Source VB6 chỉnh Hiệu ứng Led Sao Băng
  • #46
    cho mình hỏi chút? sao dùng code này nạp vào 89s52 lại không thể tắt hẳn được led nhỉ ( mặc dù set led ko sáng ) nhưng led ko tắt hẳn mà vẫn sáng mờ mờ!
    code như sau:
    #include<regx51.h>
    char NumPort=16;
    char PWM[32];
    char chuki=0;
    void SetPort(char i, char v)
    switch (i)
    case 0:
    P1_0
    = v; return;
    case 1:
    P1_1
    = v; return;
    case 2:
    P1_2
    = v; return;
    case 3:
    P1_3
    = v; return;
    case 4:
    P1_4
    = v; return;
    case 5:
    P1_5
    = v; return;
    case 6:
    P1_6
    = v; return;
    case 7:
    P1_7
    = v; return;
    case 8:
    P3_0
    = v; return;
    case 9:
    P3_1
    = v; return;
    case 10:
    P3_2
    = v; return;
    case 11:
    P3_3
    = v; return;
    case 12:
    P3_4
    = v; return;
    case 13:
    P3_5
    = v; return;
    case 14:
    P3_6
    = v; return;
    case 15:
    P3_7
    = v; return;
    case 16:
    P2_0
    = v; return;
    case 17:
    P2_1
    = v; return;
    case 18:
    P2_2
    = v; return;
    case 19:
    P2_3
    = v; return;
    case 20:
    P2_4
    = v; return;
    case 21:
    P2_5
    = v; return;
    case 22:
    P2_6
    = v; return;
    case 23:
    P2_7
    = v; return;
    case 24:
    P0_0
    = v; return;
    case 25:
    P0_1
    = v; return;
    case 26:
    P0_2
    = v; return;
    case 27:
    P0_3
    = v; return;
    case 28:
    P0_4
    = v; return;
    case 29:
    P0_5
    = v; return;
    case 30:
    P0_6
    = v; return;
    case 31:
    P0_7
    = v; return;
    void Timer0()interrupt 1
    char i;
    TF0=0;
    TR0=0; //stop ngat
    for (i=0 ; i<NumPort ; i++)
    if (chuki <=
    PWM[i]) SetPort(i,1);
    else
    SetPort(i,0);
    chuki += 10; //Tang 7,8,9,10 se bot chop
    if (chuki >= 100) chuki=0;
    TR0=1; //tiep tuc ngat
    void delay(unsigned int ms)
    unsigned int i, j;
    for(i=0 ; i<ms ; i++)
    for(j=0 ; j<120 ; j++) {}
    void ResetPWM()
    unsigned char i;
    for(i=0 ; i<NumPort ; i++)
    PWM[i]=0;
    main()
    EA=0;
    TMOD=0x02; //timer 0 - che do 2 - 8 bit tu dong nap lai
    TH0 = 156;
    TL0 = 156;
    ET0=1;
    EA=1;
    TR0=1;
    while (1)
    delay(10);
    ResetPWM();
    PWM[8]=100;PWM[10]=5;PWM[11]=16;PWM[12]=32;PWM[13]=49;PWM[14]=64;PWM[15]=75;//1
    delay(10);
    ResetPWM();
    PWM[8]=75;PWM[9]=100;PWM[11]=5;PWM[12]=16;PWM[13]=32;PWM[14]=49;PWM[15]=64;//2
    delay(10);
    ResetPWM();
    PWM[8]=64;PWM[9]=75;PWM[10]=100;PWM[12]=5;PWM[13]=16;PWM[14]=32;PWM[15]=49;//3
    delay(10);
    ResetPWM();
    PWM[8]=49;PWM[9]=64;PWM[10]=75;PWM[11]=100;PWM[13]=5;PWM[14]=16;PWM[15]=32;//4
    delay(10);
    ResetPWM();
