Đọc cardreader của siemens theo chuẩn Wiegand ! cách giải mã 52 bit ra số site code (5 số) của hd card.
  • Đọc cardreader của siemens theo chuẩn Wiegand ! cách giải mã 52 bit ra số site code (5 số) của hd card.
    Không up được file chứ không mình up luôn software kiểm soát xử lí data từ bo đọc về pc viết bằng VB6.0 luôn. Củ chuối qua ngay cả file hex cũng không úp được?
    D0 EQU P3.2 ;NGAT NGOAI 0
    D1 EQU P3.3 ;NGAT NGOAI 1
    RX EQU P3.0
    TX EQU P3.1
    COUNT EQU 40H
    DEM EQU 41H
    DL_BY1 EQU 42H
    DL_BY2 EQU 43H
    STACK EQU 4AH
    DATA1 EQU 20H
    DATA2 EQU 21H
    DATA3 EQU 22H
    DATA4 EQU 23H
    DATA5 EQU 24H
    DATA6 EQU 25H
    DATA7 EQU 26H
    ; ;30H->3D LA 14 BYTE LUU MA ACCII CUA CHUOI WIEGAND 52 BIT.CARD READER 5355A-900,REV N.1;
    ACI1 EQU 30H
    ACI2 EQU 31H
    ACI3 EQU 32H
    ACI4 EQU 33H
    ACI5 EQU 34H
    ACI6 EQU 35H
    ACI7 EQU 36H
    ACI8 EQU 37H
    ACI9 EQU 38H
    ACI10 EQU 39H
    ACI11 EQU 3AH
    ACI12 EQU 3BH
    ACI13 EQU 3CH
    ACI14 EQU 3DH
    XLDT_BIT BIT 7FH
    INT_SEC BIT 7EH
    FIST_BIT BIT 7DH
    ERROR_BIT BIT 7CH
    LED_D BIT P3.4
    LED_X BIT P3.5
    ORG 00H
    SJMP START
    ORG 03H ;VECTOR NGAT NGOAI 0
    CLR INT_SEC ;CO CHON NGAT
    LJMP RECE_BIT ;NHAY DEN TRINH NGAT
    ORG 13H ;------------------1
    SETB INT_SEC ;CO CHON NGAT
    LJMP RECE_BIT ;;NHAY DEN TRINH NGAT
    ORG 23H ;NOI TIEP
    ORG 30H ;
    START:
    MOV SP,#STACK ;CHUYEN NGAN XEP VI TRI KHAC
    setb RX ;SET CAC CHAN SERIAL LEN CAO
    setb TX
    setb D0 ;SET CAC CHAN NGAT NGOAI LEN CAO
    setb D1
    MOV SCON,#50H ;
    MOV TMOD,#20H ;
    MOV TH1,#0FDH ;9600
    MOV IE,#10000000B ;CHO PHEP NGAT NGOAI 0,1, NOI TIEP
    SETB TCON.0 ;NGAT THEO SUON NGAT NGOAI 0
    SETB TCON.2 ;NGAT THEO SUON 1
    SETB TR1
    CLR XLDT_BIT
    CLR ERROR_BIT
    MOV DEM,#0
    CHUKIMOI:
    SETB IE.0 ;BAT NGAT NGOAI 0;BAT DAU MOT CHU TRINH DOC MOI
    SETB IE.2 ;VA NGAT NGOAI 1
    SETB LED_X
    SETB LED_D
    MOV R1,#ACI1 ;XOA CAC BYTE CHUA ACCII
    XOA_TIEP:
    MOV @R1,#0
    INC R1
    CJNE R1,#ACI14+1,XOA_TIEP
    MOV DATA1,#0 ;XOA DATA CU CON TON LAI
    MOV DATA2,#0
    MOV DATA3,#0
    MOV DATA4,#0
    MOV DATA5,#0
    MOV DATA6,#0
    MOV DATA7,#0
    MOV R1,#0
    MOV R2,#0
    MOV R3,#0
    MOV R4,#0
    MOV R5,#0
    MOV R6,#0
    MOV R7,#0
    MOV COUNT,#4 ;NAP 8 BIT CHO BYTE
    MOV R0,#DATA7 ;20HBAT DAU CHU KY NHAN ID THE
    DKM: JNB RI,GMTD
