Xin hướng dẫn đoạn code matlab wiener filter này!
  • Xin hướng dẫn đoạn code matlab wiener filter này!
    Code:
    function output=WienerScalart96(signal,fs,IS)
    % output=WIENERSCALART96(signal,fs,IS)
    % Wiener filter based on tracking a priori SNR usingDecision-Directed
    % method, proposed by Scalart et al 96. In this method it is assumed that
    % SNRpost=SNRprior +1. based on this the Wiener Filter can be adapted to a
    % model like Ephraims model in which we have a gain function which is a
    % function of a priori SNR and a priori SNR is being tracked using Decision
    % Directed method.
    % Author: Esfandiar Zavarehei
    % Created: MAR-05
    if (nargin<3 | isstruct(IS))
        IS=.25; %Initial Silence or Noise Only part in seconds
    end
    W=fix(.025*fs); %Window length is 25 ms
    SP=.4; %Shift percentage is 40% (10ms) %Overlap-Add method works good with this value(.4)
    wnd=hamming(W);
    %IGNORE FROM HERE ...............................
    if (nargin>=3 & isstruct(IS))%This option is for compatibility with another programme
        W=IS.windowsize
        SP=IS.shiftsize/W;
        %nfft=IS.nfft;
        wnd=IS.window;
        if isfield(IS,'IS')
            IS=IS.IS;
        else
            IS=.25;
        end
    end
    % ......................................UP TO HERE
    pre_emph=0;
    signal=filter([1 -pre_emph],1,signal);
    NIS=fix((IS*fs-W)/(SP*W) +1);%number of initial silence segments
    y=segment(signal,W,SP,wnd); % This function chops the signal into frames
    Y=fft(y);
    YPhase=angle(Y(1:fix(end/2)+1,:)); %Noisy Speech Phase
    Y=abs(Y(1:fix(end/2)+1,:));%Specrogram
    numberOfFrames=size(Y,2);
    FreqResol=size(Y,1);
    N=mean(Y(:,1:NIS)')'; %initial Noise Power Spectrum mean
    LambdaD=mean((Y(:,1:NIS)').^2)';%initial Noise Power Spectrum variance
    alpha=.99; %used in smoothing xi (For Deciesion Directed method for estimation of A Priori SNR)
    NoiseCounter=0;
    NoiseLength=9;%This is a smoothing factor for the noise updating
    G=ones(size(N));%Initial Gain used in calculation of the new xi
    Gamma=G;
    X=zeros(size(Y)); % Initialize X (memory allocation)
    h=waitbar(0,'Wait...');
    for i=1:numberOfFrames
        %%%%%%%%%%%%%%%%VAD and Noise Estimation START
        if i<=NIS % If initial silence ignore VAD
            SpeechFlag=0;
            NoiseCounter=100;
        else % Else Do VAD
            [NoiseFlag, SpeechFlag, NoiseCounter, Dist]=vad(Y(:,i),N,NoiseCounter); %Magnitude Spectrum Distance VAD
        end
        if SpeechFlag==0 % If not Speech Update Noise Parameters
            N=(NoiseLength*N+Y(:,i))/(NoiseLength+1); %Update and smooth noise mean
            LambdaD=(NoiseLength*LambdaD+(Y(:,i).^2))./(1+NoiseLength); %Update and smooth noise variance
        end
        %%%%%%%%%%%%%%%%%%%VAD and Noise Estimation END
        gammaNew=(Y(:,i).^2)./LambdaD; %A postiriori SNR
        xi=alpha*(G.^2).*Gamma+(1-alpha).*max(gammaNew-1,0); %Decision Directed Method for A Priori SNR
        Gamma=gammaNew;
        G=(xi./(xi+1));
        X(:,i)=G.*Y(:,i); %Obtain the new Cleaned value
        waitbar(i/numberOfFrames,h,num2str(fix(100*i/numberOfFrames)));
    end
    close(h);
    output=OverlapAdd2(X,YPhase,W,SP*W); %Overlap-add Synthesis of speech
    output=filter(1,[1 -pre_emph],output); %Undo the effect of Pre-emphasis
    function ReconstructedSignal=OverlapAdd2(XNEW,yphase,windowLen,ShiftLen);
    %Y=OverlapAdd(X,A,W,S);
    %Y is the signal reconstructed signal from its spectrogram. X is a matrix
    %with each column being the fft of a segment of signal. A is the phase
    %angle of the spectrum which should have the same dimension as X. if it is
    %not given the phase angle of X is used which in the case of real values is
    %zero (assuming that its the magnitude). W is the window length of time
    %domain segments if not given the length is assumed to be twice as long as
    %fft window length. S is the shift length of the segmentation process ( for
    %example in the case of non overlapping signals it is equal to W and in the
    %case of %50 overlap is equal to W/2. if not givven W/2 is used. Y is the
    %reconstructed time domain signal.
