e làm xong nhưng sao nó chạy ko đúng gì hết các anh có thể coi lại giúp e được ko
đây là code và file mô phỏng của em
9.rar
9.rar
/***************************************************** This program was produced by the CodeWizardAVR V2.05.0 Professional Automatic Program Generator © Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l. http://www.hpinfotech.com Project : Version : Date : 7/11/2012 Author : NeVaDa Company : Comments: Chip type : ATmega16 Program type : Application AVR Core Clock frequency: 8.000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 256 *****************************************************/ #include <mega16.h> #include <delay.h> // I2C Bus functions #asm .equ __i2c_port=0x1B ;PORTA .equ __sda_bit=1 .equ __scl_bit=0 #endasm #include <i2c.h> // DS1307 Real Time Clock functions #include <ds1307.h> // Alphanumeric LCD Module functions // Alphanumeric LCD Module functions #asm .equ __lcd_port=0x12 ;PORTD #endasm #include <lcd.h> // Declare your global variables here // Declare your global variables here unsigned char h,m,s,ngay,thang,nam; void main(void) { // Declare your local variables here // Input/Output Ports initialization // Port A initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTA=0x00; DDRA=0x00; // Port B initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTB=0x00; DDRB=0x00; // Port C initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTC=0x00; DDRC=0x00; // Port D initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTD=0x00; DDRD=0x00; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=FFh // OC0 output: Disconnected TCCR0=0x00; TCNT0=0x00; OCR0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer 1 Stopped // Mode: Normal top=FFFFh // OC1A output: Discon. // OC1B output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge // Timer 1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer 2 Stopped // Mode: Normal top=FFh // OC2 output: Disconnected ASSR=0x00; TCCR2=0x00; TCNT2=0x00; OCR2=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off // INT2: Off MCUCR=0x00; MCUCSR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; SFIOR=0x00; // I2C Bus initialization i2c_init(); // DS1307 Real Time Clock initialization // Square wave output on pin SQW/OUT: On // Square wave frequency: 1Hz rtc_init(0,1,0); // LCD module initialization lcd_init(16); rtc_set_time(23,59,59); rtc_set_date(01,07,91); while (1) { rtc_get_time(&h,&m,&s); rtc_get_date(&ngay,&thang,&nam); lcd_gotoxy(0,0); lcd_putchar(h/10 | 0x30); lcd_putchar(h%10 | 0x30); lcd_putsf(":"); lcd_putchar(m/10 | 0x30); lcd_putchar(m%10 | 0x30); lcd_putsf(":"); lcd_putchar(s/10 | 0x30); lcd_putchar(s%10 | 0x30); lcd_gotoxy(0,1); lcd_putchar(ngay/10 | 0x30); lcd_putchar(ngay%10 | 0x30); lcd_putsf("--"); lcd_putchar(thang/10 | 0x30); lcd_putchar(thang%10 | 0x30); lcd_putsf("--"); lcd_putchar(nam/10 | 0x30); lcd_putchar(nam%10 | 0x30); delay_ms(500); // Place your code here } }
/***************************************************** This program was produced by the CodeWizardAVR V2.05.0 Professional Automatic Program Generator © Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l. http://www.hpinfotech.com Project : Version : Date : 7/11/2012 Author : NeVaDa Company : Comments: Chip type : ATmega16 Program type : Application AVR Core Clock frequency: 8.000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 256 *****************************************************/ #include <mega16.h> #include <delay.h> // I2C Bus functions #asm .equ __i2c_port=0x1B ;PORTA .equ __sda_bit=1 .equ __scl_bit=0 #endasm #include <i2c.h> // DS1307 Real Time Clock functions #include <ds1307.h> // Alphanumeric LCD Module functions // Alphanumeric LCD Module functions #asm .equ __lcd_port=0x12 ;PORTD #endasm #include <lcd.h> // Declare your global variables here // Declare your global variables here unsigned char h,m,s,ngay,thang,nam; void main(void) { // Declare your local variables here // Input/Output Ports initialization // Port A initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTA=0x00; DDRA=0x00; // Port B initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTB=0x00; DDRB=0x00; // Port C initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTC=0x00; DDRC=0x00; // Port D initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTD=0x00; DDRD=0x00; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=FFh // OC0 output: Disconnected TCCR0=0x00; TCNT0=0x00; OCR0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer 1 Stopped // Mode: Normal top=FFFFh // OC1A output: Discon. // OC1B output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge // Timer 1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer 2 Stopped // Mode: Normal top=FFh // OC2 output: Disconnected ASSR=0x00; TCCR2=0x00; TCNT2=0x00; OCR2=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off // INT2: Off MCUCR=0x00; MCUCSR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; SFIOR=0x00; // I2C Bus initialization i2c_init(); // DS1307 Real Time Clock initialization // Square wave output on pin SQW/OUT: On // Square wave frequency: 1Hz rtc_init(0,1,0); // LCD module initialization lcd_init(16); rtc_set_time(23,59,59); rtc_set_date(01,07,91); while (1) { rtc_get_time(&h,&m,&s); rtc_get_date(&ngay,&thang,&nam); lcd_gotoxy(0,0); [COLOR="#FF0000"] lcd_putchar(h/10 | 0x30); lcd_putchar(h%10 | 0x30); lcd_putsf(":"); lcd_putchar(m/10 | 0x30); lcd_putchar(m%10 | 0x30); lcd_putsf(":"); lcd_putchar(s/10 | 0x30); lcd_putchar(s%10 | 0x30);[/COLOR] lcd_gotoxy(0,1); lcd_putchar(ngay/10 | 0x30); lcd_putchar(ngay%10 | 0x30); lcd_putsf("--"); lcd_putchar(thang/10 | 0x30); lcd_putchar(thang%10 | 0x30); lcd_putsf("--"); lcd_putchar(nam/10 | 0x30); lcd_putchar(nam%10 | 0x30); delay_ms(500); // Place your code here } }
void key_time()
{if(mode==1)
{//lcd_clear();
lcd_gotoxy(0,1);
lcd_putsf(" Chinh Gio");
lcd_gotoxy(5,0);
//rtc_get_time(&h,&m,0);
if((up==0)&(down==1))
{if(h==23)
h=0;
else
h++;
if((down==0)&(up==1))
{if(h==0)
h=23;
else
h--;
