Để mình coi lại xem nhé.Mai lên Hà nội mua con lcd mới vậy.Làm đủ mọi cách mà không thấy động tĩnh gì cả chỉ hiển thị vài ký tự linh tinh.
Nhưng dù sao cũng cảm ơn các bác nhé.
bit ký hiệu ý nghĩa
+1:0 P0.0 00 GPIO Port 0.0 00
01 TXD (UART0)
10 PWM1
11 Reserved
bit ký hiệu ý nghĩa
01 TXD (UART0)
10 PWM1
11 Reserved
/*------------------------------ CHUONG TRINH GIAO TIEP LCD------------------------------- */
// Cac chan dung cho giao tiep LCD
//P0.0 - P0.7 = D0 - D7
//P0.8 = LCD_EN
//P0.9 = LCD_RS
//P0.10 = LCD_RW
/* Include file */
#include <LPC214x.h>
/* Define LCD PinIO Mask */
#define LCD_EN 0x00000100 // P0.8(0000 0000 0000 0000 0000 000x 0000 0000)
#define LCD_RS 0x00000200 // P0.9(0000 0000 0000 0000 0000 00x0 0000 0000)
#define LCD_RW 0x00000400 // P0.10(0000 0000 0000 0000 0000 0x00 0000 0000)
#define LCD_BUS 0x000000ff // P0.0-P0.7(0000 0000 0000 0000 0000 0000 xxxx xxxx)
#define lcd_en_set() IOSET0 = LCD_EN // EN = 1 (Enable)
#define lcd_en_clr() IOCLR0 = LCD_EN // EN = 0 (Disable)
#define lcd_rs_set() IOSET0 = LCD_RS // RS = 1 (Select Instruction mode)
#define lcd_rs_clr() IOCLR0 = LCD_RS // RS = 0 (Select Data mode)
#define lcd_rw_set() IOSET0 = LCD_RW // RW = 1 (Read)
#define lcd_rw_clr() IOCLR0 = LCD_RW // RW = 0 (Write)
/* Chon chieu cac IO pins giao tiep LCD*/
#define lcd_dir_write() IODIR0 |= 0x000007ff //(0000 0000 0000 0000 0000 0xxx xxxx xxxx)
#define lcd_dir_read() IODIR0 &= 0xffffff00 //(0000 0000 0000 0000 0000 0000 xxxx xxxx)
/* Define cac thao tac co ban voi LCD */
#define lcd_clear() lcd_write_control(0x01) // Clear Display
#define lcd_cursor_home() lcd_write_control(0x02) // Set Cursor = 0
#define lcd_display_on() lcd_write_control(0x0E) // LCD Display Enable
#define lcd_display_off() lcd_write_control(0x08) // LCD Display Disable
#define lcd_display_blink() lcd_write_control(0x0F) // Set Cursor = Blink
#define lcd_cursor_on() lcd_write_control(0x0E) // Enable LCD Cursor
#define lcd_cursor_off() lcd_write_control(0x0C) // Disable LCD Cursor
#define lcd_cursor_left() lcd_write_control(0x10) // Shift Left Cursor
#define lcd_cursor_right() lcd_write_control(0x14) // Shift Right Cursor
#define lcd_display_sleft() lcd_write_control(0x18) // Shift Left Display
#define lcd_display_sright() lcd_write_control(0x1C) // Shift Right Display
/* prototype */
void lcd_init(void); // Initial LCD
void lcd_write_control(unsigned char); // Write Instuction to LCD
void lcd_write_ascii(unsigned char); // Write LCD Display(ASCII)
void goto_vitri(unsigned char); // Set Position Cursor LCD
void lcd_hienthi(unsigned char*); // Print Display to LCD
char busy_lcd(void); // Read Busy LCD Status
void enable_lcd(void); // Enable Pulse
void delay(unsigned long int); // Delay Function
/* Chuong trinh chinh */
int main(void)
lcd_init(); // Initial LCD
// Loop Print Message to LCD16 x 2 //
while(1) // Loop Continue
goto_vitri(0x80); // Set Cursor Line-1
lcd_hienthi("ngay 15/06/09"); // Display LCD Line-1
goto_vitri(0xC0); // Set Cursor = Line-2
lcd_hienthi("Chuong trinh LCD"); // Display LCD Line-2
delay(5000000); // Display Delay
lcd_clear();
lcd_hienthi("LPC2148-NXP"); // Display LCD Line-1
lcd_hienthi("EASY ARM!!!"); // Display LCD Line-2
lcd_clear();