    MOV A,SBUF
    CLR RI
    CALL MOTUDO
    GMTD:
    JNB XLDT_BIT,DKM
    JNB ERROR_BIT,BT
    CLR ERROR_BIT
    LJMP CHUKIMOI
    BT:
    CLR IE.0 ;TAT NGAT NGOAI 0;DE XU LI DATA
    CLR IE.2 ;VA NGAT NGOAI 1
    CLR XLDT_BIT ;co xlb
    ;NEU DAT DELAY CHO NAY SE BI LOI NOI DUNG TG R7
    MOV R1,DATA7
    MOV R2,DATA6
    MOV R3,DATA5
    MOV R4,DATA4
    MOV R5,DATA3
    MOV R6,DATA2
    MOV R7,DATA1
    CALL SITECODE ;ko goi trinh con nay de lay code nguyen thuy(HEX) tu card
    CALL LUOMCODE ;ko goi trinh con nay de lay code nguyen thuy (HEX)tu card
    CALL Hex3DecConv ;ko goi trinh con nay de lay code nguyen thuy (HEX)tu card
    CALL CONVER_BCDACCII
    MOV DEM,#14 ;GUI 14 BYTE
    MOV R0,#ACI14 ;3DH;DIA CHI BAT DAU TINH THEO CHIEU GIAM DAN 14 BYTE LUU ACCII
    GU_TIEP:
    MOV SBUF,@R0
    JNB TI,$
    CLR TI
    DEC R0
    DJNZ DEM,GU_TIEP ;KHI R0 = ACI1 THI THOAT LOOP
    ; CALL WAITT
    CALL WAITT ;doi de khoi bi loi ngat
    CALL WAITT
    CALL PHANHOI
    LJMP CHUKIMOI
    PHANHOI:
    MOV DL_BY1,#255
    CNR: JB RI,N
    DJNZ DL_BY1,CNR
    CALL WAITT
    CALL WAITT
    CALL WAITT
    CLR LED_D
    CLR LED_X
    SJMP VEAGAIN ;LOI NHAY VE LAI
    N: MOV A,SBUF
    CLR RI
    CJNE A,#52H,CHECKT1t
    CLR LED_X
    CALL WAITT ;TRE CHO LED SANG
    CALL WAITT
    CALL WAITT
    CALL WAITT
    CALL WAITT
    SJMP VEAGAIN
    CHECKT1t:
    CJNE A,#0BH,CHECKT111
    CLR LED_D
    CALL WAITT
    CALL WAITT
    CALL WAITT
    CALL WAITT
    SJMP VEAGAIN
    CHECKT111:
    ; CLR LED_X
    ; CLR LED_D
    ; CALL WAITT ;TRE CHO LED SANG
    CALL WAITT
    CALL WAITT
    CALL WAITT
    VEAGAIN:
    RET
    MOTUDO:
    CJNE A,#0CH,CHE122
    CLR LED_X
    SJMP VTD
    ;mo cua tu do tai day
    CHE122:
    CJNE A,#0DH,VTD
    CLR LED_D
    SJMP VTD
    VTD: RET
    ;======================DATA1
    RECE_BIT:
    CJNE R0,#DATA1,STOGE11
    MOV A,DATA1
    SJMP LUU_BIT1
    STOGE11:
    CJNE R0,#DATA2,STOGE12
    MOV A,DATA2
    SJMP LUU_BIT1
    STOGE12:
    CJNE R0,#DATA3,STOGE13
    MOV A,DATA3
    SJMP LUU_BIT1
    STOGE13:
    CJNE R0,#DATA4,STOGE14
    MOV A,DATA4
    SJMP LUU_BIT1
    STOGE14:
    CJNE R0,#DATA5,STOGE15
    MOV A,DATA5
    SJMP LUU_BIT1
    STOGE15:
    CJNE R0,#DATA6,STOGE16
    MOV A,DATA6
    SJMP LUU_BIT1
    STOGE16:
    CJNE R0,#DATA7,STOGE17
    MOV A,DATA7
    SJMP LUU_BIT1
    STOGE17:
    CLR LED_D
    ;SJMP $
    SETB ERROR_BIT
    RETI
    LUU_BIT1:
