF VDK
                                hitkhoi Tìm hiểu thêm về hitkhoi
