có ai ko ạ...............
Hỏi về giao tiếp AVR và module SIMCOM
hi,hồi hè là tìm hiểu thôi,giờ bắt tay vô làm mạch thực mới phát sinh nhiều vấn đềNguyên văn bởi demon52 Xem bài viếtLuồng lập từ 7/2012 mà vẫn chưa làm xong à @@
Tập lệnh hay dùng nhất!
1. Test Commands:
AT Command Description
AT Check communication between the module and PC/Microcontroller.
ATD<Caller Phone Number>; Call to phone number. Ex: ATD0988434887;
ATDL Reial last telephone number.
ATI Display Product Identification Information. Ex: Return:SIM900 R11.0
AT&V Display Current Configuration.
AT+GSV Display Product Identification Information. Ex: SIMCOM_Ltd - SIMCOM_SIM908 - Revision:1137B02SIM908M64_ST
AT+CSQ Signal Quality Report.Ex: +CSQ: 28,0 (<99 Signal is good)
AT+CPIN? Check Sim status. Ex: +CPIN: READY
AT+IPR? Check(Test/Set/Read) Baud rate. Ex: +IPR: 0(Auto_bauding)
AT+CSCA? SMS Service Center Address. Ex: +CSCA: "+84980200030",145
AT+CMTE? Read the temperature when the module is running. Ex: +CMTE: 0,38
AT+CGREG? Network Registration Status. Return: +CREG: 1,1 - Enable Network and Registed.
AT+CGMI Get manufacturer information. Ex: SIMCOM_Ltd
AT+CGMR Get software version. Ex: Revision:1137B02SIM908M64_ST
AT+CGSN Get device IMEI. 861001000034104
AT+COPS? Display the current network operation: +COPS: 0,0,"VNM and VIETTEL"
Trên dây là 1 s? l?nh d? các b?n Test vi?c giao ti?p gi?a PC/Microcontroller v?i SIM908.
2. Configuration Command:
* These AT Command will be used in the first times to configuration for SIM908.
1. ATZ Reset default configuration.
2 Echo:
- ATE0 Echo Off. //N?u mu?n t?t Echo
- ATE1 Echo ON.//N?u mu?n m? Echo
3. AT+CLIP=1 Enable display phone number of calling.
4. AT&W Save Active(ATE0 and AT+CLIP=1) Profile.
5. AT+CMGF=1 SMS Text Mode.
6. New message indication:
- AT+CNMI=1,1,0,0,0 New message indication enable and select SIM memory storage.
Return only: +CMTI: "SM",<index>(+CMTI: "SM",1)
Or:
- AT+CNMI=2,0,0,0,0 New message indication enable and select SIM memory storage.
Return:+CMT: "+84988434887","","12/04/21,17:00:26+28"[Noi dung tin nhan]
7.AT+CSAS Save SMS Setting.Web:
->Nhận thiết kế, hoàn thiện dự án, sản phẩm điện tử<-
-->Giải pháp GSM/GPRS/GPS - Công nghệ RFID<--
không hiểu sao mình gửi lệnh
UART_init();
UART_tx_rx_on();
UART_putchar('A');
delay_ms(1000);
UART_putchar('T');
delay_ms(1000);
UART_putchar('D');
delay_ms(1000);
UART_putchar('0');
delay_ms(1000);
UART_putchar('9');
delay_ms(1000);
UART_putchar('8');
delay_ms(1000);
UART_putchar('8');
delay_ms(1000);
UART_putchar('6');
delay_ms(1000);
UART_putchar('0');
delay_ms(1000);
UART_putchar('0');
delay_ms(1000);
UART_putchar('5');
delay_ms(1000);
UART_putchar('2');
delay_ms(1000);
UART_putchar('4');
delay_ms(1000);
UART_putchar(';');
delay_ms(1000);
UART_putchar('\n');
delay_ms(1000);
UART_putsf(CR);
delay_ms(10000);
mà sao lại hiển thị như thế bạn mấy bạn
Ko cần phải delay sau mỗi lần gửi kí tự đâu. Trong IDE đọc phần fprintf(Uart_Stream,"AT/r"); vầy là xong nè... ko nhớ viết đúng ko nữa nhưng na ná thế.Web:
Bạn có thể download phần mềm giao tiếp với Module SIM ở đây, soft do mình viết chạy ổn định trên module SIM900/908
Link software: Phần mềm test giao tiếp UART, GSM, USB | VnTech24hWeb:
Max thế. ở chổ banlinhkien.vn bán co 650k mà mạch làm đầy đủ và rất tốt nữaNguyên văn bởi hitechvn Xem bài viếtĐúng rồi bên Hoàng Phát ở gần Thủ Lệ có bán module này. Giao tiếp rs232 giá 850K.
. Em đang làm cái này , mua đồ làm mạch hết ùi, ngồi nghiên cứu cả tháng trời mà chẵng đâu vào đâu + ngâm cứu bài viết này từ đầu tới giờ mà vẩn không hiểu, ai giúp em với...
ko hiểu chỗ nào và cần giúp gì?. bạn mua modul sim ở banlinhkien.com thì nhờ bên đó họ hỗ trợ luôn cho.Nguyên văn bởi congphap245 Xem bài viếtMax thế. ở chổ banlinhkien.vn bán co 650k mà mạch làm đầy đủ và rất tốt nữa
. Em đang làm cái này , mua đồ làm mạch hết ùi, ngồi nghiên cứu cả tháng trời mà chẵng đâu vào đâu + ngâm cứu bài viết này từ đầu tới giờ mà vẩn không hiểu, ai giúp em với...(^_^) hoangnv.3i@gmail.com
06-12-2025, 17:17 -
05-12-2025, 19:59 -
04-12-2025, 01:27 -
