Xin giúp em với các bác ơi
  • tudoluong87
    Thành viên mới
    • Mar 2011
    • 6
    EM MỚI VÀO NGHỀ NÊN CHƯA HIỂU RÕ MONG CÁC BÁC CHỈ GIÚP EM ! EM XIN CHÂN THÀNH CẢM ƠN Ạ!
    EM CÓ BÀI TOÁN LÀ HẸN GIỜ MỚI 3 KHOẢNG THỜI GIAN DÙNG NGẮT TIMER !
    NHẤN NÚT CHUYỂN SANG CHẾ ĐỘ 1
    NHẤN TIẾP CHUYỂN SANG CHẾ ĐỘ 2
    NHẤN TIẾP CHUYỂN SANG CHẾ ĐỘ 3
    ĐÂY LAD CODE EM LẬP TRÌNH MONG CÁC BÁC GIÚP EM VỚI NHÁ. EM KHÔNG BIẾT SAO NO KHÔNG CHẠY CÁC BÁC GIÚP EM VỚI
    #include <REGX51.H>
    #define timer P3_0
    #define timer1 P1_0
    #define timer2 P1_1
    #define timer3 P1_2
    unsigned int i,time_now,hengio,time_off,kt_hengio,count,sec;
    void setup_timer(void)
    TMOD = 0x01 ;
    TH0 = 0x3C ;
    TL0 = 0xAF ;
    IE = 0x82 ;
    TF0 = 0;
    TR0 = 1;
    void T0_ISR (void) interrupt 1
    TR0 = 0;
    TH0 = 0x3C;
    TL0 = 0xAF ;
    count++;
    if (count==20)
    count = 0;
    sec++;
    TF0 = 0;
    TR0 = 1;
    void setup_gio(void)
    if (kt_hengio==1)
    if(sec>time_off)
    timer1=timer2=timer=1;
    hengio = 0;
    if(timer)
    while(timer)
    kt_hengio=1;
    sec=0;
    hengio++ ;
    if(hengio> 3)
    {hengio = 0;}
    switch(hengio)
    case 0: {kt_hengio=0;
    timer1=1; timer2=1; timer3=1; break;}
    case 1: {time_off=1800; // 30 minutes
    timer1=0; timer2=1; timer3=1; break;}
    case 2: {time_off=3600; // 1 hour
    timer1=1; timer2=0; timer3=1; break;}
    case 3: {time_off=7200; // 2 hours
    timer1=1; timer2=1; timer3=0; break;}
    void main(void)
    hengio=0;
    count = 0;
    timer1=timer2=timer3= 1;
    setup_timer();
    P1= 0xff;
    P3= 0x00;
    while(1)
    setup_gio();
  • tdm
    • Sep 2005
    • 349
    Nguyên văn bởi tudoluong87 Xem bài viết
    EM GỦI CẢ SƠ ĐỒ VÀ CODE EM LẬP TRÌNH MONG CÁC BÁC GIÚP EM VỚI NHÁ. EM KHÔNG BIẾT SAO NO KHÔNG CHẠY CÁC BÁC GIÚP EM VỚI
    http://www.mediafire.com/?i48vm8cjydf8bom
    thêm :interrupt 1 vào chỗ khai báo ngắt
    • tudoluong87
      Thành viên mới
      • Mar 2011
      • 6
      cảm ơn bac nhá
      • vothanhlong
        • Jan 2010
        • 116
        #4
        #include <REGX51.H>
        #define timer P3_0
        #define timer1 P1_0
        #define timer2 P1_1
        #define timer3 P1_2
        TMOD = 0x01 ;
        TH0 = 0x3C ;
        TL0 = 0xAF ;
        IE = 0x82 ;
        TF0 = 0;
        TR0 = 1;
        void T0_ISR (void)
        TR0 = 0;
        TH0 = 0x3C;
        TL0 = 0xAF ;
        count++;
        if (count==20)
        count = 0;
        sec++;
        TF0 = 0;
        TR0 = 1;
        if (kt_hengio==1)
        if(sec>time_off)
        hengio = 0;
        if(timer)
        while(timer)
        kt_hengio=1;
        sec=0;
        hengio++ ;
        if(hengio> 3)
        {hengio = 0;}
        switch(hengio)
        void main(void)
        hengio=0;
        count = 0;
        setup_timer();
        P1= 0xff;
        P3= 0x00;
        while(1)
        setup_gio();
        Mình không rành về C lắm, nhưng hình như vấn đề nẳm ở chỗ mình tô đỏ ấy. Các cao thủ C xem thử dùm mình phải chỗ đó count = 20 thì Timer0 mới được chạy lại không vậy?
        Chõ này hình như bạn tdm có sự nhầm lẫn hay sao ấy, trong chương trình chỉ sử dụng timer0 thôi chứ đâu có timer1 hả bạn.
        Công ty TNHH Tự Động Hóa Đạt Lân
        32/36, Ông Ích Khiêm, F14, Q11
        ĐT: 08.3974 7308 - 0937.197.001
        email:
        Webite:
        • tdm
          • Sep 2005
          • 349
          #5
          Nguyên văn bởi vothanhlong Xem bài viết
          chỗ tô đỏ không có gì sai.
          count = 20//để kéo dài thời gian[khi ngắt sảy ra 20 lần thì biến sec mới được tăng]
          • vothanhlong
            • Jan 2010
            • 116
            #6
            Nguyên văn bởi tdm Xem bài viết
            Thanks tdm nhé, bạn có thể giải thích cụ thể đoạn chương trình đó cho mình không, mình gà về C lắm.
            email:
            Webite:
            tudoluong87 Tìm hiểu thêm về tudoluong87
