xin giúp đỡ sữa lỗi đoan code này.Mong mấy anh giúp em
  • tuanepu
    Thành viên mới
    • Sep 2012
    • 18
    Vì em mới nghiên cứu mảng này nên không rõ sữa lỗi.Mong mấy anh text lại em đoạn code này.
    #include "16F877A.h"
    #define <16f877a.h>
    #device *=16 adc=10
    #use delay(clock=20000000)
    #FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT,NOLVP, NOCPD, NOWRT
    #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
    #include <LCD.C>
    #define enter RB0
    #define tang RB1
    #define giam RB2
    int8 read1,read2,m,thuc,dat_pc,dat,kp=100,kd=10,ki=2,er ror,pre_error;
    int16 P,I,D,sum,duty;
    #INT_RDA
    void serial_isr()
    {dat_pc=getc();
    void send_to_pc(int8 giatri)
    { printf("%2u\r",giatri);
    void phim_bam(void);
    void main ()
    set_tris_a(0xFF);
    set_tris_b(0b00000111);
    set_tris_c(0x00);
    set_tris_d(0x00);
    dat=39;
    //=====================khoi tao ngat ngoai=================
    enable_interrupts (INT_RDA);
    //ext_int_edge(H_TO_L);
    enable_interrupts (GLOBAL);
    //=====================khoi tao ADC ====================
    setup_adc_ports(AN0_AN1_AN3);
    setup_adc(ADC_CLOCK_INTERNAL);
    delay_ms(50);
    //=====================khoi tao PWM ====================
    setup_ccp1(ccp_pwm);
    lcd_init();
    Printf(LCD_putc,"\fLOP 43DDK TNUT");
    delay_ms(200);
    Printf(LCD_putc,"\nDO AN NHUNG");
    delay_ms(200);
    Printf(LCD_putc,"\f Waiting........");
    delay_ms(200);
    while(1)
    phim_bam();
    set_ADC_channel(0);//Doc ADC tu LM35
    delay_ms(10);
    read2=read_adc();
    thuc =read2*0.488758553;
    //============= chong trinh PID so =======================
    error = dat-thuc; // tinh sai so
    P = KP*error; // tinh thanh phan ti le
    I = I+KI*(pre_error+error)/4; // thoi gian lay mau la 0.5s
    D = KD*(error-pre_error)*2;
    pre_error= error; // luu lai gia tri sai so truoc do
    sum = P+I+D; // tin hieu tong khi qua khau PID
    duty = sum; // cap nhat gia PID vao bo phat PWM
    if (duty>1023)
    duty=1023; // gia tri lon nhat cua thanh ghi PWM
    // if (error==0)
    // I=255; // duy tri nhiet do khi ngo ra dat yeu cau
    if (error<0)
    duty =0; // tat PWM khi ngo ra vot lo
    set_pwm1_duty(duty); // cho phep phat PWM voi gia tri duty cu the
    // if(m!=0)
    // { duty=0;
    // error=0;
    //=========Gui du lieu ra LCD ==================
    lcd_init();
    printf(lcd_putc,"\f\rNhietdodat: %u\nNhietdothuc: %u",dat,thuc);
    // delay_us(200);
    //=======================Gui du du lieu ra PC============
    send_to_pc(thuc);
    void phim_bam()
    lcd_init();
    if (input(pin_b0) ==0)
    while(input(pin_b0) == 0)
    if (input(pin_b2) == 0)
    dat = dat - 1;
    while(input(pin_b2) == 0)//cho nha phim
    delay_ms(10);//chong nay phim
    if (input(pin_b1) == 0)
    dat = dat + 1;
    while(input(pin_b1) == 0)//cho nha phim
    đây là đoạn code thuyết trình mô phỏng máy ấp trứng.mong mấy anh sửa một số lỗi giúp em.Em xin cảm ơn
  • tuanepu
    Thành viên mới
    • Sep 2012
    • 18
    có 7 lỗi này anh ạ,em không hiểu cho lắm nên không kiểm tra được.Mong anh giúp
    tuanepu Tìm hiểu thêm về tuanepu
