Cách gửi xung, đọc và ghi dữ liệu của con 24c64 và 24c00 có giống nhau ko các bác?
Thanks!
Thanks!
)#include <reg2051.h>
//#include <reg52.h>
//#include <intrins.h>
//#include "E:\KeilC_uVision4\common.h"
sbit SCL = P3^0;
sbit SDA = P3^1;
//extern delay_nop();
void delay_nop()
_nop_();
_nop_();
_nop_();
_nop_();
void i2c_start(void)
SDA = 1;
delay_nop();
SCL = 1;
delay_nop();
SDA = 0;
delay_nop();
SCL = 0;
void i2c_stop(void)
SCL = 0;
SDA = 0;
delay_nop();
SCL = 1;
delay_nop();
SDA = 1;
unsigned char i2c_read(bit ack)
unsigned char data i, result;
result = 0;
SDA = 1; //select input direction
delay_nop();
SCL = 0;
for(i = 0; i < 8; i++)
delay_nop();
SCL = 1;
delay_nop();
result <<= 1;
if(SDA == 1) result++;
SCL = 0;
delay_nop();
SDA = (ack == 1)? 0:1;
delay_nop();
SCL = 1;
delay_nop();
SCL = 0;
return result;
bit i2c_write(unsigned char value)
unsigned char data i, temp;
bit bdata ack;
temp = value;
SCL = 0;
SCL = 0;
delay_nop();
SDA = (temp & 0x80)? 1:0;
delay_nop();
SCL = 1;
SCL = 1;
delay_nop();
SCL = 0;
SCL = 0;
temp <<= 1;
SDA = 1; // read ACK
delay_nop();
SCL = 1;
SCL = 1;
ack = SDA;
delay_nop();
SCL = 0;
SCL = 0;
return ack;
#define RTC_SLAVE_ADDRESS 0xD0
#define RTC_READ_COMMAND RTC_SLAVE_ADDRESS | 0x01
#define RTC_WRITE_COMMAND RTC_SLAVE_ADDRESS
struct Time
char second;
char minute;
char hour;
//char day;
//char date;
//char month;
//char year;
extern i2c_start();
extern i2c_stop();
extern bit i2c_write(unsigned char value);
extern unsigned char i2c_read(bit ack);
extern delay_us(unsigned int us);
void delay_us(unsigned int us)
while(us--);
extern delay_nop();
void DS1307_init()
unsigned char x;
i2c_start();
i2c_write(RTC_WRITE_COMMAND); //Write slave address
i2c_write(0x00);
i2c_start();
i2c_write(RTC_READ_COMMAND);
x = i2c_read(0); // Read second with NACK
i2c_stop();
delay_us(10);
i2c_start();
i2c_write(0x00); // Go to Second Reggister
i2c_write(x & 0x7F); // start DS1307
i2c_stop();
i2c_start();
i2c_write(0x07); // Go to Control Reggister
i2c_write(0x10); // configure RTC
i2c_stop();
struct Time DS1307_get_time()
struct Time t;
i2c_start();
i2c_write(0x00); // Go to top of memory
i2c_start();
t.second = i2c_read(1); // Read with ACK
t.minute = i2c_read(1);
t.hour = i2c_read(0);
i2c_stop();
return t;
struct Time DS1307_get_date_time()
struct Time t;
i2c_start();
i2c_start();
t.hour = i2c_read(1);
t.day = i2c_read(1);
t.date = i2c_read(1);
t.month = i2c_read(1);
t.year = i2c_read(0);
i2c_stop();
return t;
void DS1307_set_time(struct Time t)
i2c_start();
i2c_write(0x00);
i2c_write(t.second);
i2c_write(t.minute);
i2c_write(t.hour);
i2c_stop();
void DS1307_set_date_time(struct Time t)
i2c_start();
i2c_write(0x00);
i2c_write(t.hour);
i2c_write(t.day);
i2c_write(t.date);
i2c_write(t.month);
i2c_write(t.year);
i2c_stop();
void DS1307_write(char addr, char value)
i2c_start();
i2c_write(addr);
i2c_write(value);
i2c_stop();
unsigned char DS1307_read(char addr)
unsigned char value;
i2c_start();
i2c_write(addr);
i2c_start();
value = i2c_read(0);
i2c_stop();
return value;
