download từ ieee
Anh download giúp em tài liệu này với ạ. Em cám ơn......
Learning feedback controller design of switching converters via MATLAB/SIMULINK
Juing-Huei Su Jiann-Jong Chen Dong-Shiuh Wu
Dept. of Electron. Eng., Lunghwa Univ. of Sci. & Technol.;
This paper appears in: Education, IEEE Transactions on
Publication Date: Nov 2002
Volume: 45, Issue: 4
On page(s): 307- 315
ISSN: 0018-9359
INSPEC Accession Number: 7464601
Digital Object Identifier: 10.1109/TE.2002.803403
Current Version Published: 2002-12-10
Đây là link của nó:
mình đang cần các tài liệu này, các bác có thể giúp mình được không:
[2] R. Coifman, V. Rokhlin, and S.Wandzura, “The fast multipole method
for the wave equation: A pedestrian prescription,” IEEE Antennas
Propagat. Mag., vol. 35, pp. 7–12, 1993.
[4] E. Bleszynski, M. Bleszynski, and J. Jaroszewicz, “AIM: Adaptive integral
method for solving large-scale electromagnetic scattering and
radiation problems,” Radio Sci., vol. 31, pp. 1225–1251, 1996.
[5] M. F. Catedra, R. P. Torres, J. Basterrechea, and E. Gago, The CG-FFT
Method: Application of Signal Processing Techniques to Electromagnetics.
Boston, MA: Artech, 1995.
[6] J. M. Jin, J. L. Volakis, and J. D. Collins, “A finite element boundary
integral method for scattering and radiation by two- and three-dimensional
structures,” IEEE Antennas Propagat. Mag., vol. 33, pp. 22–32,
Jun. 1991.
[7] J. L. Volakis, A. Chatterjee, and L. C. Kempel, “Review of the finiteelement
method for three-dimensional electromagnetic scattering,” J.
Opt. Soc. Amer. A, vol. 11, no. 4, pp. 1422–1433, Apr. 1994.
[8] J. M. Jin and V. V. Liepa, “Application of hybrid finite element method
to electromagnetic scattering from coated cylinders,” IEEE Trans. Antennas
Propagat., vol. AP-36, no. 1, pp. 50–54, Jan. 1988.
[9] J. Liu, Y. Lin, J.-H. Lee, E. Simsek, and Q. H. Liu, “Application of
the hybrid spectral integral method with spectral element method,” in
Proc. IEEE Ant. Propagat. Soc. Int. Symp., Honolulu, HI, Jun. 2007, p.
5611.
[11] T. Xiao and Q. H. Liu, “Enlarged cells for the conformal FDTD method
to avoid the time step reduction,” IEEE Microw. Wireless Compon.
Lett., vol. 14, no. 12, pp. 551–553, Dec. 2004.
[12] T. Xiao and Q. H. Liu, “A 3-D enlarged cell technique (ECT) for the
conformal FDTD method,” IEEE Trans. Antennas Propagat., vol. 56,
no. 3, pp. 765–773, Mar. 2008.
Xin chân thành cảm ơn và hậu tạ.Last edited by Bluewind188; 21-07-2009, 08:54.
Bài của bạn now_nevNguyên văn bởi now_nev Xem bài viết@bluewind: bạn ko thể bớt chút thời gian tìm link trên ieee cho mỗi paper rồi post trên đây để nhờ các anh down giúp sao? chẳng lẽ bạn mún các anh phải tìm link rồi down cho bạn lun???
@all: Tớ remove file này đi vì Now_nev đã nhận được bài.
Thấy có tận 5 bạn load mà chưa thấy nhấn thank
Cám ơn bác now_new nhiều.Nguyên văn bởi now_nev Xem bài viết@bluewind: bạn ko thể bớt chút thời gian tìm link trên ieee cho mỗi paper rồi post trên đây để nhờ các anh down giúp sao? chẳng lẽ bạn mún các anh phải tìm link rồi down cho bạn lun???
2.http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
6.http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
8.http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
9.http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
11.http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
12.http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
Còn 2 tài liệu 5,7 bác nào có thì share mình với.
