Tự làm radio
Cái này hồi đi học mình cũng nghe thầy nói đến cái này nhưng không để ý. Nhưng làm được. Bạn có thể tham khảo cái này:
The Simplest AM Receiver
In the case of a strong AM signal, it turns out that you can create a simple radio receiver with just two parts and some wire! The process is extremely simple -- here's what you need:
A diode - You can get a diode for about $1 at Radio Shack. Part number 276-1123 will do.
Two pieces of wire - You'll need about 20 to 30 feet (15 to 20 meters) of wire. Radio Shack part number 278-1224 is great, but any wire will do.
A small metal stake that you can drive into the ground (or, if the transmitter has a guard rail or metal fence nearby, you can use that)
A crystal earphone - Unfortunately, Radio Shack does not sell one. However, Radio Shack does sell a Crystal Radio Kit (part number 28-178) that contains the earphone, diode, wire and a tuner (which means that you don't need to stand right next to the transmitter for this to work), all for $10.
You now need to find and be near an AM radio station's transmitting tower (within a mile/1.6 km or so) for this to work. Here's what you do:
Drive the stake into the ground, or find a convenient metal fence post. Strip the insulation off the end of a 10-foot (3-meter) piece of wire and wrap it around the stake/post five or 10 times to get a good solid connection. This is the ground wire.
Attach the diode to the other end of the ground wire.
Take another piece of wire, 10 to 20 feet long (3 to 6 meters), and connect one end of it to the other end of the diode. This wire is your antenna. Lay it out on the ground, or hang it in a tree, but make sure the bare end does not touch the ground.
Connect the two leads from the earplug to either end of the diode, like this:
Now if you put the earplug in your ear, you will hear the radio station -- that is the simplest possible radio receiver! This super-simple project will not work if you are very far from the station, but it does demonstrate how simple a radio receiver can be.
Here's how it works. Your wire antenna is receiving all sorts of radio signals, but because you are so close to a particular transmitter it doesn't really matter. The nearby signal overwhelms everything else by a factor of millions. Because you are so close to the transmitter, the antenna is also receiving lots of energy -- enough to drive an earphone! Therefore, you don't need a tuner or batteries or anything else. The diode acts as a detector for the AM signal as described in the previous section. So you can hear the station despite the lack of a tuner and an amplifier!
Bạn có thể tham khảo thêm tại đây: http://electronics.howstuffworks.com/radio9.htm
hoặc bạn có thể tìm quyển này để tham khảo cách làm: Potato Radio, Dizzy Dice, and More Wacky, Weird Experiments from the Mad Scientist“Tôi chỉ có một sự ham muốn, ham muốn tột bậc, là làm sao cho nước ta được hoàn toàn độc lập, dân ta được hoàn toàn tự do, đồng bào ai cũng có cơm ăn áo mặc, ai cũng được học hành”
Muốn nghe được radio loại này thì phải có cái ống nghe tổng trở cao thường thấy trong máy điện thoại đĩa số thời trước dây nối ống nghe với kim gút< loại dài đầu có núm nhựa tròn > là dây nhiều sợi kính 2 ly xoắn lại với nhau củ khoai phải còn tươi héo khô không dùng được chuối xiêm cắt đôi cũng xài được tuy không bằng khoai tây mới đầu tôi dùng khoai như hướng dẫn chừng bắt được đài rối mới thử sang các loại củ quả khác thì thấy chuối xiêm cũng dò dược đài còn chuối già hay chuối khác thì không dò được,hai kim gút cắm trên mặt củ khoai hoạt động giống như diod tách sóng dây và ống nghe vừa là bộ thu vừa cộng hưởng nghe rất nhỏ chỉ hơn muổi kêu 1 tí vì vậy đêm khuya nghe mới rõ và chỉ bắt được đài đia phương.
Hihi, thú vị thật đấy nhưng thầy địa lý, à quên vật lý của bạn chắc nói tóm tắt quá khiến bạn truyền đạt lại càng tắt hơn. Tôi cũng có nghe các cụ dạy tôi hồi xưa nói rồi, vừa là để vui nhưng cũng là nghiêm túc đấy!
Nhưng phải nói chính xác là: "chế radio dùng nguồn điện từ củ khoai tây". Chỉ cần khéo léo và đủ kiên nhẫn một chút sẽ chế được. Chú ý: Hồi xưa khác với bây giờ lắm đáy nhé, hồi xưa chỉ có mỗi một "đài tiếng nói việt nam, phát thanh từ Hà nội, thủ đô nước cộng hòa ..." nên sau khi tỉ mỉ và kiên nhẫn 1 hồi là có thể nghe thấy tiếng chị Kim Cúc đọc truyện đêm khuya ngay, chứ còn bây giờ sóng sách nó như biển trong giông bão thế này, phẩm chất tỉ mỉ và kiên nhẫn phải đòi hỏi cao gấp 10 các cụ ngày xưa mới có hy vọng. Còn cụ thể mạch như thế nào thì mỗ tôi không dám múa rìu qua mắt các bác thợ cao tần trên này
"Imagination is better than knowledge. Knowledge is limited. Imagination encircles the world" - Albert Einstein
theo tôi củ khoai tây là để làm nguồn : khi cắm 2 que kim loại khác nhau ( đồng và kẽm ) vào củ khoai tây thì sẽ sinh ra điện gióng như pin vậyNguyên văn bởi duong_act Xem bài viếtCách này nghe còn có vẻ khả thi và đoạn dây dài 10m may ra tạo được dòng đủ lớn để làm cái headphone nói được chứ còn củ khoai tây thì có lẽ không được.Tôi đã thử dùng ăng ten cao 7m ,headphone,3 quả pin (4.5V) và 1 con transistor C945 mới nghe được tiếng đài.Đấy là chưa chọn sóng,, các đài cãi lộn lẫn nhau còn nếu chọn sóng làm tín hiệu suy giảm thì chưa biết thế nào.Do vậy tôi nghĩ làm từ củ khoai tây có lẽ ông thầy nào đó đã nói quá lên đôi chút.
Không phải đâu vì nếu làm nguồn thì cái headphone giống như được mắc vào quả pin và chẳng có gì xảy ra.Hơn nữa nồng độ của chất điện li trong củ khoại tây nhỏ và kích thước 2 thanh kim loại cũng không lớn( vì phải cắm được vào củ khoai tây) nên suất điện động tạo ra là rất nhỏ, không đáng kể gì.Nguyên văn bởi huuphuong Xem bài viếttheo tôi củ khoai tây là để làm nguồn : khi cắm 2 que kim loại khác nhau ( đồng và kẽm ) vào củ khoai tây thì sẽ sinh ra điện gióng như pin vậy
trang web http://sci-toys.com/scitoys/scitoys/...ade_radio.html có mấy cái mạch radio hay hay, cứ thử rồi tính tiếp, có thể làm cái cuộn dây to to ra, bắt nhạy hơn nhìu
Được.Nguyên văn bởi maiquoctuan Xem bài viếtsax ko có tụ xoay lấy tụ thường dc ko vậy
L và C cộng hưởng với tần số.
Thay đổi tần số cộng hưởng thì thực hiện 1 trong 2 cách sau:
- Thay đổi L, giử C cố định.
- Thay đổi C, giử L cố định.
Chúc vui.
hôm nay, 00:05 -
Hôm qua, 13:38 -
16-12-2025, 09:13 -
