Lỗi này là lỗi gì trong AVRSTUDIO ?
  • soulasylum
    Thành viên chính thức
    • Feb 2009
    • 78
    lỗi báo error: lvalue required as left operand of assignment
    lỗi này là lỗi gì thế các bác.
    chương trình của em:
    Code:
    #include <avr/io.h>
    #include <avr/pgmspace.h>
    #include <util/delay.h>
    #include <avr/interrupt.h>
    #include "pcd8544.h"
    #include "main.h"
    #define contrast    0x7F
    //#define contrast  0x2A
    #define LATCH	  	PB2
    #define DATA		PB3
    #define CLK			PB5
    #define D5          851
    #define E5          758
    #define Fsh5        675
    #define G5          637
    #define A5          568
    #define B5 			506
    #define C6 			477
    #define D6 			425
    #define DUR 		40
    static const unsigned char data[6][8] PROGMEM = {
    	{0xff,0x00,0xff,0x00,0xff,0x00,0xff,0x00},
    	{0x0f,0xf0,0x0f,0xf0,0x0f,0xf0,0x0f,0xf0}
    volatile unsigned char temp[8],i,j=0;
    void latch_data();
    void latch_data( void )
    	LATCH = 1;
    	LATCH = 0;
    ISR (TIMER1_COMPA_vect)
    	for (i=0;i<8;i++)
    		temp[i] = data[0][i];
    ISR (TIMER2_COMP)
    	for (i=0;i<8;i++)
    		if (temp[i]&(0x80>>i))
    			DATA = 0;
    		else
    			DATA = 1;
    		CLK = 0;
    		CLK = 1;
    	latch_data();
    	PORTC = j|8;
    	j++;
    	if (j==8)
    		j=0;
    int main()
    	PORTD=0x00;
    	DDRD=0xFF;
    	PORTB=0x00;
    	DDRB=(1<<CLK)|(1<<LATCH)|(1<<DATA);
    	// Timer/Counter 1 initialization
    	// Clock source: System Clock
    	// Clock value: 11.719 kHz
    	// Mode: Normal top=FFFFh
    	// OC1A output: Discon.
    	// OC1B output: Discon.
    	// Noise Canceler: Off
    	// Input Capture on Falling Edge
    	// Timer 1 Overflow Interrupt: Off
    	// Input Capture Interrupt: Off
    	// Compare A Match Interrupt: On
    	// Compare B Match Interrupt: Off
    	TCCR1A=0x00;
    	TCCR1B=0x05;
    	TCNT1H=0x00;
    	TCNT1L=0x00;
    	ICR1H=0x00;
    	ICR1L=0x00;
    	OCR1AH=0x01;
    	OCR1AL=0xD4;
    	OCR1BH=0x00;
    	OCR1BL=0x00;
    	// Timer/Counter 2 initialization
    	// Clock value: 46.875 kHz
    	// Mode: CTC top=OCR2
    	// OC2 output: Disconnected
    	ASSR=0x00;
    	TCCR2=0x0E;
    	TCNT2=0x00;
    	OCR2=0x75;
    	// Timer(s)/Counter(s) Interrupt(s) initialization
    	TIMSK=0x90;
    	sei();
    	PORTC=0x00;
    	DDRC=0xFF;
      	LcdInit();
            LcdContrast(contrast);
    	LcdInit();
        return 0;
    các dòng có lỗi như trên là :
    Code:
    LATCH = 0;
    LATCH = 1;
    DATA = 0;
    DATA = 1;
    CLK = 0;
    CLK =1;
  • soulasylum
    • Feb 2009
    • 78
    có phải cách #define sai không các bác nhỉ
    • dt_love
      • Feb 2007
      • 509
      Dòng định nghĩa #define của bạn bị sai rồi.
      Vì trong thư viện IO của nó, hình như là không có PB2,PB3 hay gì đó mà là PORTB, và hình như là nó không cho truy cập đến từng bit giống CV
      • quanhdt
        • Jul 2005
        • 79
        #4
        Nguyên văn bởi soulasylum Xem bài viết
        Một ví dụ cụ thể
        #define LED7SEG_DATA_DDR DDRA
        #define LED7SEG_DATA_PORT PORTA
        #define LED7SEG_DATA_BIT PA1
        #define LED7SEG_CLOCK_DDR DDRA
        #define LED7SEG_CLOCK_PORT PORTA
        #define LED7SEG_CLOCK_BIT PA2
        #define LED7SEG_LATCH_DDR DDRA
        #define LED7SEG_LATCH_PORT PORTA
        #define LED7SEG_LATCH_BIT PA3
        #define led7seg_data_ouput() LED7SEG_DATA_DDR |= _BV(LED7SEG_DATA_BIT)
        #define led7seg_data_high() LED7SEG_DATA_PORT |= _BV(LED7SEG_DATA_BIT)
        #define led7seg_data_low() LED7SEG_DATA_PORT &= ~_BV(LED7SEG_DATA_BIT)
        #define led7seg_clock_ouput() LED7SEG_CLOCK_DDR |= _BV(LED7SEG_CLOCK_BIT)
        #define led7seg_clock_high() LED7SEG_CLOCK_PORT |= _BV(LED7SEG_CLOCK_BIT)
        #define led7seg_clock_low() LED7SEG_CLOCK_PORT &= ~_BV(LED7SEG_CLOCK_BIT)
        #define led7seg_latch_ouput() LED7SEG_LATCH_DDR |= _BV(LED7SEG_LATCH_BIT)
        #define led7seg_latch_high() LED7SEG_LATCH_PORT |= _BV(LED7SEG_LATCH_BIT)
        #define led7seg_latch_low() LED7SEG_LATCH_PORT &= ~_BV(LED7SEG_LATCH_BIT)
        • agnort
          • May 2007
          • 156
          #5
          cách set bit va clear bit trong AVRStudio
          #define setbit(port,pin) port |= 1<<pin
          #define clrbit(port,pin) port &= ~(1<<pin)
          VD: setbit(PORTD,PORTD1);
          • soulasylum
            • Feb 2009
            • 78
            #6
            thanks các bác
            • songproo
              Thành viên mới
              • Aug 2010
              • 5
              #7
              help
              e mới học avr studio, nhưng khi đã cải cả winavr và e coppy thử một đoạn code, chạy thử và nó báo warning như sau:
              c:/winavr-20100110/lib/gcc/../../avr/include/util/delay.h:85:3: warning: #warning "F_CPU not defined for <util/delay.h>"
              mong các anh chị giúp em cách khắc phục
              • semipower
                • Jul 2010
                • 44
                #8
                Hàm delay yêu cầu định nghĩa tần số cho CPU. Ví dụ:
                #define F_CPU 8000000UL
                Giải pháp nguồn điện và nguồn dự phòng chuyên nghiệp.
                Thiết kế chế tạo nguồn xung theo yêu cầu:
                • nguyentuanqs
                  Thành viên mới
                  • Aug 2010
                  • 72
                  #9
                  các bác cho em hỏi toán tử BV trong mấy cái macro ấy có nghĩa gì ạ?
                  soulasylum Tìm hiểu thêm về soulasylum
