đồ chơi khủng cho AVR đây!!!
  • đồ chơi khủng cho AVR đây!!!
    rtx_3.1.rar : PR_RTX
    PR_RTX is a task switcher for the Atmel AVR processor that is easily implemented by inserting a header file and a task control block into the code produced by the CodeVisionAVR wizard or written by a programmer. The header file contains all of the control structure and initializations to get the RTX running.
    A rich variety of RTX services are provided to control task switching, timing and task control. Tasks may be put into a wait state based on time or receipt of a semaphore from another task or both. Tasks may be started or stopped either from within the task itself or from another task. Tasks may switch in a round-robin mode or in a priority mode where one task requires critical timing control.
    This is a source code product and is packaged in the form of both CodeVisionAVR and Imagecraft projects.
    Features
    -Complete task switching control in either round-robin or priority mode
    -Automatic time base set-up
    -Allocation of internal and/or external SRAM based on project configuration
    -Includes ability to pass inter-task semaphores with limited messaging
    -Tasks may switch on other periodic signals such as the ADC or even from an external interrupt
    -Complete CodeVisionAVR and Imagecraft project packages with an example programs
    -Designed specifically for CodeVisionAVR, Imagecraft and the Atmel AVR
    -Simple setup configuration through #define macros
    -PR_RT_eXaminer tool allows users to examine stack sizes and usage
    avr_cf.rar and avr_sd.rar : FlashFile SD/CF FAT12/16 File Systems for AVR.
    FlashFile - SD/MMC FAT12/16 File Systems for AVR
    FlashFile are source code packages designed to give MSDOS compatibility to your embedded application using SD/MMC, Mini-SD, TransFlash or CompactFlash memory modules! Standard C library functions such as fopen, fclose, fcreate, fread, frwrite, fgetc, fputc, and others allow easy access to data stored on an SD/MMC card by a PC as well as an easy method of creating and maintaining data from your embedded application that can be easily accessed by a PC. Both FAT12, and FAT16 formats are supported including subdirectories.
    Quá là cảm ơn bạn, thấy có thư viện này bán trên mạng (cả Tây, cả ta), vội vã đi tìm crk, ai dè ngay bên cạnh mình, hê, cứ đi tìm đâu đâu ấy...
      Cám ơn bạn nha,
      Thư viện này hay qua'
      Vui
      hoanf
        các bác oi, cho e hỏi 1 câu ngớ ngẩn là cái mà bác longimi pot len là cai gi vậy, e có down về roi nhung ko bit xai, các bác vui lòng chỉ e cách xài với,e thấy những người cảm ơn bác longimi toàn là cao thủ ko hà, chác là bác longimi đã tặng bảo kiếm cho các anh hùng, hi vọng mọi người chỉ e vài chiêu để e sử dụng bảo kiếm với,pls.
          Các anh ơi cho em biết mấy file vừa uplen có tác dụng gì vậy ạ.
          longimi Tìm hiểu thêm về longimi
            14-12-2025, 19:50