Mình thực sự rất cần, mong các bác giúp đỡ.
Xin chân thành cảm ơn và hậu tạLast edited by Bluewind188; 22-07-2009, 10:18.
Không hiểu lắm những điều bạn nóiNguyên văn bởi Bluewind188 Xem bài viếtCám ơn bác now_new nhiều.
Nho ban download giup bai bao
Optimal slab heating control with temperature trajectoryoptimization
Yoshitani, N. Ueyama, T. Usui, M.
Instrum. & Autom. Lab., Nippon Steel Corp., Chiba;
This paper appears in: Industrial Electronics, Control and Instrumentation, 1994. IECON '94., 20th International Conference on
dia chi email cua minh la trungac@tnut.edu.vn
Bác Taolao, Bác Jeff... download giup em tai lieu nay Em cam on rat nhieu
email cua em la: trungac@tnut.edu.vn
Các bác có thể Download cho em tài liệu này không?
Mail của em là kaiju85@yahoo.com
Thanks các Bác nhiều ^_^
Polynomial solutions for the direct kinematic problem of planarthree-degree-of-freedom parallel manipulators
Gosselin, C.M. Sefrioui, J.
Dept. de Genie Mecanique, Laval Univ., Ste-Foy, Que.;
This paper appears in: Advanced Robotics, 1991. 'Robots in Unstructured Environments', 91 ICAR., Fifth International Conference on
Publication Date: 19-22 Jun 1991
On page(s): 1124-1129 vol.2
Meeting Date: 06/19/1991 - 06/22/1991
ISBN: 0-7803-0078-5
References Cited: 12
INSPEC Accession Number: 4474225
Digital Object Identifier: 10.1109/ICAR.1991.240405
Current Version Published: 2002-08-06
Abstract
Presents a general solution for the direct kinematics of planar three-degree-of-freedom parallel manipulators. It has been shown elsewhere, using geometric considerations, that this problem can lead to a maximum of six real solutions. The formulation developed leads to a polynomial of the sixth order which is hence minimal. This is illustrated with an example, taken from the literature, for which six real solutions have been found. Moreover, for a special geometry in which the three joints on the platform and on the base are respectively aligned, it is shown that the solution can be cascaded in two steps involving the solution of a cubic and a quadratic respectively. This particular class of planar parallel manipulators can therefore be solved in closed-form and no more than four real solutions have been found in this case. Examples of this class of manipulators are also solved
Link: http://ieeexplore.ieee.org/xpl/freea...rnumber=240405
nhờ bác ptt3i down dùm em mấy tài liệu này cái ah
chaos in the colpitts oscillator
Simulation and experimental study of chaos generation in microwave band using Colpitts circuit
email của em la mythuat66@yahoo.com
cảm ơn bác nhiều
Giúp em download bài báo
Nhờ các bác download giúp em bài báo này với ah
Email : sonnh.imsat@gmail.com
System for Measuring Power Supply Parameters with ZigBee Connectivity
Ascariz, J.M.R. Boquete, L.
Alcala Univ., Alcala de Henares;
This paper appears in: Instrumentation and Measurement Technology Conference Proceedings, 2007. IMTC 2007. IEEE
Publication Date: 1-3 May 2007
On page(s): 1-5
ISSN: 1091-5281
ISBN: 1-4244-0588-2
INSPEC Accession Number: 9718043
Digital Object Identifier: 10.1109/IMTC.2007.379344
Current Version Published: 2007-06-25
Abstract
This paper presents a low cost system for measuring characteristic power supply parameters with ZigBee protocol connectivity. Its main feature is its use of the ZigBee protocol as the communication medium between the various modules. The hardware system is based on the ADE7758 integrated circuit, an Atmega32 microcontroller and an Xbee module. The system provides continuous mains monitoring, sending data to the control unit when necessary. A description is given of the main communication-system parameters of interest to us here, for the purposes of this application: power consumption and response time.
Link: http://ieeexplore.ieee.org/xpl/freea...number=4258186
Cám ơn các bác nhiều!