    PWM[0]=100;PWM[1]=100;PWM[2]=100;PWM[3]=100;PWM[4]=100;PWM[5]=100;PWM[6]=100;PWM[7]=100;PWM[8]=32;PWM[9]=49;PWM[10]=64;PWM[11]=75;PWM[12]=100;PWM[14]=5;PWM[15]=16;//5
    delay(10);
    ResetPWM();
    PWM[0]=100;PWM[1]=100;PWM[2]=100;PWM[3]=100;PWM[4]=100;PWM[5]=100;PWM[6]=100;PWM[7]=100;PWM[8]=16;PWM[9]=32;PWM[10]=49;PWM[11]=64;PWM[12]=75;PWM[13]=100;PWM[15]=5;//6
    delay(10);
    ResetPWM();
    PWM[8]=5;PWM[9]=16;PWM[10]=32;PWM[11]=49;PWM[12]=64;PWM[13]=75;PWM[14]=100;//7
    delay(10);
    ResetPWM();
    PWM[9]=5;PWM[10]=16;PWM[11]=32;PWM[12]=49;PWM[13]=64;PWM[14]=75;PWM[15]=100;//8
    delay(10);
    ResetPWM();
    PWM[0]=100;PWM[1]=100;PWM[2]=100;PWM[3]=100;PWM[4]=100;PWM[5]=100;PWM[6]=100;PWM[7]=100;PWM[8]=100;PWM[10]=5;PWM[11]=16;PWM[12]=32;PWM[13]=49;PWM[14]=64;PWM[15]=75;//9
    delay(10);
    ResetPWM();
    PWM[0]=100;PWM[1]=100;PWM[2]=100;PWM[3]=100;PWM[4]=100;PWM[5]=100;PWM[6]=100;PWM[7]=100;PWM[8]=75;PWM[9]=100;PWM[11]=5;PWM[12]=16;PWM[13]=32;PWM[14]=49;PWM[15]=64;//10
    delay(10);
    ResetPWM();
    PWM[8]=64;PWM[9]=75;PWM[10]=100;PWM[12]=5;PWM[13]=16;PWM[14]=32;PWM[15]=49;//11
    delay(10);
    ResetPWM();
    PWM[8]=49;PWM[9]=64;PWM[10]=75;PWM[11]=100;PWM[13]=5;PWM[14]=16;PWM[15]=32;//12
    delay(10);
    ResetPWM();
    PWM[8]=32;PWM[9]=49;PWM[10]=64;PWM[11]=75;PWM[12]=100;PWM[14]=5;PWM[15]=16;//13
    delay(10);
    ResetPWM();
    PWM[8]=16;PWM[9]=32;PWM[10]=49;PWM[11]=64;PWM[12]=75;PWM[13]=100;PWM[15]=5;//14
    delay(10);
    ResetPWM();
    PWM[8]=5;PWM[9]=16;PWM[10]=32;PWM[11]=49;PWM[12]=64;PWM[13]=75;PWM[14]=100;//15
    delay(10);
    ResetPWM();
    PWM[9]=5;PWM[10]=16;PWM[11]=32;PWM[12]=49;PWM[13]=64;PWM[14]=75;PWM[15]=100;//16
    thanks
    • #47
      Nguyên văn bởi quangvinh2k8 Xem bài viết
      Dưới đây là chương trình đã chỉnh sửa để không còn bị giật hình nữa
      Chương trình cài đặt: LedShow setup.zip
      Nếu đã cài thì cập nhật lại: LedShow.exe
      ví dụ về Led Sao băng: SaoBang.led
      Source VB6: LedShow VB6.zip
      Bác nào up lại mấy file này dùm em với,link die rồi.
      ĐT: 0972 20 58 68
      Gmail:
      • #48
        up....................
        • #49
          if (chuki <= PWM[i]) SetPort(i,1); //bỏ dấu = đi bạn. mình đang xài bản mới cho phép lên đến 300 dòng với 32 port, 8KB tha hồ làm, do k ai quan tâm nên k up
          else
          SetPort(i,0);
          • #50
            Bạn nào còn giữ source trên cho mình xin lại giúp, ổ cứng bị mọt ăn die hết rồi
            • #51
              link die rồi anh ơi!
              • #52
                em cũng khoái cái này lắm sao anh không viết biên dịch ra file hex luôn cho anh em tahm khảo chứ tạo ra c rồi biên dịch ra he dùng phần mền khác cũng hơi bất tiện
                quangvinh2k8 Tìm hiểu thêm về quangvinh2k8
