Học viết chương trình C trên AVR studio
  • #46
    các bác dùng avr studio lâu rồi thì chắc có nhiều thư viện,
    có bác nào có thư viện cho giao thức 1 dây
    và ds18b20 kô?
    bác nào có thì share cho mình với
    thank
    ĐỪNG KHÓC CHO NHỮNG GÌ ĐÃ QUA, MÀ HÃY CƯỜI CHO NHỮNG ĐIỀU SẮP TỚI!
    • #47
      Nguyên văn bởi quocdat_dtvt Xem bài viết
      và ds18b20 kô?
      thank
      Moi trong Blog của mình thấy cái này, bạn đọc xem giúp ích gì không ?
      PHP Code:
      [U][COLOR="Red"]One Wire[/COLOR][/U]
      Sowe are going to write a piece of code that implements the 1-wire protocol.
      Start by gathering infothe first thing to look at is the DS18B20 datasheetget a feeling of what is aboutNo need to understand everything in the datasheetOn Maxim's site there are tones of application notes, I would suggest application notes 162,187,126,120, with this sequence, probably first AVR318 application note which is easy to follow. Come on, show an aggressive attitude, although you don't understand everythingI don't either. Do not copy/paste pieces of code hoping it's going to workit will notFrom the ground we go up. Try to simplify thinks by asking yourself simple questions.
      You see that many thermos can be connected together on a busa micro talks to themso they have to be addressed with a unique ID (think ethernet IP analogy). There is a single wireso only one speaks at a timeWho coordinates discussionThe masterthe micro (forget ethernet analogy). Well, if it does how the hell it knows which thermo is on the busThere is an algorithm for doing thatthe search algorithm. Do I careNonot for this projectwe have a single thermo on the busIs there a way to identify communication errors or malfunctioning thermosThe CRC does that.
      If
      you were a microcontroller, and wanted to talk over your half-duplex conference phone to your fellow thermometerswhat interogation commands you would like to haveThere are a few simple conceptsthat reasonably fit into the puzzleDon't bypass them.
      Hmm, where to start? The first think to try after getting the idea is sending 1s and 0s. Reading 1s and 0s would help too. It comes down to holding the pin for output and releasing it for input. When set for output, the pin can be written, when set for input the pin can be read ... Have a look at the following defs and see if they make any sense.
      // set pin mask
      #define wmask     0x08
      // set 1-wire pin for output
      #define wOut      DDRA |= wmask
      // set 1-wire pin for input (bus released)
      #define wIn       DDRA &= ~wmask
      // set 1-wire bus high
      #define wH        PORTA |= wmask
      // set 1-wire bus low
      #define wL        PORTA &= ~wmask
      // get 1-wire bus input (bus released)
      #define wR        PINA & wmask
      Now, this is just pin toggling, from that we need to get to the basic bus signals. Let'
      s go one level upHmmwait a minuteit looks like we need a delay firstOKThink of ...
      // delay = 5.70 + (1.22 * count)us
      void uDelay(u8 count)
          while(
      count--);
      This is a delay but how long does it lastYou need to simulate your code with AVRStudioplease do soGo to Debug => AVR Simulator Options => Frequency=7.3728 MHzAfter compilingDebug => Start Debuggingpress F11 a couple of times and look at the stopwatchYou may reset your stopwatch by right clicking on itI hope you get the same result as I diddelay 5.70 1.22 count microseconds for a 7.3728MHz clockOne time slot is 60us and looking at the AVR318 appnote we can realize how to output 1s and 0s....
      void wTxbit (u8 bit)
      wOut;wL;
         if (
      bit)
      uDelay (4);      // 10.58us
      wIn;
      uDelay (46);     // 61.82us
         else
      wIn;             // better releash the bus
      Delay constrains have to be met butthe protocol timing is not very strictOnto the read routine ...
      u8 wRxbit (void)
      u8 data;
      wOut;wL;
      uDelay (0);         // 10.58us
      wIn;
      data=wR;
      uDelay (23);        // 61.82us
      return data;
      Your time has comeafter clearly understanding the aboveyou have to implement the Reset/Presence signalLucky you
      • #48
        Nguyên văn bởi thienluong
        AVR studio chủ yếu dùng để viết bằng ngôn ngữ ÁM thôi , nó rất mạnh và hay trong việc gỡ rối mô phỏng bên ASM , còn viết bằng C thì dùng CodeVisionAVR là hay nhất
        Ngày xưa khi còn học thì mình cũng đã làm tốt với codevision, nhưng cảm thấy nó không thực sự tốt vì mình phụ thuộc nhiều vào phần mềm, và mình không khoái nó lắm, sau một năm không đụng chạm gì đến, giờ không còn chữ nào trong bụng cả, hi hi, thế là mình có thể coi như tờ giấy trắng với AVR.
        Vậy thì sao nhỉ? mình bắt đầu học từ mớ i(từ sáng nay), dĩ nhiên là mình ngốn kha khá tài liệu và không nhớ gì mấy. tuy nhiên, mình thấy AVR studio tốt hơn nhiều, hỗ trợ mạnh với C/C++, bạn chỉ cần cài đặt thêm winavr là ngon, cách tốt nhất là cài winavr trước và cài avr studio sau, nếu cài avr studio trước thì ta configuration option là được mà, ^^.
        Vũ xuân Lợi
        YM!:
        • #49
          hjx , theo mình đc pít thì AVR_studio hỗ trợ cả 2 loại ngôn ngữ C và ASM mà . bạn setup WinAVR trước rồi setup AVR_studio bản full là ok mà . tha hồ mà lập trình nhá !
          ................. Pleiku .................... GIA LAI ...................
          • #50
            Cho em hỏi, cài AVR Studio 5 là đã tích hợp sẵn WINAVR rồi hả mấy bác?
            • #51
              Nguyên văn bởi schanbkhn Xem bài viết
              mình cũng mới học về AVR , nói chúng thấy cũng chẳng dễ lắm , để mà am hiểu tường tận về AVR , theo mình thì nên tham khảo qua datasheet của nó , và đọc 1 số sách tiếng anh ( mình search thấy rất ít sách tiếnh anh , sách tiếng nga thì nhiều hơn 1 chút ... )nếu chỉ đọc 1 ít sách ( tiếng việt ) thì e là không hiểu hết ..., viết code cho AVR bằng ASM , sau đó dùng AVRstudio để check ... đọc phần hướng dẫn sử dụng của nó thì cũng khá đầy đủ ... tuy nhiên , cũng có nhiều điều chưa biết về mấy cái này , chịu khó hỏi cũng có nhiều anh em giúp đỡ ...
              Nhưng dù sao thì chúng ta cũng cần 1 trình biên dịch đủ tốt để viết code
              Mình bắt đầu viết bằng C cho avrstudio,nhìn chung còn hạn chế
              Bạn có thể chỉ cho mình tìm hiểu các câu lệnh của avrstudio 6 không? thank
              chi_co_nui Tìm hiểu thêm về chi_co_nui
