KeiC tạo file hex dung lượng hơn 2Kb
  • khongtu19bk
    Thành viên mới
    • Mar 2014
    • 11
    Mình code cho 89C2051 sử dụng KeiC nhưng tạo ra file hex phần mềm PL51L cứ báo hơn 2Kb.
    file hex (ko nạp được-báo lỗi):
    Code:
    :10085B00E4FDFCC3ED9FEC9E5015E4FBFA0BBB00D3
    :0F086B00010AEB647B4A70F50DBD00010C80E4BF
    :01087A00225B
    :04087B008E0E8F0F3F
    :10087F00900000C3E582950FE583950E50097FE840
    :07088F007E03115BA380EC66
    :01089600223F
    :040836008E0A8F0B8C
    :10083A00E4F50CF50DC3E50D950BE50C950A501082
    :10084A007F3C7E00117B050DE50D70E9050C80E506
    :01085A00227B
    :10080000E4F508F509C290D2917F057E00117BC204
    :1008100091D2907F057E00117B0509E509700205E4
    :1008200008C39406E508940040DBC290C2917F02A1
    :060830007E00113680CAB3
    :030000000208975C
    :0C089700787FE4F6D8FD75810F020800A0
    :00000001FF
    thử với file hex khác thì nạp được, không báo lỗi
    Code:
    :1001D300E4FEFDEE25E0FEA291E4334206C290EF79
    :1001E30030E702D290EF25E0FFD29200C2920000E6
    :0601F3000DBD08DFAF06A0
    :0101F90022E3
    :10024900758920438780758BFF758DFF759850D20E
    :020259008E22F3
    :0A027800C2998F993099FDC29922B6
    :070282003098FDAF99C2980E
    :010289002252
    :10025B001201FA30980612028212016E12023480D9
    :01026B00F2A0
    :1001FA00750B01D290D291C292C293E4F509F50827
    :10020A00120249438901758C3C758AB0C28DD28C21
    :01021A0022C1
    :10023400308D11E50B6005A2B2B392B2C28D758CFC
    :050244003C758AB022A8
    :10016E00EF24B7601924F9601824FE601D14601482
    :10017E0024FB6013146016240E7015020291020007
    :10018E00030200670200C802021B02011B02028A60
    :04019E001202962291
    :050291007F4F0202781E
    :1000C800C293E4F50BC2B2C292758C3C758AB0C279
    :1000D8008DD28C308DFDC28DD290D291C28C758C10
    :1000E8003C758AB0C28DD293D28C308DFDC28D7F83
    :1000F800AC1201D37F531201D37FFF1201D37FFFCC
    :100108001201D3BF69047F018002E4FF12027875EF
    :020118000B01D9
    :01011A0022C2
    :07028A00C2937F59020278C4
    :10006700C2B2E4F50B7F501202781202828F0C1293
    :1000770002781202828F0D850D101201A27F501295
    :1000870001D3AF0A1201D3AF10120278E4F50EF5CF
    :100097000F1202828F0C1202781202828F0D850DC9
    :1000A700101201A2AF0A1201D3AF10120278050F86
    :1000B700E50F7002050EC3E50E940140D4750B01E0
    :0100C7002216
    :10011B00C2B2E4F50B7F521202781202828F0C12DC
    :10012B0002781202828F0D850D111201A27F3012FF
    :10013B0001D3AF0A1201D3AF11120278E4F50EF519
    :10014B000F1202828F0C7FFF1201D38F10120278D5
    :10015B00050FE50F7002050EC3E50E940140E27525
    :02016B000B0186
    :01016D00226F
    :10021B007FAC1201D37F801201D37FFF1201D37FFA
    :09022B00FF1201D37F5802027892
    :10000300D2B2E4F50B7F281201D3E4FF1201D3E44B
    :10001300FF1201D37FFF1201D38F0E7F281201D36A
    :100023007F011201D3E4FF1201D37FFF1201D38FAB
    :100033000F7F281201D37F021201D3E4FF1201D3F1
    :100043007FFF1201D38F10AF0E1202781202828F3C
    :100053000EAF0F1202781202828F0FAF10120278C6
    :03006300750B0119
    :010066002277
    :010296002245
    :1001A20074D0250CF50CD39409400674F9250CF58E
    :1001B2000C74D0250DF50DD39409400674F9250D64
    :1001C200F50D850C0AE50AC454F0F50AE50D420A5C
    :0101D200220A
    :0300000002026C8D
    :0C026C00787FE4F6D8FD75811102025B7A
    :00000001FF
    Cụ thể code của mình:
    Code:
    #include <REG2051.H>
           void Delay_ms(unsigned int t)
    unsigned int x ,y;
    for (x=0;x<t;x++)
    for (y=0;y<123;y++)
    void Delay_s(unsigned int t)
    unsigned int x;
    for (x=0;x<t;x++)
    Delay_ms(1000); //tre 1s *t
    void Delay_phut(unsigned int t)
    unsigned int x;
    for (x=0;x<t;x++)
    Delay_s(60); //tre 1 phut*t
    void main()
    unsigned int x;
    while(1)
    for (x=0;x<6;x++)
    P1_0=0;
    P1_1 = 1;
    Delay_s(5);
    //------chay xong 5s-------//
    P1_1 = 0;
    P1_0=1;
    Delay_s(5);
    //------chay xong 5s------//
    P1_0 = 0;
    P1_1=0;
    Delay_phut(2);
    //Nghi 30s
    Thạch anh 12Mhz. Ai biết xin mách dùm.
  • phan_it
    • Dec 2005
    • 366
    Hi, chương trinh bạn viết có code ở địa chi xa nhất là 2211, dung lượng của AT89C2051 tối đa 2048 byte. Trước khi nạp chương trình Pl51L có kiểm tra điều này và nó không nạp nữa. nếu dùng chương trình khác để nạp mà chương trình đó không kiểm tra thì vẫn nạp - và có thể vẫn chạy được nhưng một khi nào đó chường trình trỏ đến địa chỉ 2211 thì treo. Đoạn code bạn viết thì không dài mà keil dịch ra .hex như vậy thì kiểm tra lại các tham số enviroment của keil xem đã phù hợp chưa (ví dụ chọn chip, model bộ nhớ, ....).
    0912666017
    • khongtu19bk
      Thành viên mới
      • Mar 2014
      • 11
      Bạn sửa giúp mình rồi up cho mình file hex được ko bạn.
      khongtu19bk Tìm hiểu thêm về khongtu19bk
