Help me PIC16f887
  • Help me PIC16f887
    Giúp e cái code mikroC này với. E ko hiểu cái chương trình con getADC().
    E ko hiểu ngay chỗ
    SPI1_Write(0x06);
    channel = channel << 6;
    tmp = SPI1_Read(channel) & 0x0F;
    tmp = tmp << 8;
    tmp |= SPI1_Read(0);
    tại sao lại viết như vậy?
    Bài này là Giao tiếp SPI giữa PIC16f887 với con ADC mcp3204.
    Nguyên code của nó đây:
    sbit Chip_Select_Direction at TRISC0_bit;
    sbit Chip_Select at RC0_bit;
    // LCD module connections
    sbit LCD_RS at RB5_bit;
    sbit LCD_EN at RB7_bit;
    sbit LCD_D4 at RB0_bit;
    sbit LCD_D5 at RB2_bit;
    sbit LCD_D6 at RB4_bit;
    sbit LCD_D7 at RB6_bit;
    sbit LCD_RS_Direction at TRISB5_bit;
    sbit LCD_EN_Direction at TRISB7_bit;
    sbit LCD_D4_Direction at TRISB0_bit;
    sbit LCD_D5_Direction at TRISB2_bit;
    sbit LCD_D6_Direction at TRISB4_bit;
    sbit LCD_D7_Direction at TRISB6_bit;
    // End LCD module connections
    unsigned int measurement, lastValue;
    void Init()
    ANSEL = 0; // Configure AN pins as digital I/O
    ANSELH = 0;
    C1ON_bit = 0; // Disable comparators
    C2ON_bit = 0;
    // Init LCD
    Lcd_Init();
    Lcd_Cmd(_LCD_CLEAR);
    Lcd_Cmd(_LCD_CURSOR_OFF);
    measurement = 0; // Initialize the measurement variable
    // Init SPI
    SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, // Initialize PIC as master
    _SPI_DATA_SAMPLE_END, // Data sample at end
    _SPI_CLK_IDLE_LOW,
    _SPI_LOW_2_HIGH);
    Chip_Select_Direction= 0; // ClearBit(TRISC,0)
    Chip_Select= 0; // SetBit(PORTC,0)
    unsigned int getADC(unsigned short channel)
    // Returns 0..4095
    unsigned int tmp;
    Chip_Select = 0; // Select MCP3204
    SPI1_Write(0x06); // SPI communication using 8-bit segments
    channel = channel << 6; // Bits 7 & 6 define ADC input
    tmp = tmp << 8; // Get ADC value
    Chip_Select = 1;
    return tmp;
    void ProcessValue(unsigned int pv, unsigned short channel)
    { // Writes measured values to LCD
    char i, lcdRow, lcdCol;
    if(channel < 2) lcdRow=1;
    else lcdRow=2;
    if(channel%2 > 0 ) lcdCol=13;
    else lcdCol=4;
    // Converting the measured value into 4 characters
    // and writing them to the LCD at the appropriate place
    i = pv /1000 + 48;
    Lcd_Chr(lcdRow,lcdCol, i);
    pv %= 1000;
    i = pv /100 + 48;
    Lcd_Chr(lcdRow,lcdCol+1, i);
    pv %= 100;
    i = pv /10 + 48;
    Lcd_Chr(lcdRow,lcdCol+2, i);
    pv %= 10;
    i = pv + 48;
    Lcd_Chr(lcdRow,lcdCol+3, i);
    // main procedure
    void main()
    Init();
    // Compilation le
    Lcd_Out(1,1,"Build : " __TIME__);
    Lcd_Out(2,1,"le " __DATE__);
    Delay_ms(2000);
    // Initialize SPI and LCD
    Lcd_Out(1,1,"C0= C1=");
    Lcd_Out(2,1,"C2= C3=");
    while(1)
    measurement = getADC(0); // Get ADC result from Channel 0
    ProcessValue(measurement,0); // Writes measured value to LCD
    Delay_ms(100); // Wait 100ms
    measurement = getADC(1); // Get ADC result from Channel 1
    ProcessValue(measurement,1); // Writes measured value to LCD
    measurement = getADC(2); // Get ADC result from Channel 2
    ProcessValue(measurement,2); // Writes measured value to LCD
    measurement = getADC(3); // Get ADC result from Channel 3
    ProcessValue(measurement,3); // Writes measured value to LCD
    Nếu bạn đọc datasheet của adc thì sẽ hiểu thôi mà
    SPI1_Write(0x06); // bit start + single end mode
    channel = channel << 6; // address of channel
    tmp = SPI1_Read(channel) & 0x0F; //4 bit cao
    tmp = tmp << 8; // dịch bit lên cao
    tmp |= SPI1_Read(0); //đọc nốt 8 bit thấp
        Trước tiên là Cảm ơn a rất nhiều. Nhưng A có thể giải thích cụ thể cho e hơn xíu được hok a?
        0x06 là 00000110 z sao là bit start với single end z a?
        channel sao phải dịch trái 6 rùi mới đọc z a?
        Nguyên văn bởi Ari@132 Xem bài viết
          nếu bạn xem datasheet của ADC, bạn sẽ thấy frame của dữ liệu đc truyền. Việc ghi đọc trong chương trình hoàn toàn dựa trên các bytes này. Mình đoán rằng lệnh read(data)=write(data) + read() nên 2 bit D1 và D0 mới được gửi cho ADC để chọn kênh.
            E ko biết đọc datasheet a ơi!
              Nếu bạn chưa biết đọc datasheet thì nên bắt đầu đọc. Mới đầu khó hiểu, dần dần sẽ vỡ ra. Nếu đọc mãi vẫn không hiểu hoặc không thèm đọc thì tốt nhất là không nên làm món điện tử này. Chỉ để qua bài tập, đề tài ... thì có nhiều cách.
              babytiger9x Tìm hiểu thêm về babytiger9x
              • nick22
                Trả lời cho Máy điện châm ?
                bởi nick22
                01-12-2025, 13:23
