đây là code và mạch của em ạ khi em bật thì màn hình lcd hiển thị nhưng nháy đen liên tục các ace xem giúp em lỗi ở đâu ạ
code ạ
#INCLUDE <16F887.H>
#FUSES NOWDT, PUT, HS, NOPROTECT, NOLVP
#USE DELAY(CLOCK = 20M)
#INCLUDE <TV_LCD.C>
#DEFINE MODE PIN_B0
#DEFINE UP PIN_B1
#DEFINE DOWN PIN_B2
UNSIGNED INT8 GIO, PHUT, GIAY, BDT;
UNSIGNED INT8 GT;
#INT_TIMER1
VOID INTERRUPT_TIMER1()
{ SET_TIMER1 (59286);
BDT++;
Void LCD_HIENTHI()
LCD_COMMAND (0X84); LCD_DATA ("DONG HO");
LCD_COMMAND (0XC4); LCD_DATA (GIO/10 + 0X30);
LCD_DATA (GIO%10 + 0X30); LCD_DATA (":");
LCD_DATA (PHUT/10 + 0X30); LCD_DATA (PHUT%10 + 0X30);
LCD_DATA (":"); LCD_DATA (GIAY/10 + 0X30);
LCD_DATA (GIAY%10 + 0X30);
VOID LCD_NHAPNHAY()
{ IF (GT==1) { LCD_COMMAND (0XC4); LCD_DATA (" ");}
IF (GT==2) { LCD_COMMAND (0XC7); LCD_DATA (" ");}
IF (GT==3) { LCD_COMMAND (0XCA); LCD_DATA (" ");}
VOID BT_MODE()
{ IF (!INPUT (MODE))
{ DELAY_MS (20);
IF (!INPUT (MODE))
{ GT++;
IF (GT==4) GT=0;
WHILE (!INPUT(MODE));
VOID BT_UP()
{ IF (!INPUT (UP))
{ DELAY_MS (20);
IF (!INPUT (UP))
{ SWITCH (GT)
CASE 1: IF (GIO==23) GIO=0;
ELSE GIO++;
BREAK;
CASE 2: IF (PHUT==59) PHUT=0;
ELSE PHUT++;
BREAK;
CASE 3: IF (GIAY==59) GIAY=0;
ELSE GIAY++;
BREAK;
DEFAULT: BREAK;
WHILE (!INPUT (UP));
VOID BT_DOWN()
{ IF (!INPUT (DOWN))
{ DELAY_MS (20);
If (!INPUT (DOWN))
{ SWITCH (GT)
{ CASE 1: IF (GIO==0) GIO=23;
ELSE GIO--;
BREAK;
CASE 2: IF (PHUT==0) PHUT=59;
ELSE PHUT--;
BREAK;
CASE 3: IF (GIAY==0) GIAY=59;
ELSE GIAY--;
BREAK;
WHILE (!INPUT (DOWN));
VOID MAIN()
{ SET_TRIS_D (0X00);
LCD_SETUP();
GIAY=0;
PHUT=0;
GIO=0;
BDT=0;
LCD_HIENTHI();
SETUP_TIMER_1 (T1_INTERNAL|T1_DIV_BY_8);
Set_TIMER1 (59286);
ENABLE_INTERRUPTS (GLOBAL);
ENABLE_INTERRUPTS (INT_TIMER1);
wHILE (TRUE)
IF (BDT<100)
{ LCD_HIENTHI();
LCD_NHAPNHAY();
BT_MODE();
BT_UP();
BT_DOWN();
ELSE
{ BDT=BDT-100;
GIAY++;
IF (GIAY==60)
{ GIAY=0;
PHUT++;
IF (PHUT==60)
{ PHUT=0;
GIO++;
If (GIO==24) GIO=0;
giúp em sửa lỗi nháy liên tục trên màn hình hiển thị lcd
hôm nay, 05:06 -
Quán ăn Vĩnh Yên-
Hôm qua, 21:56 -
Nhà hàng Vĩnh Yên-
Hôm qua, 21:50 -
Do 8 chân G của mosfet được đấu song song thành 2 nhóm nên có cùng biên độ xung kích. Nhưng Q1 và Q2 nằm cuối dãy B3;B4 ờ mức nguồn cao nhất do chân Q có điện áp...-
Hôm qua, 08:29 -
bởi chinhnguyen9
Xem hình có phần thuyết minh bên trong tiện việc quan sát và đọc thuyết minh. Khi G1 high dòng điện chạy theo các đường màu đen khi G2 high dòng điện chạy theo các đường màu nâu đỏ.
Bổ sung một tính chất củng cố cho tên gọi tụ...-
24-04-2024, 01:15 -
23-04-2024, 19:24 -
23-04-2024, 16:05 -
bởi chinhnguyen9Trước đây có thế hệ mạch cân bằng chủ động hoạt động theo nguyên lý so áp giữa 2 cell (hoặc 2 chuỗi) liền kề nếu điện áp này >100mV mach cận bằng sẽ được kích hoạt và sẽ dừng hoạt động cân bằng khi độ chênh điện áp giảm xuống còn 30 mV
Hiện nay có dòng sản phẩm mới gọi là...-
23-04-2024, 07:26 -
20-04-2024, 12:00 -
18-04-2024, 18:24 -
