LẬP TRÌNH ĐỒNG HỒ +CHỈNH GIỜ +ÂM THANH+Lỗi
  • LẬP TRÌNH ĐỒNG HỒ +CHỈNH GIỜ +ÂM THANH+Lỗi
    Đây là bài lập trình các bác xem hộ em sao toàn bị lội như sau:
    Build target 'Target 1'
    compiling dongholoade1-8.c...
    DONGHOLOADE1-8.C(93): error C202: 'd': undefined identifier
    DONGHOLOADE1-8.C(94): error C202: 'd': undefined identifier
    Target not created
    //*******LCD code -created by DOAN VU**************
    //******KHI LAP TRINH ,DONG HO SO+LOA+CHINH GIO 24/7/2012******************
    #include <regx51.h>
    #include <E:\LAP TRINHC CHO 8051\THU VIEN\THU VIEN DELAY.h>
    #include <E:\LAP TRINHC CHO 8051\THU VIEN\THU VIEN LCD.h>
    unsigned int x=0;
    unsigned int y=0;
    unsigned int z=0;
    unsigned int count;
    //---------------CHUONG TRINH CON------------------
    void hienthi(void)
    lcd_gottoxy(10,0);
    lcd_putchar(x/10+48);
    lcd_putchar(x%10+48);
    lcd_gottoxy(9,0);
    lcd_putchar(':');
    lcd_gottoxy(7,0);
    lcd_putchar(y/10+48);
    lcd_putchar(y%10+48);
    lcd_gottoxy(6,0);
    lcd_putchar(':');
    lcd_gottoxy(4,0);
    lcd_putchar(z/10+48);
    lcd_putchar(z%10+48);
    void timer1(void) interrupt 3 using 2
    TH1=0xd8;
    TL1=0xf0;
    TR1=1;
    count++;
    if(count>=100){count=0;x++;}
    if(x>=60) { x=0; y++;}
    if(y>=60) { y=0; z++;}
    if(z>=24) { z=0;}
    void nhaycham()
    if( count>50)
    lcd_gottoxy(9,0);
    lcd_putchar(':');
    lcd_gottoxy(6,0);
    lcd_putchar(':');
    else
    lcd_gottoxy(9,0);
    lcd_putchar(' ');
    lcd_gottoxy(6,0);
    lcd_putchar(' ');
    void chinhgio()
    if(P3_0==0){ y++; while(P3_0==0){};}
    if(y>=60){y=0;}
    if(P3_1==0){ z++;while(P3_1==0){};}
    if(z>=24){z=0;}
    if(P3_2==0){ TR1=0;}
    if(P3_3==0){TR1=1;}
    void tinhtoan()
    unsigned int a,d;
    const unsigned int mang[10]={395,395,395,525,395,395,395,395}; //==mang tan so cua am thanh
    for(a=0;a<8;a++)
    d=mang[a];
    void timer0(void) interrupt 1 using 2
    TH0= ((65536-(1000000/(d*2)))%256);//cach tinh ra he 10
    TL0= ((65536-(1000000/(d*2)))/256);
    TR0=1;
    P3_7=~P3_7 ;
    //-------------CHUONG TRINH -----------------------
    void main(void)
    TMOD=TMOD|0x11;
    TH1=0x00;
    TL1=0x10;
    ET1=1;
    EA=1;
    TR1=1;
    lcd_init();
    TH0=0x00;
    TL0=0x10;
    ET0=1;
    EA=1;
    TR0=1;
    lcd_init();
    while(1)
    hienthi();
    nhaycham();
    chinhgio();
    tinhtoan();
    // A LA
    // B SI
    // C DO
    // D RE
    // E MI
    // F PHA
    // G SON
    Yahoo:mr.doan0302@yahoo.com
    Gmail:doanvanvu91@gmail.com
    SDT:01649543156
    biến d chưa được khai báo
    Website chính thức đổi địa chỉ website thành
    Mời các bạn ghé thăm !!!
      Nguyên văn bởi mast090 Xem bài viết
      có trong hàm void tinhtoan rồi mà anh
      gmail :
        trong hàm tính toán đã có biến d, nhưng có lẽ nó báo lỗi biến d trong hàm ngắt của bạn.
          h mới để ý. biến d sử dụng trong ngắt phải là biến toàn cục, hàm ngắt ko truyền biến vào được
          gmail :
            bạn viết lại cho mình đoạn đó được không .tk
            SDT:01649543156
              có lẽ code này là xin ở đâu chứ ko phải tự viết, các biến muốn sử dụng được ở mọi hàm là biến toàn cục, còn biến địa phương chỉ sử dụng được tại chuơng trình con nó khai báo và ko gây ảnh hưởng tới các chương trình con khác nếu cũng có biến tương tự.
              vd như trên, x,y,z là toàn cục. a,d là biến địa phương
                Mình mới học lập trình lên còn chưa thành thạo chứ xin lỗi bạn mast090 tớ không bao giờ đi copy code ,làm thế thì bao giờ mới khá được,nếu chỗ nào mắc thì tớ hỏi .
                SDT:01649543156
                  Nguyên văn bởi doanvu Xem bài viết
                  vậy mình xin nói thế này, bạn đang học viết code 1 cách thụ động, nghĩa là kiểu chỉ cần biết có cái đấy là nó chạy còn tại sao nó chạy thì ko biết. đây là 1 trong như thứ cơ bản nhất của lập trình C và mình nghĩ vs 1 số ngôn ngữ khác cũng vậy. và mình cũng đã ví dụ cho bạn về 2 loại biến ở trên rồi, xem lại nhé
                    bạn sửa lại biến d thành biến toàn cục đi. cái đấy là cái sai trước mắt. còn sai ở đâu thì sửa tiếp
                    gmail :
                    doanvu Tìm hiểu thêm về doanvu
