Xin giúp code LED MATRIX 8x32 dùng HC595
  • Xin giúp code LED MATRIX 8x32 dùng HC595
    e đang tìm hiểu 1 cái code chạy led matrix 8x32 hi vọng sẽ làm được 1 cái chạy chữ cho thích... làm kịp thì tết treo lên cửa nhà cho bố mẹ mừng.
    nhưng mà đọc code e không hiểu 1 số lệnh, mong được các pro chỉ giúp
    đây là code:
    Code:
    // Ten chuong trinh : Mach Ledmatrix Run Text
    // Nguoi thuc hien : demon52
    // Ngay thuc hien : 24/10/2012
    // Phien ban : Demo
    // Mo ta phan cung : Dung PIC16F877A - thach anh 20MHz
    // : 74HC595
    // : PortB dung dieu khien!
    // Notes:
    // : dung che do Power On Reset
    #include <16F877A.h>
    #include <def_877a.h>
    #device *=16 adc=10
    #FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT,NOLVP, NOCPD, NOWRT
    #use delay(clock=20000000)
    #include <C:\Users\OnePiece\Pictures\595\string.h>
    #include "font.c"
    #define ic595_sclk1 PIN_B0
    #define ic595_data1  PIN_B1
    #define ic595_lclk1 PIN_B2
    #define ic595_sclk2 PIN_B3
    #define ic595_data2  PIN_B4
    #define ic595_lclk2 PIN_B5
    unsigned int8 next=0,lengh_STR;
    unsigned char count=0;
    unsigned char welcome[]=" http://codientu.org  ";
    unsigned char *str;
    #int_timer0
    void ngat_time0()
       set_timer0(8);
       count++;
       if(count==25){
          count=0;
          next++;
          if(next>=lengh_STR)next=0;
    void Ic74595_Write(char data,char ic,char bits)
       signed char count;
       if(ic==1)
          for(count=bits-1;count>=0;count--)
             if((( data>>count) & 0x01) ==1)
                output_high(ic595_data1);
             else
                output_low(ic595_data1);
             output_high(ic595_sclk1);
             output_low(ic595_sclk1);
          output_high(ic595_lclk1);
          output_low(ic595_lclk1);
       if(ic==2)
                output_high(ic595_data2);
             else
                output_low(ic595_data2);
             output_high(ic595_sclk2);
             output_low(ic595_sclk2);
          output_high(ic595_lclk2);
          output_low(ic595_lclk2);
    void Run_str_RtoL()
       lengh_str=strlen(str)*6;
       unsigned char j,temp_font;
       Ic74595_Write(1,1,1);
       for(j=next;j<32+next;j++){
          Temp_font=font[str[(j%lengh_STR)/With_of_font] -32][j%With_of_font];
          Ic74595_Write(temp_font,2,8);
          //delay_us(500);
          Ic74595_Write(0,1,1);
    void main (){
       TRISB=0x00;
       enable_interrupts(int_timer0);
       setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
       enable_interrupts(global);
       set_timer0(8);
       str=welcome;
        while(true){
                Run_str_RtoL();
    đây là đoạn mà e không hiểu:
    Code:
    void Run_str_RtoL()
          //delay_us(500);
    đại ca/đại tỷ nào hảo tâm thì vào chỉ giúp e nhé.
    còn 1 chuyện nữa e xin được chỉ giáo luôn, code này e làm mạch trên bo test thấy chạy đc đúng như mô phỏng, kể ra thì không cần hiểu code cũng có thể làm mạch rồi cho chạy chữ như ý mình rồi, nhưng mà CCS của e build code này lại bị lỗi nó chỉ vào file string.h, e không biết xử lý thế nào, lỗi là: "C\....\string.h" Line 191(37,38): Expecting an identifier
    và nhiều dòng lỗi ở dưới nữa. xin mọi ngưởi chỉ giúp e có phải tại CCS của e lỗi không ạ!
    e xin cảm ơn nhiều!
    hiện tại thì e đã chạy đc cái code này rồi
    nhưng mà có 1 lỗi tai hại mà e không giải quyết đc, đó là khi chạy chữ thì tất cả các cột đều bị nhân đôi (x2) ... ...
    khiến chữ cứ díu dít vào nhau không nhìn ra gì cả, đây là hình minh họa:
    nếu bình thường thì phải thế này:
    thực tế khi chạy lại thế này:
    nhưng nếu là mấy chữ này thì còn nhìn đc chứ phải chữ m với n với w là không thấy j luôn:
    chuẩn là thế này:
    thế mà nó lại thế này:
    Thật là đau buồn quá, xin đại hiệp nào ra tay trượng nghĩa giúp e vụ này với...
      cái lỗi này là do bạn khi chuyển sang quét cột (hàng) bạn chưa tắt cột (hàng) trức đó.
      bạn chỉ cần tắt cột (hàng) trước đó là được.