    JNB INT_SEC,LUU_BIT0
    SETB C
    SJMP ROTO
    LUU_BIT0:
    CLR C
    ROTO:
    RLC A
    CJNE R0,#DATA1,STO11
    MOV DATA1,A
    SJMP LUU_BYTE1
    STO11: CJNE R0,#DATA2,STO12
    MOV DATA2,A
    SJMP LUU_BYTE1
    STO12: CJNE R0,#DATA3,STO13
    MOV DATA3,A
    SJMP LUU_BYTE1
    STO13: CJNE R0,#DATA4,STO14
    MOV DATA4,A
    SJMP LUU_BYTE1
    STO14: CJNE R0,#DATA5,STO15
    MOV DATA5,A
    SJMP LUU_BYTE1
    STO15: CJNE R0,#DATA6,STO16
    MOV DATA6,A
    SJMP LUU_BYTE1
    STO16: CJNE R0,#DATA7,STO17
    MOV DATA7,A
    SJMP LUU_BYTE1
    STO17:
    CLR LED_X
    SETB ERROR_BIT
    ;SJMP $
    RETI
    LUU_BYTE1:
    DJNZ COUNT,HET_1BYTE ;TT1
    CJNE R0,#DATA1,KT_STRING
    SETB XLDT_BIT
    CALL RORR7DATA
    RETI ;THOAT KHOI NGAT VE XU LI CHUOI DATA STRING DA NHAN
    KT_STRING:
    MOV COUNT,#8 ;NAP LAI 8 BIT CHO BYTE MOI
    DEC R0 ;CHUYEN LEN BYTE CAO HON
    HET_1BYTE:
    RETI
    WAITT:
    MOV DL_BY1,#250
    CCC: MOV DL_BY2,#250
    DJNZ DL_BY2,$
    DJNZ DL_BY1,CCC
    RET
    CONVER_BCDACCII:
    MOV A,R1
    SWAP A
    CALL BCD_ACCII
    MOV ACI14,A
    MOV A,R1
    CALL BCD_ACCII
    MOV ACI13,A
    MOV A,R2
    SWAP A
    CALL BCD_ACCII
    MOV ACI12,A
    MOV A,R2
    CALL BCD_ACCII
    MOV ACI11,A
    MOV A,R3
    SWAP A
    CALL BCD_ACCII
    MOV ACI10,A
    MOV A,R3
    CALL BCD_ACCII
    MOV ACI9,A
    MOV A,R4
    SWAP A
    CALL BCD_ACCII
    MOV ACI8,A
    MOV A,R4
    CALL BCD_ACCII
    MOV ACI7,A
    MOV A,R5
    SWAP A
    CALL BCD_ACCII
    MOV ACI6,A
    MOV A,R5
    CALL BCD_ACCII
    MOV ACI5,A
    MOV A,R6
    SWAP A
    CALL BCD_ACCII
    MOV ACI4,A
    MOV A,R6
    CALL BCD_ACCII
    MOV ACI3,A
    MOV A,R7
    SWAP A
    CALL BCD_ACCII
    MOV ACI2,A
    MOV A,R7
    CALL BCD_ACCII
    MOV ACI1,A
    RET
    BCD_ACCII:
    ANL A,#0FH
    CJNE A,#0,TT1
    ADD A,#30H ;CHUYEN RA ACCII NEU 0<A<9
    RET
    TT1:
    CJNE A,#1,TT2
    RET
    TT2:
    CJNE A,#2,TT3
    RET
    TT3:
    CJNE A,#3,TT4
    RET
    TT4:
    CJNE A,#4,TT5
    RET
    TT5:
    CJNE A,#5,TT6
    RET
    TT6:
    CJNE A,#6,TT7
    RET
    TT7:
    CJNE A,#7,TT8
    RET
    TT8:
    CJNE A,#8,TT9
    RET
    TT9:
    CJNE A,#9,TT10
    RET
    TT10:
    CJNE A,#0AH,TT11
    ADD A,#37H
    TT11:
    CJNE A,#0BH,TT12
    ADD A,#37H
    RET
    TT12:
    CJNE A,#0CH,TT13
    ADD A,#37H
    RET
    TT13:
    CJNE A,#0DH,TT14
    ADD A,#37H
    RET
    TT14:
    CJNE A,#0EH,TT15
