Giúp đỡ quét led 7 (loại 4 con liền - 12 chân) - có hình minh họa! ^^
  • ga_kon
    • Feb 2011
    • 38
    Các bác nào có kinh nghiệm quét led 7 đoạn giải thích hộ em kái này!
    Có phải vấn đề nằm ở transistor C1815 không!
    Nếu hiển thị bình thường thì sáng đều 4 con, nếu dùng phương pháp quét led thì chỉ có con thứ tư là sáng nhiều!
    Em pó tay rồi! ?????????
  • huuthinh
    • Jan 2013
    • 7
    Đưa code xem thử đi bạn.
    • ga_kon
      • Feb 2011
      • 38
      #include "string.h"
      #include "msp430g2553.h"
      #include <intrinsics.h>
      union reg {
      struct bit {
      unsigned char b0:1;
      unsigned char b1:1;
      unsigned char b2:1;
      unsigned char b3:1;
      unsigned char b4:1;
      unsigned char b5:1;
      unsigned char b6:1;
      unsigned char b7:1;
      }_BIT;
      unsigned char _BYTE;
      union reg* _P1_DIR = (union reg*)0x22 ;
      union reg* _P1_OUT = (union reg*)0x21 ;
      union reg* _P1_IN = (union reg*)0x20 ;
      union reg* _P2_DIR = (union reg*)0x2A ;
      union reg* _P2_OUT = (union reg*)0x29 ;
      union reg* _P2_IN = (union reg*)0x28 ;
      #define GIAY 0x00
      #define PHUT 0x01
      #define GIO 0x02
      #define SCLOUT _P2_OUT->_BIT.b0
      #define SDAIN _P2_IN->_BIT.b1
      #define SDAOUT _P2_OUT->_BIT.b1
      #define L1 _P2_OUT->_BIT.b2
      #define L2 _P2_OUT->_BIT.b3
      #define L3 _P2_OUT->_BIT.b4
      #define L4 _P2_OUT->_BIT.b5
      #define Led _P1_OUT->_BIT.b4
      #define delay_1 nop()
      void nop(void)
      int i=20;
      while(i--);
      volatile unsigned int giay,gio,phut;
      unsigned char maled[]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x0 9};
      unsigned int a=0;
      //================================== GIAO TIEP DS1307 ==========================
      void I2C_start(void)
      _P2_DIR->_BIT.b0 =1;
      _P2_DIR->_BIT.b1 =1;
      SDAOUT = 1; SCLOUT = 1;
      delay_1;
      SDAOUT = 0; delay_1;
      SCLOUT = 0; delay_1;
      void I2C_stop(void)
      SCLOUT = 1; SCLOUT = 0;
      SCLOUT = 1; delay_1;
      SDAOUT = 1;
      unsigned char I2C_write(unsigned char dat)
      unsigned char i;
      for (i=0;i<8;i++)
      SDAOUT = (dat & 0x80) ? 1:0;
      SCLOUT=1;SCLOUT=0;
      dat<<=1;
      SCLOUT = 0;
      return dat;
      unsigned char I2C_read(void)
      _P2_DIR->_BIT.b1 =0;
      char rd_bit;
      unsigned char i, dat;
      dat = 0x00;
      for(i=0;i<8;i++) // Vong lap doc 1 byte du lieu
      delay_1;
      rd_bit = SDAIN; // Kiem tra ACK
      dat = dat<<1;
      dat = dat | rd_bit;
      SCLOUT = 0;
      return dat;
      // CAC CHUONG TRINH CON CHO DS1307
      unsigned char DS1307_Read(unsigned char addr)
      unsigned int temp,ret;
      I2C_start(); /* Start i2c bus */
      I2C_write(0xD0); /* Connect to DS1307 */
      I2C_write(addr); /* Request RAM address on DS1307 */
      I2C_write(0XD1); /* Connect to DS1307 for Read */
      ret = I2C_read(); /* Receive data */
      I2C_stop();
      temp = ret; //BCD to HEX
      ret = (((ret/16)*10)+ (temp & 0x0f)); //for Led 7seg
      return ret;
      void DS1307_Write(unsigned char addr,unsigned char dat)
      unsigned int temp;
      temp = dat ; //HEX to BCD
      dat = (((dat/10)*16)|(temp %10)); //for Led 7seg
      I2C_write(0XD0); /* Connect to DS1307 */
      I2C_write(dat); /* Connect to DS1307 for Read */
      I2C_stop();
      void Read_DS1307()
      giay = DS1307_Read(GIAY);
      phut = DS1307_Read(PHUT);
      gio = DS1307_Read(GIO);
      void Write_DS1307()
      DS1307_Write(GIAY,giay);
      DS1307_Write(PHUT,phut);
      DS1307_Write(GIO,gio);
      //================================== HIEN THI ==================================
      void Hienthi()
      Read_DS1307();
      if(giay%2==0) a=0;
      else a=1;
      L1=0;L2=0;L3=0;L4=0;
      P1OUT=gio/10;
      L1=1;
      __delay_cycles(1000);
      P1OUT=gio%10;
      Led=a;
      L2=1;
      P1OUT=phut/10;
      L3=1;
      P1OUT=phut%10;
      L4=1;
      //========================== CHUONG TRINH CHINH ================================
      void main(void)
      // Stop watchdog timer to prevent time out reset
      WDTCTL = WDTPW + WDTHOLD;
      BCSCTL1 = CALBC1_1MHZ;
      DCOCTL = CALDCO_1MHZ;
      _P1_DIR->_BYTE = 0xFF;
      _P2_DIR->_BIT.b2 = 1;
      _P2_DIR->_BIT.b3 = 1;
      _P2_DIR->_BIT.b4 = 1;
      _P2_DIR->_BIT.b5 = 1;
      while(1)
      Hienthi();
      • ga_kon
        • Feb 2011
        • 38
        À, mình đã test thử khả năng có thể xảy ra!
        Lạ lùng là với trường hợp đếm từ 0000 đến 9999 với phương pháp quét led thì led 7 sáng đủ 4 con! có nghĩa là trường hợp quét led bị vấn đề là không thể!
        Vậy chả lẻ nào liên quan đến DS1307???
        Thế thì chả biết khắc phục thế nào!
        • THSANG AUTO
          • Jul 2012
          • 893
          Nguyên văn bởi ga_kon Xem bài viết
          cái sai đầu tiên là dùng loại bjt pnp chứ ko phải npn . cái thứ 2 là phải có tở 470-1k nối từ vđk ra chân b của bjt . và cái thứ 3 là phải có R330 nối từ chân vđk đến các chân a.b.c.d, của led.
          facebook:
          • queduong
            Moderator
            • Jul 2005
            • 6781
            quét có tính chu kỳ sao không dùng mảng và vòng lặp cho nó đơn giản hơn không . Vừa dễ đồng bộ vừa dễ kiểm soát !
            --- Hàm đọc ds1307 có thời gian trễ quá dài ... Led 4 được om lâu nên nó sáng nhất cũng là phải thôi !
            ( còn mấy cái sai về mạch điện - transistor , điện trở ... thì chưa nói )
            ga_kon Tìm hiểu thêm về ga_kon
