mach do nhiet do giup voi !!!
  • hahai
    • Mar 2010
    • 189
    Chao cac ban trong dien dan,
    Minh dang lam mach do nhiet do nhưng khi mo phong thi nó nhay, ko hieu sao nua code ktra di ktra lai nhung chua tim duoc cho sai, cac ban trong dien dan ai da lam ve mach do nhiet do chi giup voi, cam on cac ban rat nhieu, mình gui file mophong va code len cac ban giup mình voi nhe.
    Chuong trinh
    #include<stdio.h>
    #include<reg52.h>
    #include<math.h>
    sbit INTR_ADC=P3^6;
    sbit WR_ADC=P3^7;
    sbit T=P1^6;//nut bam Tang
    sbit G=P1^7;//nut bam Giam
    sbit D=P3^3;//den Do
    sbit V=P3^4;//den Vang
    sbit X=P3^5;//den Xanh
    long int x,k,ch,dv,d,ndkc;
    float v;
    unsigned long int i;
    unsigned char M[10]={0XC0,0XF9,0XA4,0XB0,0X99,0X92,0X82,0XF8,0X80,0X9 0};
    void tre (unsigned long int t)
    for(i=0;i<=t;i++);
    void hienthi()
    P1=1;P0=M[ch];tre(70);
    P1=2;P0=M[dv];tre(70);
    P1=4;P0=0X9C ;tre(70);
    P1=0;//cac Led sang dong deu
    void dat()
    if((T==1)||(G==1)) {d=0;tre(250);}//bam nut thi reset bien dem d, tao tre giua cac lan bam
    d=d+1;//dem qua trinh lap cua chuong trinh nay
    if (T==1) ndkc=ndkc+1;
    if (G==1) ndkc=ndkc-1;
    ch=ndkc/10;
    dv=ndkc%10;
    hienthi();
    void main()
    ndkc=20;
    while(1)
    T=0;
    G=0;
    if((T==1)||(G==1))//kiem tra nut bam nhiet do khong che
    while(1)
    dat();
    if(d==100) break;//neu lap 100 lan ma k co su tac dong nut bam thi thoat
    WR_ADC=0;//cho phep ADC bien doi
    tre(100);//thoi gian tre cho ADC bien doi xong
    WR_ADC=1;//khong cho ADC bien doi
    x=P2;//gan gia tri bien doi vao x
    v=x*2.5/255;
    k=v*100;//nhiet do thuc
    ch=k/10;
    dv=k%10;
    if(k>ndkc) {D=1;V=0;X=0;}
    if(k==ndkc){D=0;V=1;X=0;}
    if(k<ndkc) {D=0;V=0;X=1;}
    hienthi();
  • hahai
    • Mar 2010
    • 189
    Nguyên văn bởi hahai Xem bài viết
    Chuong trinh
    #include<stdio.h>
    #include<reg52.h>
    #include<math.h>
    sbit INTR_ADC=P3^6;
    sbit WR_ADC=P3^7;
    float v;
    for(i=0;i<=t;i++);
    void hienthi()
    void dat()
    ch=ndkc/10;
    dv=ndkc%10;
    hienthi();
    void main()
    ndkc=20;
    while(1)
    T=0;
    G=0;
    while(1)
    dat();
    v=x*2.5/255;
    ch=k/10;
    dv=k%10;
    hienthi();
    • mast090
      • Oct 2010
      • 1018
      những đoạn khác mình ko đọc, mình chỉ đọc đoạn này của bạn, cái tre(100) kìa ko phải là chờ adc biến đổi xong mà trễ tạo clock thôi, như thế này thì ko chạy đâu, sửa lại
      while(INT_ADC==0);// day moi la cho ADC chuyen doi xong, chan int dc dua len muc 1 thi thoat(ly thuyet la muc 0 nhung minh lam thuc te no la muc 1)
      Website chính thức đổi địa chỉ website thành
      Mời các bạn ghé thăm !!!
      • hahai
        • Mar 2010
        • 189
        #4
        cam on ban da quan tam toi bai viet cua minh va loi minh dang gap pai, nhung khi minh sua lai quan code ma ban viet thi bien dich no bao loi dung doan while(INT_ADC==0)
        cac ban ai da tung lam giup minh giai quyet van de nay voi nhe,
        • mast090
          • Oct 2010
          • 1018
          #5
          lỗi là phải
          cái kia bạn khai báo là INTR_ADC, còn tôi viết là INT_ADC, nhìn vào INT là phải suy ra dc nó là chân ngắn int của ADC
          điều này chứng tỏ bạn còn chưa chịu xem xét qua code thì làm sao có thể hiểu dc code, tốt nhất là bạn hãy đọc lại kĩ code để hiểu thuật toán, hiểu con ADC làm việc như thế nào, sau đó hãng đưa thắc mắc, hỏi như thế này thì có đến sáng mai ko hết
          • hahai
            • Mar 2010
            • 189
            #6
            Cam on ban,
            mình da chinh sua lai nhung tinh hinh van ko co gi sang sua ca, van bi nhay nhu giang ngo vay, ko hieu sao nua, doan minh sua lai nhu the nay:
            while(k==0 && INTR_ADC==1) k=0;
            v=x*2.5/255;
            cac ban giup minh voi gio ko biet pai lam the nao nua,
            • chung1608
              • Sep 2009
              • 4160
              #7
              Cam on ban,
              v=x*2.5/255;
              đề nghị bạn viết có dấu. Bạn nói "nhảy" hay là "nháy" cũng ko biết. Up file mô phỏng, code .C và .hex để ACE kiểm tra cho dễ
              • fee_08
                • Mar 2011
                • 201
                #8
                Cho thơi gian lấy mẫu lớn lên xem , cho cái delay to vào , thường thì mạch thật mới lỗi chứ mô phỏng chả bao giờ bị nháy cả ,
                Tham khảo bài này : Đo nhiệt độ sử dụng cảm biến LM35 - Do nhiet do su dung cam bien LM35 - MachDienTu.Tk - Mạch điện tử ứng dụng | mạch điện tử lý thú | led trái tim | led cube |khoa học - công nghệ ...
                • hahai
                  • Mar 2010
                  • 189
                  #9
                  Nháy led hàng đơn vị ! Đã cho thời gian delay lên nhưng hiện tượng vẫn vậy ! VD: nhiệt độ là 18 thì nó nhẩy số 7.8.9 liên tục ! Cac bạn ai biet giúp mình với !
                  • hahai
                    • Mar 2010
                    • 189
                    #10
                    đây là file mophong và file code các bạn giúp mình với nhé, các bạn xem có chỗ nào sai ko mà nó cứ nhẩy số liên tục, VD: nhiệt độ hiện tại đo được là: 18 độ thì nó cứ nhẩy cái số 8 ấy liên tục trong các số 7.8.9 chứ nó ko đứng yên khi nhiệt độ đo được về
                    link: New Folder.rar
                    các bạn giúp mình với,
                    cảm ơn các bạn rất nhiều,
                    • hahai
                      • Mar 2010
                      • 189
                      #11
                      không có ai giúp mình với,
                      mình đã chỉnh sửa mấy chỗ rồi mà nó vẫn cứ có hiện tượng như trên, ko thể khắc phục được có ai biết lỗi là gì ko giúp mình với mình cảm ơn các bạn rất nhiều,
                      hahai Tìm hiểu thêm về hahai