    ADD A,#37H
    RET
    TT15:
    CJNE A,#0FH,TT16
    ADD A,#37H
    TT16: RET
    RORR7DATA:
    MOV DL_BY1,#2 ;QUAY 2 LAN
    CON_RT:
    MOV A,DATA1
    MOV C,ACC.0 ;COPY BIT THAP NHAT VAO C
    MOV A,DATA7
    RRC A
    MOV DATA7,A
    MOV A,DATA6
    RRC A
    MOV DATA6,A
    MOV A,DATA5
    RRC A
    MOV DATA5,A
    MOV A,DATA4
    RRC A
    MOV DATA4,A
    MOV A,DATA3
    RRC A
    MOV DATA3,A
    MOV A,DATA2
    RRC A
    MOV DATA2,A
    MOV A,DATA1
    RRC A
    MOV DATA1,A
    DJNZ DL_BY1,CON_RT
    RET
    LUOMCODE:
    MOV R5,DATA5
    MOV R6,DATA4
    MOV R7,DATA3
    MOV DL_BY1,#4 ;QUAY 4 LAN
    CON_LC:
    CLR C
    MOV A,R5
    RRC A
    MOV R5,A
    MOV A,R6
    RRC A
    MOV R6,A
    MOV A,R7
    RRC A
    MOV R7,A
    DJNZ DL_BY1,CON_LC
    RET
    SITECODE:
    MOV R7,DATA1
    MOV R6,DATA2
    MOV R5,#0
    CALL Hex3DecConv
    MOV A,R7
    MOV R3,A
    MOV A,R6
    MOV R2,A
    MOV A,R5
    MOV R1,A
    RET
    ;3 bytes of hex number to decimal convertion routine
    ;number in r5,r6,r7 (r5-msb,..,r7-lsb), result in r4,r5,r6,r7
    ;the routine counts, how many times you can subtract the 1000000 from numer, then 100000,10000,1000,100,10,1
    ;each counter equals position of decimal number f.e.:
    ; 1E74 hex - you can subtract 1000 seven (7) times, 100 seven (7) times, 10 nine (9) times and the rest
    ;is six (6), so your result of conversion is 7796 (equals 1E74)
    Hex3DecConv: CLR C
    MOV R4,#0 ;milion counter clear
    Hex3DecLoop1: MOV A,R7 ;how many time we can subtract 10000000 without carry (989680H)
    SUBB A,#80H
    MOV R7,A
    MOV A,R6
    SUBB A,#96H
    MOV R6,A
    MOV A,R5
    SUBB A,#98H
    MOV R5,A
    JC Hex3DecSkip1
    INC R4
    JMP Hex3DecLoop1
    Hex3DecSkip1: MOV A,R4
    PUSH ACC ;push counter onto stack
    MOV A,R7
    ADD A,#80H
    MOV R7,A
    MOV A,R6
    ADDC A,#96H
    MOV R6,A
    MOV A,R5
    ADDC A,#98H
    MOV R5,A
    CLR C
    MOV R4,#0
    Hex3DecLoop2: MOV A,R7 ;how many times we can subtract 1000000 (F4240H) without carry
    SUBB A,#40H
    MOV R7,A
    MOV A,R6
    SUBB A,#42H
    MOV R6,A
    MOV A,R5
    SUBB A,#0FH
    MOV R5,A
    JC Hex3DecSkip2
    INC R4
    JMP Hex3DecLoop2
    Hex3DecSkip2: MOV A,R4
    MOV A,R7
    ADD A,#40H
    MOV R7,A
    MOV A,R6
    ADDC A,#42H
    MOV R6,A
    MOV A,R5
    ADDC A,#0FH
    MOV R5,A
    CLR C
    MOV R4,#0
    Hex3DecLoop3: MOV A,R7 ;100000 (186A0H)?