lcd_hienthi("Tac gia viet:"); // Display LCD Line-1
lcd_hienthi("killer_hung yen"); // Display LCD Line-2
lcd_clear();
/* Initial LCD : 8bit,2-line display,5x7 dot charater */
void lcd_init()
//unsigned int i; // bien delay
PINSEL0 = 0x00000000; // GPIO cho cac pin P0.0 den P0.15(chon cac chan o Pinsel 0)
IODIR0 = 0x000007ff; // P0.0-P0.10 la output(gan cac chan p0.0-p0.10 lam dau ra)
delay(100000); // Power-On Delay (15 mS)
/* Check LCD*/
IOSET0 = 0x000007ff; // Reset all pins
IOCLR0 = 0x00000030; // D5:D4 = 11 (0000 0000 0000 0000 0000 0000 0011 0000)
enable_lcd(); // Xung enable cho LCD
delay(100000); // Delay 4.1ms
IOCLR0 = 0x000007ff; // Reset all pins
IOSET0 = 0x00000030; // D5:D4 = 11
enable_lcd();
while(busy_lcd()); // Xung enable cho LCD
delay(100000); // Delay 100 ms
enable_lcd();
while(busy_lcd()); //Wait LCD Execute complete
enable_lcd();
/* Config cho LCD */
//lcd_write_control(0x30);
lcd_write_control(0x38); // Function Set (DL=1 8-Bit,N=1 2 Line,F=0 5X7)
lcd_write_control(0x0C); // Display on/off Control (Entry Display,Cursor off,Cursor not Blink)
//lcd_write_control(0x06); // Entry Mode Set (I/D=1 Increment,S=0 Cursor Shift)
//lcd_write_control(0x01); // Clear Display (Clear Display,Set DD RAM Address=0)
delay(100000); // Wait Command Ready
/* thiet lap vi tri nhap nhay cua control*/
void goto_vitri(unsigned char i)
i |= 0x80; // Set DD-RAM Address Command
lcd_write_control(i);
/* Write construction to LCD */
void lcd_write_control(unsigned char val)
//unsigned int i;
lcd_rs_clr();
lcd_rw_clr(); // RS = 0 = Instruction Select
IOCLR0 = LCD_BUS; // Reset Data pins RS=0
IOSET0 = (val & LCD_BUS); // write value
enable_lcd(); // Xung enable LCD
while(busy_lcd()); // Wait LCD Execute Complete
/* Write ascii character to LCD */
void lcd_write_ascii(unsigned char val)
unsigned int i;
lcd_rs_set();
lcd_rw_clr(); // RS = 1 = Data Select
/* Print Display Data(ASCII) to LCD */
void lcd_hienthi(unsigned char* str)
int i;
for (i=0;i<=16 && str[i]!=0;i++)
{ // 16 Character Print
lcd_write_ascii(str[i]);
} // Print Byte to LCD
/* Wait LCD Ready */
/*char busy_lcd(void)
unsigned long busy_status; // Busy Status Read
unsigned int i; // Delay Count
lcd_dir_read(); // LCD Data Bus = Read
lcd_rs_clr(); // Instruction Select
lcd_rw_set(); // Read Direction
lcd_en_set(); // Start Read Busy
for (i=0;i<100;i++); // Delay Before Read
busy_status = (IOPIN0 & 0x00000080); // D7 la busy flag
if(busy_status == 0x00800000) // Read & Check Busy Flag
lcd_en_clr(); // Disable Read
lcd_rw_clr(); // Default = Write Direction
lcd_dir_write(); // LCD Data Bus = Write
return 1; // LCD Busy Status
else
return 0; // LCD Ready Status
/* Enable Pulse to LCD */
void enable_lcd(void) // Enable Pulse
//unsigned int i; // Delay Count
lcd_en_set(); // Enable ON (EN=1)
delay(100000);
lcd_en_clr(); // Enable OFF(EN=0)
/* Delay Time Function */
/* 1-4294967296 */
void delay(unsigned long int count1)
while(count1 > 0) {count1--;} // Loop Decrease Counter
.Vì thế để chắc cú bạn phải clear tất cả các bit trong PINSEL cần tác động để chọn chức năng cho PIN tuơng ứng.vd de set P0.0 la GPIO va P0.1 là UART(RXD). thì ta cần tác động tới bit 0-->bit 3 của PINSEL0.nên ta làm như sau
