[Tin đồn] PIC32MZ
  • itx
    Moderator
    • Feb 2008
    • 1365
    [Tin đồn] PIC32MZ
    Mấy bữa nay thấy có tin đồn của mấy tay đi Masters 2013 về con này.
    Có EBI (giao diện bộ nhớ bên ngoài?), microAptiv kec lõi @ 200MHz, DSP, MMU ,2MB Flash.....
    Dự là tháng 10/2013 có mẫu.
    Tung của đã rao bán sản phẩn dựa trên nó DTX Processing family expanding with two new members | Dimitech
    Không biết thế nào, lót gạch hóng.
    Từ chối trách nhiệm:
  • eKhanhHoa
    Banned
    • Sep 2012
    • 105
    Cho DUYPhi đặt ké 1 kit nếu đc. Đã làm PIC32MX, nói chung là rất OK
    • herrtien
      • Aug 2005
      • 94
      PIC32MZ Embedded Connectivity (EC) Family
      32-bit MCUs (up to 2 MB Live-Update Flash and 512 KB SRAM) with Audio and Graphics Interfaces, HS USB, Ethernet, and Advanced Analog.
      Operating Conditions
      •2.0V to 3.6V, -40ºC to +125ºC, DC to 200 MHz
      Core: 200 MHz / 314 DMIPS microAptiv™
      •16 KB I-Cache, 4 KB D-Cache
      •MMU for optimum embedded OS execution
      •microMIPS™ mode for up to 35% smaller code size
      •DSP-enhanced core:
      -Four 64-bit accumulators
      -Single-cycle MAC, saturating and fractional math
      •Code-efficient (C and Assembly) architecture
      Clock Management
      •0.9% internal oscillator
      •Programmable PLLs and oscillator clock sources
      •Fail-Safe Clock Monitor (FSCM)
      •Independent Watchdog Timers (WDT) and Deadman Timer (DMT)
      •Fast wake-up and start-up
      Power Management
      •Low-power modes (Sleep and Idle)
      •Integrated Power-on Reset and Brown-out Reset
      •200 μA/MHz dynamic current (typical)
      Memory Interfaces
      •50 MHz External Bus Interface (EBI)
      •50 MHz Serial Quad Interface (SQI)
      •Graphics interfaces: EBI or PMP
      •Audio data communication: I2S, LJ, and RJ
      •Audio control interfaces: SPI and I2C™
      •Audio master clock: Fractional clock frequencies with USB synchronization
      High-Speed (HS) Communication Interfaces
      (with Dedicated DMA)
      •USB 2.0-compliant High-Speed On-The-Go (OTG) controller
      •10/100 Mbps Ethernet MAC with MII and RMII interface
      Security Features
      •Crypto Engine with a RNG for data encryption/decryption and authentication (AES, 3DES, SHA, MD5, and HMAC)
      •Advanced memory protection:
      -Peripheral and memory region access control
      Direct Memory Access (DMA)
      •Eight channels with automatic data size detection
      •Programmable Cyclic Redundancy Check (CRC)
      Advanced Analog Features
      •12-bit ADC module:
      -28 Msps with six Sample and Hold (S&H) circuits
      -Up to 48 analog inputs
      •Flexible and independent ADC trigger sources
      •Two comparators with 32 programmable voltage references
      •Temperature sensor with ±2ºC accuracy
      •Two CAN modules (with dedicated DMA channels):
      -2.0B Active with DeviceNet™ addressing support
      •Six UART modules (25 Mbps):
      -Supports LIN 1.2 and IrDA® protocols
      •Six 4-wire SPI modules (50 Mbps)
      •SQI configurable as an additional SPI module (50 MHz)
      •Five I2C modules (up to 1 Mbaud) with SMBus support
      •Parallel Master Port (PMP)
      •Peripheral Pin Select (PPS) to enable function remap
      Timers/Output Compare/Input Capture
      •Nine general purpose timers:
      -Nine 16-bit and up to four 32-bit timers/counters
      •Nine Output Compare (OC) modules
      •Nine Input Capture (IC) modules
      •PPS to enable function remap
      •Real-Time Clock and Calendar (RTCC) module
      Input/Output
      •5V-tolerant pins with up to 32 mA source/sink
      •Selectable open drain, pull-ups, and pull-downs
      •External interrupts on all I/O pins
      Qualification and Class B Support
      •AEC-Q100 REVG (Grade 1 -40ºC to +125ºC) planned
      •Class B Safety Library, IEC 60730
      •Back-up internal oscillator
      Debugger Development Support
      •In-circuit and in-application programming
      •4-wire MIPS® Enhanced JTAG interface
      •Unlimited software and 12 complex breakpoints
      •IEEE 1149.2-compatible (JTAG) boundary scan
      •Non-intrusive hardware-based instruction trace
      Integrated Software Libraries and Tools
      •C/C++ compiler with native DSP/fractional support
      •TCP/IP, USB, Graphics, and mTouch™ middleware
      •MFi, Android™, and Bluetooth® audio frameworks
      •μC/OS™, FreeRTOS™, and other popular RTOS kernels
      Cty TNHH Ứng Dụng Phát Triển Công Nghệ ECAPRO
      • quanghuy_125
        • May 2009
        • 382
        Nguyên văn bởi herrtien Xem bài viết
        •DSP-enhanced core:
        Clock Management
        Power Management
        Memory Interfaces
        Security Features
        •12-bit ADC module:
        Input/Output
        Em này đã có chưa hả các bác???
        ĐT : 01676455880
        itx ITX Tìm hiểu thêm về itx