    SUBB A,#0A0H
    MOV R7,A
    MOV A,R6
    SUBB A,#86H
    MOV R6,A
    MOV A,R5
    SUBB A,#01H
    MOV R5,A
    JC Hex3DecSkip3
    INC R4
    JMP Hex3DecLoop3
    Hex3DecSkip3: MOV A,R4
    PUSH ACC ;onto stack
    MOV A,R7
    ADD A,#0A0H
    MOV R7,A
    MOV A,R6
    ADDC A,#86H
    MOV R6,A
    MOV A,R5
    ADDC A,#01H
    MOV R5,A
    Hex2DecConv: MOV R4,#0
    CLR C
    Hex2DecLoop1: MOV A,R7 ;10000 (2710h)?
    SUBB A,#010H
    MOV R7,A
    MOV A,R6
    SUBB A,#27H
    MOV R6,A
    MOV A,R5
    SUBB A,#0
    MOV R5,A
    JC Hex2DecSkip1
    INC R4
    JMP Hex2DecLoop1
    Hex2DecSkip1: MOV A,R4 ;onto stack
    PUSH ACC
    MOV A,R7
    ADD A,#010H
    MOV R7,A
    MOV A,R6
    ADDC A,#27H
    MOV R6,A
    CLR C
    MOV R4,#0
    Hex2DecLoop2: MOV A,R7 ;1000 (3E8h)?
    SUBB A,#0E8H
    MOV R7,A
    MOV A,R6
    SUBB A,#03H
    MOV R6,A
    JC Hex2DecSkip2
    INC R4
    JMP Hex2DecLoop2
    Hex2DecSkip2: MOV A,R4 ;onto satck
    PUSH ACC
    MOV A,R7
    ADD A,#0E8H
    MOV R7,A
    MOV A,R6
    ADDC A,#03H
    MOV R6,A
    CLR C
    MOV R4,#0
    Hex2DecLoop3: MOV A,R7 ;100 (64h)?
    SUBB A,#064H
    MOV R7,A
    MOV A,R6
    SUBB A,#0H
    MOV R6,A
    JC Hex2DecSkip3
    INC R4
    JMP Hex2DecLoop3
    Hex2DecSkip3: MOV A,R4 ;onto stack
    PUSH ACC
    MOV A,R7
    ADD A,#064H
    MOV R7,A
    MOV A,R6
    ADDC A,#0H
    MOV R6,A
    CLR C
    MOV R4,#0
    Hex2DecLoop4: MOV A,R7 ;10 (0Ah)?
    SUBB A,#0AH
    MOV R7,A
    JC Hex2DecSkip4
    INC R4
    JMP Hex2DecLoop4
    Hex2DecSkip4: MOV A,R4 ;onto stack
    PUSH ACC
    ADD A,#0AH ;1
    MOV A,R7 ;tens & ones in w R7
    ADD A,#0AH
    MOV R7,A
    POP ACC
    SWAP A
    ADD A,R7
    MOV R7,A
    POP ACC ;thousands & hundreds in R6
    MOV R6,A
    POP ACC
    SWAP A
    ADD A,R6
    MOV R6,A
    POP ACC ;tens thousands & hundreds thousands in R5
    MOV R5,A
    POP ACC
    SWAP A
    ADD A,R5
    MOV R5,A
    POP ACC ;milins & tens milions in R4
    MOV R4,A
    POP ACC
    SWAP A
    ADD A,R4
    MOV R4,A
    RET
    END
  • nick22
    Trả lời cho Máy điện châm ?
    bởi nick22
    01-12-2025, 13:23