        Nguyên văn bởi voiviqua Xem bài viết
        cảm ơn bạn, nói có lý quá, chỉnh lại cái chạy ngon ngay.
        cảm ơn nhiều nhé!
          mà bạn ngocnamdhgt2 cho mình xin code và phan cứng của bạn được không.mình cũng đang làm 8x32 mà chưa được(mình quét hàng nhưng không biết cách làm chữ dịch từ phải qua trái lên muốn chuyển sang quét cột xem sao).
            Nguyên văn bởi ngocnamdhgt2 Xem bài viết
            đây là code:
            Code:
            // Phien ban : Demo
            // : 74HC595
            // Notes:
            #device *=16 adc=10
            #include "font.c"
            unsigned char *str;
            #int_timer0
            void ngat_time0()
               set_timer0(8);
               count++;
               if(count==25){
                  count=0;
                  next++;
               signed char count;
               if(ic==1)
                     else
               if(ic==2)
                     else
            void Run_str_RtoL()
                  //delay_us(500);
            void main (){
               TRISB=0x00;
               set_timer0(8);
               str=welcome;
                while(true){
                        Run_str_RtoL();
            Code:
            void Run_str_RtoL()
                  //delay_us(500);
            e xin cảm ơn nhiều!
            bạn cho mình hỏi bạn đã biết nguyên nhân tại sao nó báo lỗi ở string.h line 192(37,38) chưa? nếu biết rồi bạn giải thích cho mình được không?
              Nguyên văn bởi lotan_ht Xem bài viết
              mình nhớ là mình đổi lại thứ tự khai báo các thư viện là được, không nhớ là đổi cái nào nữa. bạn thử xem nhé
                bạn ơi nếu code chạy được rôi bạn up cho mình xin đi
                  code vẫn thế, thêm 1 lệnh thôi mà.
                  Code:
                  // Phien ban : Demo
                  // : 74HC595
                  // Notes:
                  #device *=16 adc=10
                  #include "font.c"
                  unsigned char *str;
                  #int_timer0
                  void ngat_time0()
                     set_timer0(8);
                     count++;
                     if(count==25){
                        count=0;
                        next++;
                     signed char count;
                     if(ic==1)
                           else
                     if(ic==2)
                           else
                  void Run_str_RtoL()
                        //delay_us(500);
                        Ic74595_Write(0xff,2,8);/// thêm lệnh này để tắt LED là ok
                  void main (){
                     TRISB=0x00;
                     set_timer0(8);
                     str=welcome;
                      while(true){
                              Run_str_RtoL();
                    mình dùng code này .....kiểm tra sao báo lỗi là bị j m.n..........nhứ thế này
                    mấy kái thư viện bị lổi j...
                    *** Error 18 "kiet.c" Line 15(10,22): File can not be opened
                    Not in "C:\Program Files (x86)\PICC\devices\def_877a.h"
                    Not in "C:\Program Files (x86)\PICC\drivers\def_877a.h"
                    Not in project "D:\VIXULI\matranchaychu\def_877a.h"
                    *** Error 18 "kiet.c" Line 19(10,51): File can not be opened
                    Not in project "C:\Users\OnePiece\Pictures\595\string.h"
                    *** Error 18 "kiet.c" Line 20(10,18): File can not be opened
                    Not in project "D:\VIXULI\matranchaychu\font.c"
                    Not in "C:\Program Files (x86)\PICC\devices\font.c"
                    Not in "C:\Program Files (x86)\PICC\drivers\font.c"
                    *** Error 12 "kiet.c" Line 80(20,21): Undefined identifier -- strlen
                    *** Error 12 "kiet.c" Line 84(17,21): Undefined identifier font
                    *** Error 12 "kiet.c" Line 95(4,9): Undefined identifier TRISB
                    6 Errors, 0 Warnings.
                    giúp vs
                      m.n hướng dẫn mjh thay chữ codientu.org đc k ạ
                        cảm ơn nhiều nhé!
                        chào bạn, bạn có đó không nhỉ. Mình có một số vấn đề muốn nhờ bạn giúp đỡ, cho mình mail của bạn được không?
                          [QUOTE=voiviqua;n980732]cái lỗi này là do bạn khi chuyển sang quét cột (hàng) bạn chưa tắt cột (hàng) trức đó.
                          bạn chỉ cần tắt cột (hàng) trước đó là được.[/QUOTEào bạn
                          mình gặp vài rắc rối khi quét led ma trận. Bạn cho mình hỏi chút. Khi mình quét dùng hàng cathode, cot anode. đến lúc làm thật gặp led matrix hàng anode, cot cathode mà mình sửa code chưa được. Bạn xem dùm mình được không? Cảm ơn nhiều.
                          ngocnamdhgt2 Tìm hiểu thêm về ngocnamdhgt2