    %Sep-04
    %Esfandiar Zavarehei
    if nargin<2
        yphase=angle(XNEW);
    end
    if nargin<3
        windowLen=size(XNEW,1)*2;
    end
    if nargin<4
        ShiftLen=windowLen/2;
    end
    if fix(ShiftLen)~=ShiftLen
        ShiftLen=fix(ShiftLen);
        disp('The shift length have to be an integer as it is the number of samples.')
        disp(['shift length is fixed to ' num2str(ShiftLen)])
    end
    [FreqRes FrameNum]=size(XNEW);
    Spec=XNEW.*exp(j*yphase);
    if mod(windowLen,2) %if FreqResol is odd
        Spec=[Spec;flipud(conj(Spec(2:end,:)))];
    else
        Spec=[Spec;flipud(conj(Spec(2:end-1,:)))];
    end
    sig=zeros((FrameNum-1)*ShiftLen+windowLen,1);
    weight=sig;
    for i=1:FrameNum
        start=(i-1)*ShiftLen+1;
        spec=Spec(:,i);
        sig(start:start+windowLen-1)=sig(start:start+windowLen-1)+real(ifft(spec,windowLen));
    end
    ReconstructedSignal=sig;
    function Seg=segment(signal,W,SP,Window)
    % SEGMENT chops a signal to overlapping windowed segments
    % A= SEGMENT(X,W,SP,WIN) returns a matrix which its columns are segmented
    % and windowed frames of the input one dimentional signal, X. W is the
    % number of samples per window, default value W=256. SP is the shift
    % percentage, default value SP=0.4. WIN is the window that is multiplied by
    % each segment and its length should be W. the default window is hamming
    % window.
    % 06-Sep-04
    % Esfandiar Zavarehei
    if nargin<3
        SP=.4;
    end
    if nargin<2
        W=256;
    end
    if nargin<4
        Window=hamming(W);
    end
    Window=Window(:); %make it a column vector
    L=length(signal);
    SP=fix(W.*SP);
    N=fix((L-W)/SP +1); %number of segments
    Index=(repmat(1:W,N,1)+repmat((0:(N-1))'*SP,1,W))';
    hw=repmat(Window,1,N);
    Seg=signal(Index).*hw;
    function [NoiseFlag, SpeechFlag, NoiseCounter, Dist]=vad(signal,noise,NoiseCounter,NoiseMargin,Hangover)
    %[NOISEFLAG, SPEECHFLAG, NOISECOUNTER, DIST]=vad(SIGNAL,NOISE,NOISECOUNTER,NOISEMARGIN,HANGOVER)
    %Spectral Distance Voice Activity Detector
    %SIGNAL is the the current frames magnitude spectrum which is to labeld as
    %noise or speech, NOISE is noise magnitude spectrum template (estimation),
    %NOISECOUNTER is the number of imediate previous noise frames, NOISEMARGIN
    %(default 3)is the spectral distance threshold. HANGOVER ( default 8 )is
    %the number of noise segments after which the SPEECHFLAG is reset (goes to
    %zero). NOISEFLAG is set to one if the the segment is labeld as noise
    %NOISECOUNTER returns the number of previous noise segments, this value is
    %reset (to zero) whenever a speech segment is detected. DIST is the
    %spectral distance.
    %Saeed Vaseghi
    %edited by Esfandiar Zavarehei
    %Sep-04
    if nargin<4
        NoiseMargin=3;
    end
    if nargin<5
        Hangover=8;
    end
    if nargin<3
        NoiseCounter=0;
    end
    FreqResol=length(signal);
    SpectralDist= 20*(log10(signal)-log10(noise));
    SpectralDist(find(SpectralDist<0))=0;
    Dist=mean(SpectralDist);
    if (Dist < NoiseMargin)
        NoiseFlag=1;
        NoiseCounter=NoiseCounter+1;
    else
        NoiseFlag=0;
        NoiseCounter=0;
    end
    % Detect noise only periods and attenuate the signal
    if (NoiseCounter > Hangover)
        SpeechFlag=0;
    else
        SpeechFlag=1;
    end
    Đoạn code trên em search được. Em bị ép buộc vào tình thế. Giờ em muốn chạy function này. Xin các bác hướng dẫn em chạy nó với.
    cái input parameters là: signal, fs, IS. Em chưa biết khai báo cái signal như thế nào. Các bác cho ví dụ giúp em với. Em xin cảm ơn!
    Tôi có thể áp dụng các mã số, nhờ để chia sẻ.
      KO hiểu bác lala55 trả lời gì nữa, chắc nhầm tôpic...
      Dù sao thì mình cũng làm được rồi , bảo vệ xong luôn rồi!
      theanh3112 Tìm hiểu thêm về theanh3112
